查看: 4878|回復(fù): 2
51單片機(jī)電子抽獎(jiǎng)系統(tǒng)程序設(shè)計(jì)+Proteus仿真
電子抽獎(jiǎng)系統(tǒng)仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
電子抽獎(jiǎng)系統(tǒng)單片機(jī)源程序如下:
#include <AT89X52.h>
#include <intrins.h>
#include <stdlib.h>
#define TRUE  1
#define FALSE 0
bit  bT0Flg = FALSE;
//U2 595的驅(qū)動(dòng)引腳定義
sbit sbSHCP2 = P2^0;
sbit sbDS2 = P2^1;
sbit sbSTCP2 = P2^2;
//U3 595的驅(qū)動(dòng)引腳定義
sbit sbSHCP3 = P2^3;
sbit sbDS3 = P2^4;
sbit sbSTCP3 = P2^5;
//U4 595的驅(qū)動(dòng)引腳定義
sbit sbSHCP4 = P2^6;
sbit sbDS4 = P2^7;
sbit sbSTCP4 = P3^0;
//U5 595的驅(qū)動(dòng)引腳定義
sbit sbSHCP5 = P3^1;
sbit sbDS5 = P3^3;
sbit sbSTCP5 = P3^4;
//U6 595的驅(qū)動(dòng)引腳定義
sbit sbSHCP6 = P3^5;
sbit sbDS6 = P3^6;
sbit sbSTCP6 = P3^7;
unsigned char temp2,temp3,temp4,temp5,temp6;
bdata unsigned char sw;    //位定義
sbit sw0 = sw ^ 0;
sbit sw1 = sw ^ 1;
sbit sw2 = sw ^ 2;
sbit sw3 = sw ^ 3;
sbit sw4 = sw ^ 4;
sbit sw5 = sw ^ 5;
sbit sw6 = sw ^ 6;
sbit sw7 = sw ^ 7;
unsigned char code SEGtable[]=
         0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,
void Delay(unsigned int x)
         unsigned char i;
        while(x--)
                 for(i=0;i<120;i++);
//595輸入函數(shù)2號(hào)
void Input5952()
         unsigned char i;
        for(i=0;i<8;i++)
                 temp2 <<= 1;
                sbDS2   = CY;
                sbSHCP2 = 1;
                _nop_();
                _nop_();
                sbSHCP2 = 0;
//595輸出函數(shù)2號(hào)
void Output5952()
         sbSTCP2 = 0;
        _nop_();
        sbSTCP2 = 1;
        _nop_();
        sbSTCP2 = 0;
//595輸入函數(shù)3號(hào)
void Input5953()
         unsigned char i;
        for(i=0;i<8;i++)
                 temp3 <<= 1;
                sbDS3   = CY;
                sbSHCP3 = 1;
                _nop_();
                _nop_();
                sbSHCP3 = 0;
//595輸出函數(shù)3號(hào)
void Output5953()
         sbSTCP3 = 0;
        _nop_();
        sbSTCP3 = 1;
        _nop_();
        sbSTCP3 = 0;
//595輸入函數(shù)4號(hào)
void Input5954()
         unsigned char i;
        for(i=0;i<8;i++)
                 temp4 <<= 1;
                sbDS4   = CY;
                sbSHCP4 = 1;
                _nop_();
                _nop_();
                sbSHCP4 = 0;
//595輸出函數(shù)4號(hào)
void Output5954()
         sbSTCP4 = 0;
        _nop_();
        sbSTCP4 = 1;
        _nop_();
        sbSTCP4 = 0;
//595輸入函數(shù)5號(hào)
void Input5955()
         unsigned char i;
        for(i=0;i<8;i++)
                 temp5 <<= 1;
                sbDS5   = CY;
                sbSHCP5 = 1;
                _nop_();
                _nop_();
                sbSHCP5 = 0;
//595輸出函數(shù)5號(hào)
void Output5955()
         sbSTCP5 = 0;
        _nop_();
        sbSTCP5 = 1;
        _nop_();
        sbSTCP5 = 0;
//595輸入函數(shù)6號(hào)
void Input5956()
         unsigned char i;
        for(i=0;i<8;i++)
                 temp6 <<= 1;
                sbDS6   = CY;
                sbSHCP6 = 1;
                _nop_();
                _nop_();
                sbSHCP6 = 0;
//595輸出函數(shù)6號(hào)
void Output5956()
         sbSTCP6 = 0;
        _nop_();
        sbSTCP6 = 1;
        _nop_();
        sbSTCP6 = 0;
void initrand(void)
           unsigned char counter=0;
    P1 = 0xff;
    sw = P1;
    counter = 0;  //統(tǒng)計(jì)開關(guān)閉合的數(shù)碼
    if(sw0 == 1)
       counter++;
    if(sw1 == 1)
       counter++;
    if(sw2 == 1)
       counter++;
    if(sw3 == 1)
       counter++;
    if(sw4 == 1)
       counter++;
    if(sw5 == 1)
       counter++;
    if(sw6 == 1)
       counter++;
    if(sw7 == 1)
       counter++;
    srand(counter);       //初始化種子
void Timer0Init(void)                           //定時(shí)器0初始化函數(shù)
  TMOD = 0x01;                                  //設(shè)置T1工作方式
        TH0 = 0x00;
        TL0 = 0x0C;        //100ms定時(shí)
  ET0 = 1;                                      //開啟定時(shí)器0中斷
//  TR0 = 1;                                      //啟動(dòng)定時(shí)器
void Timer0Deal(void) interrupt 1 using 1       //定時(shí)器0中斷處理函數(shù)
        ET0 = 0;                       //首先關(guān)閉中斷
        TH0 = 0x00;                    //然后重新裝入預(yù)制值
        TL0 = 0x0C;
  ET0 = 1;                       //打開T0中斷
  bT0Flg = TRUE;                  //定時(shí)器中斷標(biāo)志位
EX_INT0() interrupt 0 using 1         //外部中斷0服務(wù)函數(shù)
  if(TR0 == 1)                       //判斷當(dāng)前定時(shí)計(jì)數(shù)器的狀態(tài)
    TR0 = 0;
    TR0 = 1;
    initrand();   //初始化種子
  unsigned int randdata = 0;
  unsigned char wdata,qdata,baidata,sdata,gdata;
  Timer0Init();                     //初始化時(shí)鐘
  IT0 = 1;                           //設(shè)置外部中斷0觸發(fā)方式為低脈沖
  EX0 = 1;                           //使能外部中斷0
  EA = 1;                           //打開串口中斷標(biāo)志
    while(bT0Flg==FALSE);            //等待延時(shí)標(biāo)志位
    bT0Flg=FALSE;
    randdata = 2 * rand();    //獲得隨機(jī)數(shù)
    wdata = randdata/10000;    //輸出萬位
    temp2 = SEGtable[wdata];
          Input5952();
                Output5952();
    qdata = randdata%10000/1000;  //輸出千位
    temp3 =  SEGtable[qdata];
          Input5953();
                Output5953();
    baidata = randdata%1000/100;  //輸出百位
    temp4 =  SEGtable[baidata];
          Input5954();
                Output5954();
    sdata = randdata%100/10;    //輸出10位
    temp5 =  SEGtable[sdata];
          Input5955();
                Output5955();
    gdata = randdata%10;    //輸出個(gè)位
    temp6 =  SEGtable[gdata];
          Input5956();
                Output5956();
全部資料51hei下載地址:
基于51單片機(jī)和Proteus仿真的電子抽獎(jiǎng)系統(tǒng).zip (91.37 KB, 下載次數(shù): 45)
ID:584850 發(fā)表于 2019-7-17 17:16 | 只看該作者
        TH0 = 0x00;
        TL0 = 0x0C;
  ET0 = 1;                       //打開T0中斷
    TR0 = 0;
    TR0 = 1;
    initrand();   //初始化種子
  EX0 = 1;                           //使能外部中斷0
    bT0Flg=FALSE;
請問這一段是什么意思
ID:943660 發(fā)表于 2021-6-26 17:33 來自觸屏版 | 只看該作者
那邊的sw1按鍵有什么作用啊
