- #include <REG51.H>
- #include <math.h> //Keil library
- #include <stdio.h> //Keil library
- #include <INTRINS.H>
- #define uchar unsigned char
- #define uint unsigned int
- #define DataPort P0 //LCD1602數(shù)據(jù)端口
- sbit SCL=P1^2; //IIC時(shí)鐘引腳定義
- sbit SDA=P1^3; //IIC數(shù)據(jù)引腳定義
- sbit LCM_RS=P1^0; //LCD1602命令端口
- sbit LCM_RW=P1^1; //LCD1602命令端口
- sbit LCM_EN=P2^5; //LCD1602命令端口
- #define SlaveAddress 0xA6 //定義器件在IIC總線中的從地址,根據(jù)ALT ADDRESS地址引腳不同修改
- //ALT ADDRESS引腳接地時(shí)地址為0xA6,接電源時(shí)地址為0x3A
- typedef unsigned char BYTE;
- typedef unsigned short WORD;
- BYTE BUF[8]; //接收數(shù)據(jù)緩存區(qū)
- uchar ge,shi,bai,qian,wan; //顯示變量
- int dis_data; //變量
- int data_xyz[3];
- void delay(unsigned int k);
- void InitLcd(); //初始化lcd1602
- void Init_ADXL345(void); //初始化ADXL345
- void WriteDataLCM(uchar dataW);
- void WriteCommandLCM(uchar CMD,uchar Attribc);
- void DisplayOneChar(uchar X,uchar Y,uchar DData);
- void conversion(uint temp_data);
- void Single_Write_ADXL345(uchar REG_Address,uchar REG_data); //單個(gè)寫(xiě)入數(shù)據(jù)
- uchar Single_Read_ADXL345(uchar REG_Address); //單個(gè)讀取內(nèi)部寄存器數(shù)據(jù)
- void Multiple_Read_ADXL345(); //連續(xù)的讀取內(nèi)部寄存器數(shù)據(jù)
- void Delay5us();
- void Delay5ms();
- void ADXL345_Start();
- void ADXL345_Stop();
- void ADXL345_SendACK(bit ack);
- bit ADXL345_RecvACK();
- void ADXL345_SendByte(BYTE dat);
- BYTE ADXL345_RecvByte();
- void ADXL345_ReadPage();
- void ADXL345_WritePage();
- wan=temp_data/10000+0x30 ;
- temp_data=temp_data%10000; //取余運(yùn)算
- qian=temp_data/1000+0x30 ;
- temp_data=temp_data%1000; //取余運(yùn)算
- bai=temp_data/100+0x30 ;
- temp_data=temp_data%100; //取余運(yùn)算
- shi=temp_data/10+0x30 ;
- temp_data=temp_data%10; //取余運(yùn)算
- ge=temp_data+0x30;
- unsigned int i,j;
- for(i=0;i<k;i++)
- for(j=0;j<121;j++)
- void WaitForEnable(void)
- DataPort=0xff;
- LCM_RS=0;LCM_RW=1;_nop_();
- LCM_EN=1;_nop_();_nop_();
- while(DataPort&0x80);
- LCM_EN=0;
- if(Attribc)WaitForEnable();
- LCM_RS=0;LCM_RW=0;_nop_();
- DataPort=CMD;_nop_();
- LCM_EN=1;_nop_();_nop_();LCM_EN=0;
- WaitForEnable();
- LCM_RS=1;LCM_RW=0;_nop_();
- DataPort=dataW;_nop_();
- void InitLcd() //液晶顯示器的設(shè)置
- WriteCommandLCM(0x38,1);
- WriteCommandLCM(0x08,1);
- WriteCommandLCM(0x01,1);
- WriteCommandLCM(0x06,1);
- WriteCommandLCM(0x0c,1);
- Y&=1;
- X&=15;
- if(Y)X|=0x40;
- X|=0x80;
- WriteCommandLCM(X,0);
- WriteDataLCM(DData);
- 延時(shí)5微秒(STC90C52RC@12M)
- 不同的工作環(huán)境,需要調(diào)整此函數(shù),注意時(shí)鐘過(guò)快時(shí)需要修改
- 當(dāng)改用1T的MCU時(shí),請(qǐng)調(diào)整此延時(shí)函數(shù)
- void Delay5us()
- _nop_();_nop_();_nop_();_nop_();
- 延時(shí)5毫秒(STC90C52RC@12M)
- void Delay5ms()
- WORD n = 560;
- while (n--);
- 起始信號(hào)
- SDA = 1; //拉高數(shù)據(jù)線
- SCL = 1; //拉高時(shí)鐘線
- Delay5us(); //延時(shí)
- SDA = 0; //產(chǎn)生下降沿
- SCL = 0; //拉低時(shí)鐘線
- 停止信號(hào)
- SDA = 0; //拉低數(shù)據(jù)線
- SDA = 1; //產(chǎn)生上升沿
- 發(fā)送應(yīng)答信號(hào)
- 入口參數(shù):ack (0:ACK 1:NAK)
- SDA = ack; //寫(xiě)應(yīng)答信號(hào)
- 接收應(yīng)答信號(hào)
- CY = SDA; //讀應(yīng)答信號(hào)
- return CY;
- 向IIC總線發(fā)送一個(gè)字節(jié)數(shù)據(jù)
- BYTE i;
- for (i=0; i<8; i++) //8位計(jì)數(shù)器
- dat <<= 1; //移出數(shù)據(jù)的最高位
- SDA = CY; //送數(shù)據(jù)口
- ADXL345_RecvACK();
- 從IIC總線接收一個(gè)字節(jié)數(shù)據(jù)
- BYTE i;
- BYTE dat = 0;
- SDA = 1; //使能內(nèi)部上拉,準(zhǔn)備讀取數(shù)據(jù),
- dat <<= 1;
- dat |= SDA; //讀數(shù)據(jù)
- return dat;
- //******單字節(jié)寫(xiě)入*******************************************
- ADXL345_Start(); //起始信號(hào)
- ADXL345_SendByte(SlaveAddress); //發(fā)送設(shè)備地址+寫(xiě)信號(hào)
- ADXL345_SendByte(REG_Address); //內(nèi)部寄存器地址,請(qǐng)參考中文pdf22頁(yè)
- ADXL345_SendByte(REG_data); //內(nèi)部寄存器數(shù)據(jù),請(qǐng)參考中文pdf22頁(yè)
- ADXL345_Stop(); //發(fā)送停止信號(hào)
- //********單字節(jié)讀取*****************************************
- { uchar REG_data;
- ADXL345_SendByte(REG_Address); //發(fā)送存儲(chǔ)單元地址,從0開(kāi)始
- ADXL345_SendByte(SlaveAddress+1); //發(fā)送設(shè)備地址+讀信號(hào)
- REG_data=ADXL345_RecvByte(); //讀出寄存器數(shù)據(jù)
- ADXL345_SendACK(1);
- ADXL345_Stop(); //停止信號(hào)
- return REG_data;
- //連續(xù)讀出ADXL345內(nèi)部加速度數(shù)據(jù),地址范圍0x32~0x37
- void Multiple_read_ADXL345(void)
- { uchar i;
- ADXL345_SendByte(0x32); //發(fā)送存儲(chǔ)單元地址,從0x32開(kāi)始
- for (i=0; i<6; i++) //連續(xù)讀取6個(gè)地址數(shù)據(jù),存儲(chǔ)中BUF
- BUF[i] = ADXL345_RecvByte(); //BUF[0]存儲(chǔ)0x32地址中的數(shù)據(jù)
- if (i == 5)
- ADXL345_SendACK(1); //最后一個(gè)數(shù)據(jù)需要回NOACK
- else
- ADXL345_SendACK(0); //回應(yīng)ACK
- Delay5ms();
- //初始化ADXL345,根據(jù)需要請(qǐng)參考pdf進(jìn)行修改************************
- void Init_ADXL345()
- Single_Write_ADXL345(0x31,0x0B); //測(cè)量范圍,正負(fù)16g,13位模式
- Single_Write_ADXL345(0x2C,0x08); //速率設(shè)定為12.5 參考pdf13頁(yè)
- Single_Write_ADXL345(0x2D,0x08); //選擇電源模式 參考pdf24頁(yè)
- Single_Write_ADXL345(0x2E,0x80); //使能 DATA_READY 中斷
- Single_Write_ADXL345(0x1E,0x00); //X 偏移量 根據(jù)測(cè)試傳感器的狀態(tài)寫(xiě)入pdf29頁(yè)
- Single_Write_ADXL345(0x1F,0x00); //Y 偏移量 根據(jù)測(cè)試傳感器的狀態(tài)寫(xiě)入pdf29頁(yè)
- Single_Write_ADXL345(0x20,0x05); //Z 偏移量 根據(jù)測(cè)試傳感器的狀態(tài)寫(xiě)入pdf29頁(yè)
- //顯示x軸
- void display_x()
- { float temp;
- dis_data=(BUF[1]<<8)+BUF[0]; //合成數(shù)據(jù)
- if(dis_data<0){
- dis_data=-dis_data;
- DisplayOneChar(2,0,'-'); //顯示正負(fù)符號(hào)位
- else DisplayOneChar(2,0,' '); //顯示空格
- temp=(float)dis_data*3.9; //計(jì)算數(shù)據(jù)和顯示,查考ADXL345快速入門(mén)第4頁(yè)
- conversion(temp); //轉(zhuǎn)換出顯示需要的數(shù)據(jù)
- DisplayOneChar(0,0,'X'); //第0行,第0列 顯示X
- DisplayOneChar(1,0,':');
- DisplayOneChar(3,0,qian);
- DisplayOneChar(4,0,'.');
- DisplayOneChar(5,0,bai);
- DisplayOneChar(6,0,shi);
- DisplayOneChar(7,0,'g');
- //顯示y軸
- void display_y()
- { float temp;
- dis_data=(BUF[3]<<8)+BUF[2]; //合成數(shù)據(jù)
- if(dis_data<0){
- DisplayOneChar(2,1,'-'); //顯示正負(fù)符號(hào)位
- else DisplayOneChar(2,1,' '); //顯示空格
- DisplayOneChar(0,1,'Y'); //第1行,第0列 顯示y
- DisplayOneChar(1,1,':');
- DisplayOneChar(3,1,qian);
- DisplayOneChar(4,1,'.');
- DisplayOneChar(5,1,bai);
- DisplayOneChar(6,1,shi);
- DisplayOneChar(7,1,'g');
- //顯示z軸
- void display_z()
- { float temp;
- dis_data=(BUF[5]<<8)+BUF[4]; //合成數(shù)據(jù)
- if(dis_data<0){
- DisplayOneChar(10,1,'-'); //顯示負(fù)符號(hào)位
- else DisplayOneChar(10,1,' '); //顯示空格
- DisplayOneChar(10,0,'Z'); //第0行,第10列 顯示Z
- DisplayOneChar(11,0,':');
- DisplayOneChar(11,1,qian);
- DisplayOneChar(12,1,'.');
- DisplayOneChar(13,1,bai);
- DisplayOneChar(14,1,shi);
- DisplayOneChar(15,1,'g');
- //******主程序********
- void main()
- uchar devid;
- float Roll,Pitch,Q,T,K;
- delay(500); //上電延時(shí)
- InitLcd(); //液晶初始化ADXL345
- Init_ADXL345(); //初始化ADXL345
- devid=Single_Read_ADXL345(0X00);//讀出的數(shù)據(jù)為0XE5,表示正確
- while(1) //循環(huán)
- Multiple_Read_ADXL345(); //連續(xù)讀出數(shù)據(jù),存儲(chǔ)在BUF中
- data_xyz[0]=(BUF[1]<<8)+BUF[0]; //合成數(shù)據(jù)
- data_xyz[1]=(BUF[3]<<8)+BUF[2]; //合成數(shù)據(jù)
- data_xyz[2]=(BUF[5]<<8)+BUF[4]; //合成數(shù)據(jù)
- //分別是加速度X,Y,Z的原始數(shù)據(jù),10位的
- Q=(float)data_xyz[0]*3.9;
- T=(float)data_xyz[1]*3.9;
- K=(float)data_xyz[2]*3.9;
- Q=-Q;
- Roll=(float)(((atan2(K,Q)*180)/3.14159265)); //X軸角度值
- Pitch=(float)(((atan2(K,T)*180)/3.14159265)); //Y軸角度值
- DisplayOneChar(0,0,'A');
- DisplayOneChar(1,0,'n');
- DisplayOneChar(2,0,'g');
- DisplayOneChar(3,0,'l');
- DisplayOneChar(4,0,'e');
- DisplayOneChar(10,0,'O');
- DisplayOneChar(11,0,'f');
- DisplayOneChar(12,0,'f');
- DisplayOneChar(13,0,'s');
- DisplayOneChar(14,0,'e');
- DisplayOneChar(15,0,'t');
- conversion(Roll); //轉(zhuǎn)換出顯示需要的數(shù)據(jù)X軸
- DisplayOneChar(0,1,'X');
- DisplayOneChar(2,1,bai);
- DisplayOneChar(3,1,shi);
- DisplayOneChar(4,1,ge);
- DisplayOneChar(5,1,0xdf);
- conversion(Pitch); //轉(zhuǎn)換出顯示需要的數(shù)據(jù)Y軸
- DisplayOneChar(10,1,'Y');
- DisplayOneChar(11,1,':');
- DisplayOneChar(12,1,bai);
- DisplayOneChar(13,1,shi);
- DisplayOneChar(14,1,ge);
- DisplayOneChar(15,1,0xdf);
- delay(200); //延時(shí)
基于ADXL345傳感器的LCD1602角度顯示功能設(shè)計(jì).zip
(48.23 KB, 下載次數(shù): 57)
2019-5-10 10:13 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
