#include<reg52.h> //包含單片機(jī)寄存器的頭文件
sbit led1=P1^0;
sbit led2=P1^2;
sbit led5=P1^5;
sbit du=P2^6;//段選
sbit we=P2^7;//位選
sbit s1=P3^4;
sbit s2=P3^5;
sbit s3=P3^6;
sbit s4=P3^7;
sbit beep=P2^3;
sbit dot=P0^7;
unsigned char shi,fen,miao,unit,keyv,key,av,ashi,afen,amiao;
void delay() //1ms
unsigned char a,b;
for(b=102;b>0;b--)
for(a=3;a>0;a--);
void delay5(void) //誤差 5ms
unsigned char a,b;
for(b=15;b>0;b--)
for(a=152;a>0;a--);
void delayhalf (void) //誤差 0.5s
unsigned char a,b,c;
for(c=23;c>0;c--)
for(b=152;b>0;b--)
for(a=70;a>0;a--);
void display( unsigned char h,f,s)
unsigned char code duma[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x38};
unsigned char code mawei[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
unsigned char shiwan,wan,qian,bai,shi,ge;
shiwan=h/10;
wan=h%10;
qian=f/10;
bai=f%10;
shi=s/10;
ge=s%10;
P0=duma[shiwan];
du=1;
du=0;
P0=mawei[0];
we=1;
we=0;
delay();
P0=duma[wan];
dot=1;
du=1;
du=0;
dot=0;
P0=mawei[1];
we=1;
we=0;
delay();
P0=duma[qian];
du=1;
du=0;
P0=mawei[2];
we=1;
we=0;
delay();
P0=duma[bai];
dot=1;
du=1;
du=0;
dot=0;
P0=mawei[3];
we=1;
we=0;
delay();
if(key!=1&&key!=2)
P0=duma[shi];
du=1;
du=0;
P0=mawei[4];
we=1;
we=0;
delay();
P0=duma[ge];
du=1;
du=0;
P0=mawei[5];
we=1;
we=0;
delay();
if(key==1||key==2)//
P0=duma[10];
du=1;
du=0;
P0=mawei[4];
we=1;
we=0;
delay();
P0=duma[11];
du=1;
du=0;
P0=mawei[5];
we=1;
we=0;
delay();
P0=0xff;
we=1;
we=0;
passtime()
if(unit==100)
miao++;
unit=0;
led1=!led1;
led2=!led2;
if(miao==60)
fen++;
miao=0;
if(fen==60)
shi++;
fen=0;
if(shi==24)
shi=0;
void InitTimer0(void)//10ms
TMOD = 0x01;
TH0 = 0x0DC;
TL0 = 0x00;
EA = 1;
ET0 = 1;
TR0 = 1;
unit=0;
void Timer0Interrupt(void) interrupt 1
TH0 = 0x0DC;
TL0 = 0x00;
unit++ ;//add your code here!
passtime();
void adjustment(void)
if(s1==0)
delay5();
if(s1==0)
while(!s1);
amiao=0;
key++;
led5=0;
if(key==5)
key=0;
TR0=1;
led5=1;
}//////s1 count
if(s2==0)
delay5();
if(s2==0)
while(!s2);
if(key==1)//alram
ashi++;
if(ashi==24)
ashi=0;
if(key==2)
afen++;
if(afen==60)
afen=0;
}//alram
if(key==4)/////
miao=0;
TR0=0;
fen++;
if(fen==60)
fen=0;
if(key==3)///
miao=0;
TR0=0;
shi++;
if(shi==24)
shi=0;
}//adj +
///////////////////adj-
if(s3==0)
delay5();
if(s3==0)
while(!s3);
if(key==1)//alram
ashi--;
if(ashi==-1)
ashi=23;
if(key==2)
afen--;
if(afen==-1)
afen=59;
}//alram
if(key==4)//
miao=0;
TR0=0;
fen--;
if(fen==-1)
fen=59;
if(key==3)///
miao=0;
TR0=0;
shi--;
if(shi==-1)
shi=23;
}//adj -
void alarm(void)
if(fen!=afen)
av=0;
if(av==0)
if(shi==ashi&&fen==afen)
beep=0;
delayhalf();
beep=1;
delayhalf();
beep=0;
delayhalf();
beep=1;
delayhalf();
}//av==0
主函數(shù) 編程: 火星人 qq:1170675125 學(xué)習(xí)板HL-1用
void main(void)
{ashi=7;afen=0;
InitTimer0();
led2=0;
if(keyv==0)//close display
if(s4==0)
delay5();
if(s4==0)
while(!s4);
keyv=1;
av=1;
if(keyv==1)
if(s4==0)
delay5();
if(s4==0)
while(!s4);
keyv=0;
}//close display
if(keyv==0)
adjustment();
if(key!=1&&key!=2)
display(shi,fen,miao);
if(key==1||key==2)
display(ashi,afen,amiao);
if(key==0||key==3||key==4)
alarm();
}//while
