查看: 3173|回復(fù): 1
51單片機(jī)和Proteus仿真的多點(diǎn)(八路)溫度采集系統(tǒng)代碼
#include <AT89X52.h>
#include <Intrins.h>
#define                DATA        P1      //1602驅(qū)動(dòng)端口
//ROM操作命令
#define                 READ_ROM                       0x33                    //讀ROM
#define                 SKIP_ROM                       0xCC                    //跳過ROM
#define                 MATCH_ROM               0x55                    //匹配ROM
#define                 SEARCH_ROM              0xF0                    //搜索ROM
#define                 ALARM_SEARCH            0xEC                    //告警搜索
//存儲(chǔ)器操作命令
#define                 ANEW_MOVE                     0xB8                    //重新調(diào)出E^2數(shù)據(jù)
#define                 READ_POWER              0xB4                    //讀電源
#define                 TEMP_SWITCH             0x44                    //啟動(dòng)溫度變換
#define                 READ_MEMORY             0xBE                    //讀暫存存儲(chǔ)器
#define                 COPY_MEMORY             0x48                    //復(fù)制暫存存儲(chǔ)器
#define                 WRITE_MEMORY            0x4E                    //寫暫存存儲(chǔ)器
//數(shù)據(jù)存儲(chǔ)結(jié)構(gòu)
typedef struct tagTempData
        unsigned char                                         btThird;                                                        //百位數(shù)據(jù)
        unsigned char                                         btSecond;                                                        //十位數(shù)據(jù)
        unsigned char                                         btFirst;                                                        //個(gè)位數(shù)據(jù)
        unsigned char                                         btDecimal;                                                        //小數(shù)點(diǎn)后一位數(shù)據(jù)
        unsigned char                                        btNegative;                                                        //是否為負(fù)數(shù)
}TEMPDATA;
TEMPDATA m_TempData;
//引腳定義
sbit                                                         DQ = P2^7;                                                        //數(shù)據(jù)線端口
sbit                 RS=                P2^0;
sbit                 RW=                P2^1;
sbit                 E=                P2^2;
//DS18B20序列號(hào),通過調(diào)用GetROMSequence()函數(shù)在P1口讀出(讀8次)
const unsigned char code ROMData1[8] = {0x28, 0x33, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0xD7};        //U1
const unsigned char code ROMData2[8] = {0x28, 0x30, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x8E};        //U2
const unsigned char code ROMData3[8] = {0x28, 0x31, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0xB9};        //U3
const unsigned char code ROMData4[8] = {0x28, 0x32, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0xE0};        //U4
const unsigned char code ROMData5[8] = {0x28, 0x34, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x52};        //U5
const unsigned char code ROMData6[8] = {0x28, 0x35, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x65};        //U6
const unsigned char code ROMData7[8] = {0x28, 0x36, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x3C};        //U7
const unsigned char code ROMData8[8] = {0x28, 0x37, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x0B};        //U8
//判斷忙指令
void Busy()
        DATA = 0xff;
        RS = 0;
        RW = 1;
           while(DATA & 0x80)
                E = 0;
                   E = 1;
           E = 0;
//寫指令程序
void WriteCommand(unsigned char btCommand)
        Busy();
        RS = 0;
        RW = 0;
        E = 1;
        DATA = btCommand;
        E = 0;
//寫數(shù)據(jù)程序
void WriteData(unsigned char btData)
        Busy();
        RS = 1;
        RW = 0;
        E = 1;
        DATA = btData;
        E = 0;
//清屏顯示
void Clear()
        WriteCommand(1);
//初始化
void Init()
        WriteCommand(0x0c);        //開顯示,無光標(biāo)顯示
        WriteCommand(0x06);        //文字不動(dòng),光標(biāo)自動(dòng)右移
        WriteCommand(0x38);        //設(shè)置顯示模式:8位2行5x7點(diǎn)陣
//顯示單個(gè)字符
void DisplayOne(bit bRow, unsigned char btColumn, unsigned char btData, bit bIsNumber)
        if (bRow)                 WriteCommand(0xc0 + btColumn);
        else                      WriteCommand(0x80 + btColumn);
        if (bIsNumber)         WriteData(btData + 0x30);
        else                   WriteData(btData);
//顯示字符串函數(shù)
void DisplayString(bit bRow, unsigned char btColumn, unsigned char *pData)
        while (*pData != '\0')
                   if (bRow) WriteCommand(0xc0 + btColumn);        //顯示在第1行
                   else            WriteCommand(0x80 + btColumn);        //顯示在第0行
                WriteData(*(pData++));                                                //要顯示的數(shù)據(jù)
                btColumn++;        //列數(shù)加一
//延時(shí)16us子函數(shù)
void Delay16us()
        unsigned char a;
        for (a = 0; a < 4; a++);
//延時(shí)60us子函數(shù)
void Delay60us()
        unsigned char a;
        for (a = 0; a < 18; a++);
//延時(shí)480us子函數(shù)
void Delay480us()
        unsigned char a;
        for (a = 0; a < 158; a++);
//延時(shí)240us子函數(shù)
void Delay240us()
        unsigned char a;
        for (a = 0; a < 78; a++);
//延時(shí)500ms子函數(shù)
void Delay500ms()
        unsigned char a, b, c;
        for (a = 0; a < 250; a++)
        for (b = 0; b < 3; b++)
        for (c = 0; c < 220; c++);
//芯片初始化
void Initialization()
                DQ = 0;
                Delay480us();                         //延時(shí)480us
                DQ = 1;
                Delay60us();                        //延時(shí)60us
                if(!DQ)                                  //收到ds18b20的應(yīng)答信號(hào)
                        DQ = 1;
                        Delay240us();                //延時(shí)240us
                        break;
//寫一個(gè)字節(jié)(從低位開始寫)
void WriteByte(unsigned char btData)
        unsigned char i, btBuffer;
        for (i = 0; i < 8; i++)
                btBuffer = btData >> i;
                if (btBuffer & 1)
                        DQ = 0;
                        _nop_();
                        _nop_();
                        DQ = 1;
                        Delay60us();
                        DQ = 0;
                        Delay60us();
                        DQ = 1;
//讀一個(gè)字節(jié)(從低位開始讀)
unsigned char ReadByte()
        unsigned char i, btDest;
                btDest >>= 1;
                DQ = 0;
                _nop_();
                _nop_();
                DQ = 1;
                Delay16us();
                if (DQ) btDest |= 0x80;
                Delay60us();
        return btDest;
//序列號(hào)匹配
void MatchROM(const unsigned char *pMatchData)
        unsigned char i;
        Initialization();
        WriteByte(MATCH_ROM);
        for (i = 0; i < 8; i++) WriteByte(*(pMatchData + i));
//得到64位ROM序列(在P1口顯示,必須與Proteus聯(lián)調(diào)且在單步調(diào)試下才能得到)
/*void GetROMSequence()
        unsigned char i;
        Initialization();
        WriteByte(READ_ROM);
        P1 = ReadByte();
//讀取溫度值
TEMPDATA ReadTemperature()
        TEMPDATA TempData;
        unsigned int iTempDataH;
        unsigned char btDot, iTempDataL;
        static unsigned char i = 0;
        TempData.btNegative = 0;                                                //為0溫度為正
        i++;
        if (i == 9) i = 1;
        Initialization();
        WriteByte(SKIP_ROM);                                                        //跳過ROM匹配
        WriteByte(TEMP_SWITCH);                                                        //啟動(dòng)轉(zhuǎn)換
        Delay500ms();        //調(diào)用一次就行
        Delay500ms();
        Initialization();
        //多個(gè)芯片的時(shí)候用MatchROM(ROMData)換掉WriteByte(SKIP_ROM)
        switch (i)
                case 1 : MatchROM(ROMData1); break;                        //匹配1
                case 2 : MatchROM(ROMData2); break;                        //匹配2
                case 3 : MatchROM(ROMData3); break;                        //匹配3
                case 4 : MatchROM(ROMData4); break;                        //匹配4
                case 5 : MatchROM(ROMData5); break;                        //匹配5
                case 6 : MatchROM(ROMData6); break;                        //匹配6
                case 7 : MatchROM(ROMData7); break;                        //匹配7
                case 8 : MatchROM(ROMData8); break;                        //匹配8
        //WriteByte(SKIP_ROM);                                                        //跳過ROM匹配(單個(gè)芯片時(shí)用這句換掉上面的switch)
        WriteByte(READ_MEMORY);                                                        //讀數(shù)據(jù)
        iTempDataL = ReadByte();
        iTempDataH = ReadByte();
        iTempDataH <<= 8;
        iTempDataH |= iTempDataL;
        if (iTempDataH & 0x8000)
                TempData.btNegative = 1;
                iTempDataH = ~iTempDataH + 1;                                //負(fù)數(shù)求補(bǔ)
        //為了省去浮點(diǎn)運(yùn)算帶來的開銷,而采用整數(shù)和小數(shù)部分分開處理的方法(沒有四舍五入)
        btDot = (unsigned char)(iTempDataH & 0x000F);        //得到小數(shù)部分
        iTempDataH >>= 4;        //得到整數(shù)部分
        btDot *= 5;        //btDot*10/16得到轉(zhuǎn)換后的小數(shù)數(shù)據(jù)
        btDot >>= 3;
        //數(shù)據(jù)處理
        TempData.btThird   = (unsigned char)iTempDataH / 100;
        TempData.btSecond  = (unsigned char)iTempDataH % 100 / 10;
        TempData.btFirst   = (unsigned char)iTempDataH % 10;
        TempData.btDecimal = btDot;
        return TempData;
//數(shù)據(jù)處理子程序
void DataProcess()
        m_TempData = ReadTemperature();
        if (m_TempData.btNegative) DisplayOne(1, 6, '-', 0);
        else DisplayOne(1, 6, m_TempData.btThird, 1);
        DisplayOne(1, 7, m_TempData.btSecond, 1);
        DisplayOne(1, 8, m_TempData.btFirst, 1);
        DisplayOne(1, 10, m_TempData.btDecimal, 1);
        //GetROMSequence();
        Clear();
        Init();
        DisplayString(0, 0, "  Temperature");
        DisplayOne(1, 9, '.', 0);
        while (1) DataProcess();
全部資料51hei下載地址:
基于51單片機(jī)和Proteus仿真的多點(diǎn)溫度采集系統(tǒng).zip (70.95 KB, 下載次數(shù): 32)
ID:526896 發(fā)表于 2019-5-11 13:58 | 只看該作者
可以按鍵調(diào)整多個(gè)DS18B20的上下限嗎
