查看: 1144|回復(fù): 0
基于51單片機(jī)的24L01無線模塊設(shè)計(jì)
ID:517871 發(fā)表于 2019-5-9 19:22 | 只看該作者 回帖獎勵 |倒序?yàn)g覽 |閱讀模式
#include <reg52.h>
#include <ABSACC.h>
#include <intrins.h>
#include <stdio.h>
#define BYTE_BIT0        0x01
#define BYTE_BIT7        0x80
bdata unsigned  char DATA_BUF;
#define DATA7        ((DATA_BUF&BYTE_BIT7) != 0)
#define DATA0   ((DATA_BUF&BYTE_BIT0) != 0)
sbit        flag        =DATA_BUF^7;
sbit        flag1        =DATA_BUF^0;
//---------------------------------------------------發(fā)送數(shù)據(jù)緩沖區(qū)-------------------------------------------------
#define TxRxBuf_Len 4
unsigned char TxRxBuf[TxRxBuf_Len]={0x29,0x30,0x31,0x32,};
code TxAddress[4]={0xcc,0xcc,0xcc,0xcc};
char tf;
//----------------------------------------NRF905工作模式控制端口------------------------------------------------------
sbit        TXEN=P1^0;
sbit        TRX_CE=P3^2;
sbit        PWR=P1^1;
//----------------------------------------LED顯示端口---------------------------------------------------
sbit    LED=P2^3; //蜂鳴器
//----------------------------------------NRF905 數(shù)據(jù)交換端口---------------------------------------------------
sbit        MISO=P1^6;
sbit        MOSI=P1^5;
sbit        SCK=P1^7;
sbit        CSN=P1^3;
//----------------------------------------nrf905狀態(tài)端口---------------------------------------------------------
sbit        AM=P1^4;
sbit        DR=P3^3;
sbit        CD=P1^2;
//----------------------------------------按鍵端口-------------------------------------------------------
sbit        KEY=P3^4;  //BST-V51開發(fā)板上最下角第一個按鍵
//----------------------------------------nrf905控制指令-------------------------------------------
#define WC                0x00
#define RC                0x10
#define WTP                0x20
#define RTP                0x21
#define WTA                0x22
#define RTA                0x23
#define RRP                0x24
//------------------------------------------------NRF905寄存器配置------------------------------------------------
unsigned char idata RFConf[11]=
  0x00,                             //配置命令//
  0x4c,                             //CH_NO,配置頻段在430MHZ
  0x0c,                             //輸出功率為10db,不重發(fā),節(jié)電為正常模式
  0x44,                             //地址寬度設(shè)置,為4字節(jié)
  0x04,0x04,                        //接收發(fā)送有效數(shù)據(jù)長度為4字節(jié)
  0xCC,0xCC,0xCC,0xCC,              //接收地址
  0x58,                              //CRC充許,8位CRC校驗(yàn),外部時(shí)鐘信號不使能,16M晶振
//================================================延時(shí)===========================================================
void nrf905_Delay(int n)
        uint i;
        while(n--)
        for(i=0;i<80;i++);
//=================================================SPI讀函數(shù)=======================================================
unsigned char SpiRead(void)
        unsigned char j;
        for (j=0;j<8;j++)
        DATA_BUF=DATA_BUF<<1;
                SCK=1;
                if (MISO)        //讀取最高位,保存至最末尾,通過左移位完成整個字節(jié)
                        DATA_BUF|=BYTE_BIT0;
                        DATA_BUF&=~BYTE_BIT0;
                SCK=0;
         return DATA_BUF;
//===========================================SPI寫函數(shù)===============================================================
void SpiWrite(unsigned char send)
        unsigned char i;
        DATA_BUF=send;
        for (i=0;i<8;i++)
                if (DATA7)        //總是發(fā)送最高位
                        MOSI=1;
                        MOSI=0;
                SCK=1;
                SCK=0;
//------------------------------------------------------初始化nRF905---------------------------------------------
void nRF905Init(void)
    CSN=1;                                                // Spi         disable
        SCK=0;                                                // Spi clock line init low
        DR=1;                                                // Init DR for input
        AM=1;                                                // Init AM for input
        CD=1;                                                // Init CD for input
        PWR=1;                                        // nRF905 power on
        TRX_CE=0;                                        // Set nRF905 in standby mode
        TXEN=0;                                        // set radio in Rx mode
//-----------------------------------------------------初始化寄存器-----------------------------------------------
void Config905(void)
        uchar i;
        CSN=0;                                                // Spi enable for write a spi command
        //SpiWrite(WC);                                // Write config command寫放配置命令
        for (i=0;i<11;i++)        // Write configration words  寫放配置字
           SpiWrite(RFConf[i]);
        CSN=1;                                        // Disable Spi
//-----------------------------------------------------發(fā)送數(shù)據(jù)打包---------------------------------------------------
void TxPacket(uchar *TxRxBuf)
        uchar i;
        //Config905();
        CSN=0;
        SpiWrite(WTP);                                // Write payload command
        for (i=0;i<4;i++)
                SpiWrite(TxRxBuf[i]);                // Write 32 bytes Tx data
        CSN=1;
        nrf905_Delay(1);                                                // Spi disable
        SpiWrite(WTA);                                // Write address command
        for (i=0;i<4;i++)                        // 寫入與對方地址一樣的地址
                SpiWrite(TxAddress[i]);
        TRX_CE=1;                                        // Set TRX_CE high,start Tx data transmission
        nrf905_Delay(1);                                        // while (DR!=1);
        TRX_CE=0;                                        // Set TRX_CE low
//----------------------------------------------設(shè)置發(fā)送初始狀態(tài)---------------------------------------------
void SetTxMode(void)
        TRX_CE=0;
        TXEN=1;
        nrf905_Delay(1);                                         // nrf905_Delay for mode change(>=650us)
//-----------------------------------------------設(shè)置接收初始化---------------------------------------------------
void SetRxMode(void)
        TXEN=0;
        TRX_CE=1;
//-------------------------------------------------判斷數(shù)據(jù)接收狀態(tài)-----------------------------------------------------
unsigned char CheckDR(void)                //檢查是否有新數(shù)據(jù)傳入 Data Ready
        DR=1;
//通過對端口寫1,可以使端口為輸入狀態(tài),這51的 特性。不熟悉者可以參閱51相關(guān)書籍作證(將DR端口設(shè)置為輸入狀態(tài)。)
        if (DR==1)
                DR=0;
                return 1;
                return 0;
//----------------------------------------------------讀NRF905接收數(shù)據(jù)------------------------------------------------------------
void RxPacket(void)
        uchar i;
    nrf905_Delay(1);
//        TRX_CE=0;                                        // Set nRF905 in standby mode
    nrf905_Delay(100);
    TRX_CE=0;
    nrf905_Delay(1);
        SpiWrite(RRP);
        for (i = 0 ;i < 4 ;i++)
                TxRxBuf[i]=SpiRead();                // Read data and save to buffer
        CSN=1;
    nrf905_Delay(10);
        TRX_CE=1;
//--------------------------------------------------------數(shù)據(jù)接收------------------------------------------------
void  RX(void)
          SetRxMode();
        //  while (CheckDR()==0);  為了實(shí)現(xiàn)雙向通信,就不能一直處于接收等待狀態(tài),所以注釋掉
                  nrf905_Delay(10);
                    RxPacket();
                  if(TxRxBuf[0]==0x29)
                                  LED=0;
                            nrf905_Delay(300);
                                LED=1;
                            nrf905_Delay(300);//接收到數(shù)據(jù) 后閃爍
void main(void)
        nRF905Init();
             Config905();
                LED=1;
                        RX();
                   if(KEY ==0 )
                                 while(KEY==0);
                                tf = 1 ;
                                TxRxBuf[0]=0x29;
               if (tf==1)
                SetTxMode();
                            TxPacket(TxRxBuf);        // 發(fā)送命令數(shù)據(jù)
                                  LED=0;
                            nrf905_Delay(300);
                                LED=1;
                            nrf905_Delay(300);                        //發(fā)送后蜂鳴器響一下
                                tf = 0;
基于51單片機(jī)的24L01無線模塊設(shè)計(jì).zip
777.96 KB, 下載次數(shù): 4, 下載積分: 黑幣 -5
