#include<reg52.h>
uchar a,miao,shi,fen,ri,yue,nian,week,flag,temp,key1n;
#define yh 0x80 //第一行的初始位置
#define er 0x80+0x40 //第二行初始位置
//sbit cs1=P3^7;
//sbit ledk=P2^5;
sbit dula=P2^6;
sbit wela=P2^7;
sbit wr=P1^1;
sbit rs=P1^0;
sbit en=P2^5;
sbit SCLK=P2^1; // 6 P1.1
sbit IO=P2^0; // 7 P1.0
sbit RST=P2^4; //時(shí)鐘 5 P1.2
sbit ACC0=ACC^0;
sbit ACC7=ACC^7;
sbit key=P3^7;
sbit key1=P3^0;
sbit key2=P3^1;
sbit key3=P3^2;
uchar code tab1[]={"2009- - THU"};
uchar code tab2[]={" : : "};
void delay(uint xms)//延時(shí)函數(shù)
uint x,y;
for(x=xms;x>0;x--)
for(y=110;y>0;y--);
/******************液晶寫(xiě)入************************/
write_1602com(uchar com)//液晶寫(xiě)入指令函數(shù)
rs=0;//置為寫(xiě)入命令
P0=com;//送入數(shù)據(jù)
delay(1);
en=1;//拉高使能端
delay(1);
en=0;//完成高脈沖
write_1602dat(uchar dat)
rs=1;//置為寫(xiě)入數(shù)據(jù)
P0=dat;//送入數(shù)據(jù)
delay(1);
en=1;
delay(1);
en=0;
/*********************over***********************/
/********************ds1302****************************/
void write_byte(uchar dat)
ACC=dat;
RST=1;
for(a=8;a>0;a--)
IO=ACC0;
SCLK=0;
SCLK=1;
ACC=ACC>>1;
uchar read_byte()
RST=1;
for(a=8;a>0;a--)
ACC7=IO;
SCLK=1;
SCLK=0;
ACC=ACC>>1;
return (ACC);
void write_1302(uchar add,uchar dat)
RST=0;
SCLK=0;
RST=1;
write_byte(add);
write_byte(dat);
SCLK=1;
RST=0;
uchar read_1302(uchar add)
uchar temp;
RST=0;
SCLK=0;
RST=1;
write_byte(add);
temp=read_byte();
SCLK=1;
RST=0;
return(temp);
uchar BCD_Decimal(uchar bcd)
uchar Decimal;
Decimal=bcd>>4;
return(Decimal=Decimal*10+(bcd&=0x0F));
void ds1302_init()
RST=0;
SCLK=0;
write_1302(0x80,miao|0x00);//允許寫(xiě)
void write_sfm(uchar add,uchar dat)//寫(xiě)時(shí)分秒
uchar gw,sw;
gw=dat%10;
sw=dat/10;
write_1602com(er+add);
write_1602dat(0x30+sw);
write_1602dat(0x30+gw);
void write_nyr(uchar add,uchar dat)
uchar gw,sw;
gw=dat%10;
sw=dat/10;
write_1602com(yh+add);
void write_week(uchar week)//寫(xiě)星期函數(shù)
write_1602com(yh+0x0d);
switch(week)
case 1:write_1602dat('M');//delay(5);
write_1602dat('O');//delay(5);
write_1602dat('N');
break;
case 2:write_1602dat('T');//delay(5);
write_1602dat('U');//delay(5);
write_1602dat('E');
break;
case 3:write_1602dat('W');//delay(5);
write_1602dat('E');//delay(5);
write_1602dat('D');
break;
case 4:write_1602dat('T');//delay(5);
write_1602dat('H');//delay(5);
write_1602dat('U');
break;
case 5:write_1602dat('F');//delay(5);
write_1602dat('R');//delay(5);
write_1602dat('I');
break;
case 6:write_1602dat('S');//delay(5);
write_1602dat('A');
break;
case 7:write_1602dat('S');//delay(5);
write_1602dat('N');
break;
lcd_init()//液晶初始化函數(shù)
{ wr=0;
write_1602com(0x38);//設(shè)置液晶工作模式
write_1602com(0x0c);//開(kāi)顯示不顯示光標(biāo)
write_1602com(0x06);//整屏不移動(dòng),指針加一
write_1602com(0x01);
write_1602com(yh+2);//字符寫(xiě)入的位置
for(a=0;a<14;a++)
write_1602dat(tab1[a]);
//delay(3);
write_1602com(er+4);
for(a=0;a<8;a++)
write_1602dat(tab2[a]);
//delay(3);
void keyscan()
key=0;
if(key1==0)//key1為功能鍵
delay(5);
if(key1==0)
while(!key1);
key1n++;
if(key1n==9)
key1n=1;
switch(key1n)
case 1: TR0=0;//關(guān)閉定時(shí)器
//TR1=0;
write_1602com(er+0x0b);//寫(xiě)入光標(biāo)位置
write_1602com(0x0f);//設(shè)置光標(biāo)為閃爍
temp=(miao)/10*16+(miao)%10;
write_1302(0x8e,0x00);
write_1302(0x80,0x80|temp);//miao
write_1302(0x8e,0x80);
break;
case 2: write_1602com(er+8);//fen
//write_1602com(0x0f);
break;
case 3: write_1602com(er+5);//shi
break;
case 4: write_1602com(yh+0x0f);//week
break;
case 5: write_1602com(yh+0x0b);//ri
break;
case 6: write_1602com(yh+0x08);//yue
break;
case 7: write_1602com(yh+0x05);//nian
break;
case 8:
write_1602com(0x0c);//設(shè)置光標(biāo)不閃爍
TR0=1;//打開(kāi)定時(shí)器
write_1302(0x80,0x00|temp);//miao
break;
if(key1n!=0)//當(dāng)key1按下以下。再按以下鍵才有效
if(key2==0) //上調(diào)鍵
delay(5);
if(key2==0)
while(!key2);
switch(key1n)
case 1:miao++;
if(miao==60)
miao=0;
write_sfm(0x0a,miao);//寫(xiě)入新的秒數(shù)
write_1602com(er+0x0b);//因?yàn)樵O(shè)置液晶的模式是寫(xiě)入數(shù)據(jù)后,指針自動(dòng)加一,在這里是寫(xiě)回原來(lái)的位置
//write_1602com(0x0b);
break;
case 2:fen++;
if(fen==60)
fen=0;
write_sfm(0x07,fen);
temp=(fen)/10*16+(fen)%10;
write_1302(0x82,temp);
break;
case 3:shi++;
if(shi==24)
shi=0;
write_sfm(4,shi);
temp=(shi)/10*16+(shi)%10;
write_1302(0x84,temp);
break;
case 4:week++;
if(week==8)
week=0;
write_week(week);
break;
case 5:ri++;
if(ri==31)
ri=0;
write_nyr(10,ri);
temp=(ri)/10*16+(ri)%10;
write_1302(0x86,temp);
write_1602com(yh+11);
break;
case 6:yue++;
if(yue==13)
yue=0;
write_nyr(7,yue);
temp=(yue)/10*16+(yue)%10;
write_1302(0x88,temp);
write_1602com(yh+8);
break;
case 7:nian++;
if(nian==100)
nian=0;
write_nyr(4,nian);
write_1602com(yh+5);
break;
if(key3==0)
delay(5);
if(key3==0)
while(!key3);
switch(key1n)
case 1:miao--;
if(miao==-1)
miao=59;
break;
case 2:fen--;
if(fen==-1)
fen=59;
write_sfm(7,fen);
break;
case 3:shi--;
if(shi==-1)
shi=23;
write_sfm(4,shi);
break;
case 4:week--;
if(week==-1)
week=7;
write_week(week);
break;
case 5:ri--;
if(ri==-1)
ri=30;
write_nyr(10,ri);
break;
case 6:yue--;
if(yue==-1)
yue=12;
write_nyr(7,yue);
break;
case 7:nian--;
if(nian==-1)
nian=99;
write_nyr(4,nian);
break;
void init()
TMOD=0x11;
TH0=0;
TL0=0;
EA=1;
ET0=1;
TR0=1;
void cmg(void)//數(shù)碼管鎖存函數(shù)
dula=1;
P0=0x00;
dula=0;
wela=1;
P0=0x00;
wela=0;
cmg();//數(shù)碼管鎖存
lcd_init();
ds1302_init();
init();
//TH0=(65536-60000)/256;
//TL0=(65536-60000)%256;
keyscan();
void timer0() interrupt 1
miao = BCD_Decimal(read_1302(0x81));
fen = BCD_Decimal(read_1302(0x83));
shi = BCD_Decimal(read_1302(0x85));
ri = BCD_Decimal(read_1302(0x87));
yue = BCD_Decimal(read_1302(0x89));
nian=BCD_Decimal(read_1302(0x8d));
week=BCD_Decimal(read_1302(0x8b));
//keyscan();
write_sfm(10,miao);
//write_1602com(er+0x0a);
//write_1602dat(':');
write_sfm(7,fen);
//write_1602com(er+0x07);
write_sfm(4,shi);
//write_nyr(4,nian);
write_nyr(10,ri);
write_nyr(7,yue);
//write_week(week);
