查看: 5040|回復(fù): 2
51單片機(jī)貨車(chē)超重監(jiān)測(cè)系統(tǒng)程序+Proteus仿真
基于51單片機(jī)和Proteus仿真的貨車(chē)超重監(jiān)測(cè)系統(tǒng)仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
#include <AT89X52.h>
#include <intrins.h>
#include <stdio.h>
#define R24C04ADD 0xA1
#define W24C04ADD 0xA0
//ADC0832的引腳
sbit ADCS =P2^2;  //ADC0832 chip seclect
sbit ADDI =P2^4;  //ADC0832 k in
sbit ADDO =P2^4;  //ADC0832 k out
sbit ADCLK =P2^3;  //ADC0832 clock signal
sbit SDA = P2 ^ 1;                                //數(shù)據(jù)線
sbit SCL = P2 ^ 0;                                //時(shí)鐘線
bit bAck;                                          //應(yīng)答標(biāo)志 當(dāng)bbAck=1是為正確的應(yīng)答
unsigned char dispbitcode[8]={0xf7,0xfb,0xfd,0xfe,0xef,0xdf,0xbf,0x7f};  //位掃描
unsigned char dispcode[11]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0xff};  //共陽(yáng)數(shù)碼管字段碼
unsigned char dispbuf[4];
unsigned int temp;
unsigned char getdata; //獲取ADC轉(zhuǎn)換回來(lái)的值
void delay_1ms(void)  //12mhz delay 1.01ms
   unsigned char x,y;
   x=3;
   while(x--)
       y=40;
       while(y--);
void display(void)  //數(shù)碼管顯示函數(shù)
  char k;
  for(k=0;k<4;k++)
  P1 = dispbitcode[k];
  P0 = dispcode[dispbuf[k]];
  if(k==1)          //加上數(shù)碼管的dp小數(shù)點(diǎn)
          P0&=0x7f;
  delay_1ms();
讀ADC0832函數(shù)
//采集并返回
unsigned int Adc0832(unsigned char channel)     //AD轉(zhuǎn)換,返回結(jié)果
    unsigned char i=0;
    unsigned char j;
    unsigned int dat=0;
    unsigned char ndat=0;
    if(channel==0)channel=2;
    if(channel==1)channel=3;
    ADDI=1;
    _nop_();
    _nop_();
    ADCS=0;//拉低CS端
    _nop_();
    _nop_();
    ADCLK=1;//拉高CLK端
    _nop_();
    _nop_();
    ADCLK=0;//拉低CLK端,形成下降沿1
    _nop_();
    _nop_();
    ADCLK=1;//拉高CLK端
    ADDI=channel&0x1;
    _nop_();
    _nop_();
    ADCLK=0;//拉低CLK端,形成下降沿2
    _nop_();
    _nop_();
    ADCLK=1;//拉高CLK端
    ADDI=(channel>>1)&0x1;
    _nop_();
    _nop_();
    ADCLK=0;//拉低CLK端,形成下降沿3
    ADDI=1;//控制命令結(jié)束
    _nop_();
    _nop_();
    dat=0;
    for(i=0;i<8;i++)
        dat|=ADDO;//收數(shù)據(jù)
        ADCLK=1;
        _nop_();
        _nop_();
        ADCLK=0;//形成一次時(shí)鐘脈沖
        _nop_();
        _nop_();
        dat<<=1;
        if(i==7)dat|=ADDO;
    for(i=0;i<8;i++)
        j=0;
        j=j|ADDO;//收數(shù)據(jù)
        ADCLK=1;
        _nop_();
        _nop_();
        _nop_();
        _nop_();
        j=j<<7;
        ndat=ndat|j;
        if(i<7)ndat>>=1;
    ADCS=1;//拉低CS端
    ADCLK=0;//拉低CLK端
    ADDO=1;//拉高數(shù)據(jù)端,回到初始狀態(tài)
    dat<<=8;
    dat|=ndat;
    return(dat);            //return ad k
//啟動(dòng)I2C總線,即發(fā)送起始條件
void StartI2C()
        SDA = 1;                              //發(fā)送起始條件數(shù)據(jù)信號(hào)
        _nop_();
        SCL = 1;
        _nop_();                                    //起始建立時(shí)間大于4.7us
        _nop_();
        _nop_();
        _nop_();
        _nop_();
        SDA = 0;                              //發(fā)送起始信號(hào)
        _nop_();
        _nop_();
        _nop_();
        _nop_();
        _nop_();
        SCL = 0;                                //時(shí)鐘操作
        _nop_();
        _nop_();
//結(jié)束I2C總線,即發(fā)送I2C結(jié)束條件
void StopI2C()
        SDA = 0;                                //發(fā)送結(jié)束條件的數(shù)據(jù)信號(hào)
        _nop_();                                      //發(fā)送結(jié)束條件的時(shí)鐘信號(hào)
        SCL = 1;                                //結(jié)束條件建立時(shí)間大于4us
        _nop_();
        _nop_();
        _nop_();
        _nop_();
        _nop_();
        SDA = 1;                                //發(fā)送I2C總線結(jié)束命令
        _nop_();
        _nop_();
        _nop_();
        _nop_();
        _nop_();
//發(fā)送一個(gè)字節(jié)的數(shù)據(jù)
void        SendByte(unsigned char c)
        unsigned char BitCnt;
        for(BitCnt = 0;BitCnt < 8;BitCnt++)                                  //一個(gè)字節(jié)
                        if((c << BitCnt)& 0x80) SDA = 1;                   //判斷發(fā)送位
                        else        SDA = 0;
                        _nop_();
                        SCL = 1;                              //時(shí)鐘線為高,通知從機(jī)開(kāi)始接收數(shù)據(jù)
                        _nop_();
                        _nop_();
                        _nop_();
                        _nop_();
                        _nop_();
                        SCL = 0;
        _nop_();
        _nop_();
        SDA = 1;                                                //釋放數(shù)據(jù)線,準(zhǔn)備接受應(yīng)答位
        _nop_();
        _nop_();
        SCL = 1;
        _nop_();
        _nop_();
        _nop_();
        if(SDA == 1) bAck =0;
        else bAck = 1;                                                //判斷是否收到應(yīng)答信號(hào)
        SCL = 0;
        _nop_();
        _nop_();
//接收一個(gè)字節(jié)的數(shù)據(jù)
unsigned char RevByte()
        unsigned char retc;
        retc = 0;
        SDA = 1;
        for(BitCnt=0;BitCnt<8;BitCnt++)
                _nop_();
                SCL = 0;                                            //置時(shí)鐘線為低,準(zhǔn)備接收
                _nop_();
                _nop_();
                _nop_();
                _nop_();
                _nop_();
                SCL = 1;                                            //置時(shí)鐘線為高使得數(shù)據(jù)有效
                _nop_();
                _nop_();
                retc = retc << 1;                                    //左移補(bǔ)零
                if (SDA == 1)
                retc = retc + 1;                                     //當(dāng)數(shù)據(jù)為1則收到的數(shù)據(jù)+1
                _nop_();
                _nop_();
        SCL = 0;
        _nop_();
        _nop_();
        return(retc);                                   //返回收到的數(shù)據(jù)
//WChipAdd:寫(xiě)器件地址;RChipAdd:讀器件地址;InterAdd:內(nèi)部地址;如寫(xiě)正確則返回?cái)?shù)據(jù),
//否則返回對(duì)應(yīng)錯(cuò)誤步驟序號(hào)
//向指定器件的內(nèi)部指定地址發(fā)送一個(gè)指定字節(jié)
unsigned char WIICByte(unsigned char WChipAdd,unsigned char InterAdd,unsigned char WIICData)
        StartI2C();        //啟動(dòng)總線
        SendByte(WChipAdd);                                                        //發(fā)送器件地址以及命令
        if (bAck==1)        //收到應(yīng)答
                SendByte(InterAdd);        //發(fā)送內(nèi)部子地址
                if (bAck ==1)
                        SendByte(WIICData);                                                        //發(fā)送數(shù)據(jù)
                        if(bAck == 1)
                                StopI2C();                    //停止總線
                                return(0xff);
                                return(0x03);
                        return(0x02);
        return(0x01);
//讀取指定器件的內(nèi)部指定地址一個(gè)字節(jié)數(shù)據(jù)
unsigned char RIICByte(unsigned char WChipAdd,unsigned char RChipAdd,unsigned char InterDataAdd)
        unsigned char TempData;
        TempData = 0;
        SendByte(WChipAdd);                                                    //發(fā)送器件地址以及讀命令
                SendByte(InterDataAdd);                                        //發(fā)送內(nèi)部子地址
                if (bAck ==1)
                        StartI2C();
                        SendByte(RChipAdd);
                        if(bAck == 1)
                                TempData = RevByte();       //接收數(shù)據(jù)
                                StopI2C();                  //停止I2C總線
                                return(TempData);           //返回?cái)?shù)據(jù)
                                return(0x03);
                        return(0x02);
                return(0x01);
void main(void)
  unsigned int OverCounter = 0;
  unsigned char ptemp;
  bit OverFlg = 0;
  unsigned int temp,ppress = 0;
  float  press;
          getdata=Adc0832(0);
          if(14<getdata<243)                                       //當(dāng)壓力值介于15kpa到115kpa之間時(shí),遵循線性變換
                  int vary=getdata;                                                //y=(115-15)/(243-13)*X+15kpa
                        press=((10.0/23.0)*vary)+9.3;                        //測(cè)試時(shí)補(bǔ)償值為9.3
                        temp=(int)(press*10);                  //放大10倍,便于后面的計(jì)算
      if(temp != ppress)
        ppress = temp;
        OverFlg = 1;
                        dispbuf[3]=temp/1000;                                     //取壓力值百位
                        dispbuf[2]=(temp%1000)/100;                            //取壓力值十位
                        dispbuf[1]=((temp%1000)%100)/10;                    //取壓力值個(gè)位
                        dispbuf[0]=((temp%1000)%100)%10;                        //取壓力值十分位
                        display();
      if (temp > 100)
          if(OverFlg == 1)    //如果是新的一輛車(chē)通過(guò)
            OverCounter++;
            WIICByte(W24C04ADD,0x01,(OverCounter/0xff));    //低位
            WIICByte(W24C04ADD,0x02,(OverCounter%0xff));    //高位
//            ptemp = printf("%f\n",OverCounter);
            OverFlg = 0;    //清除標(biāo)志
Keil代碼與Proteus8.8仿真下載:
貨車(chē)超重監(jiān)測(cè)系統(tǒng).7z (59.29 KB, 下載次數(shù): 56)
ID:699631 發(fā)表于 2020-2-29 15:58 | 只看該作者
需要用Proteus8.8打開(kāi)
ID:720166 發(fā)表于 2020-4-1 14:09 | 只看該作者
好資料,51黑有你更精彩!!!
