2019-5-9 17:16 上傳
- #include <AT89X52.H>
- unsigned char code dispbit[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f}; //P2的掃描位
- unsigned char code dispcode[]={0x3f,0x06,0x5b,0x4f,0x66,
- 0x6d,0x7d,0x07,0x7f,0x6f,0x00,0x40}; //數(shù)碼管的字形編碼
- unsigned char dispbuf[8]={0,0,0,0,0,0,10,10}; //初始化顯示值
- unsigned char temp[8]; //存放顯示的數(shù)據(jù)
- unsigned char dispcount; //顯示計數(shù)器值
- unsigned char T0count; //T0的計數(shù)器值
- unsigned char timecount; //計時計數(shù)器值
- bit flag; //標(biāo)志位
- unsigned long x; //頻率值
- //頻率計算函數(shù)
- void HzCal(void)
- unsigned char i;
- x=T0count*65536+TH0*256+TL0; //得到T0的16位計數(shù)器值
- for(i=0;i<8;i++)
- temp[i]=0;
- i=0;
- while(x/10) //拆分
- temp[i]=x%10;
- x=x/10;
- i++;
- temp[i]=x;
- for(i=0;i<6;i++) //換算為顯示數(shù)據(jù)
- dispbuf[i]=temp[i];
- timecount=0;
- T0count=0;
- void main(void)
- TMOD=0x15; //設(shè)置定時器工作方式
- TH0=0;
- TL0=0;
- TH1=(65536-5000)/256;
- TL1=(65536-5000)%256; //初始化T1
- TR1=1;
- TR0=1;
- ET0=1;
- ET1=1;
- EA=1; //開中斷
- while(1)
- if(flag==1)
- flag=0;
- HzCal(); //頻率計算函數(shù)
- TH0=0;
- TL0=0;
- TR0=1;
- //定時器T0中斷服務(wù)子函數(shù)
- void t0(void) interrupt 1 using 0
- T0count++;
- //定時器T1中斷服務(wù)子函數(shù)
- void t1(void) interrupt 3 using 0
- TL1=(65536-5000)%256; //初始化T1預(yù)裝值,1ms定時
- timecount++; //掃描
- if(timecount==200) //秒定時
- TR0=0; //啟動T0
- timecount=0;
- flag=1;
- P2=0xff; //初始化選擇引腳
- P0=dispcode[dispbuf[dispcount]]; //輸出待顯示數(shù)據(jù)
- P2=dispbit[dispcount];
- dispcount++; //切換到下一個選擇引腳
- if(dispcount==8) //如果已經(jīng)掃描完成切換
- dispcount=0;
基于51單片機(jī)和Proteus仿真的簡易頻率計.zip
(55.02 KB, 下載次數(shù): 123)
2019-5-9 17:16 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
