查看: 3328|回復: 3
單片機小小調度器源程序 操作系統(tǒng)相關
ID:451498 發(fā)表于 2019-5-11 08:45 | 顯示全部樓層 |閱讀模式
一個簡易的調度器
單片機源程序如下:
  1. #include <stc89c51.h>
  2. /****小小調度器開始**********************************************/
  3. #define MAXTASKS 3
  4. volatile unsigned char timers[MAXTASKS];
  5. #define _SS static unsigned char _lc=0; switch(_lc){default:
  6. #define _EE ;}; _lc=0; return 255;
  7. #define WaitX(tickets)??do {_lc=(__LINE__+((__LINE__%256)==0))%256; return tickets ;} while(0); case (__LINE__+((__LINE__%256)==0))%256:
  8. #define RunTask(TaskName,TaskID) do { if (timers[TaskID]==0) timers[TaskID]=TaskName(); }??while(0);
  9. #define RunTaskA(TaskName,TaskID) { if (timers[TaskID]==0) {timers[TaskID]=TaskName(); continue;} }? ?//前面的任務優(yōu)先保證執(zhí)行
  10. #define CallSub(SubTaskName) do {unsigned char currdt; _lc=(__LINE__+((__LINE__%256)==0))%256; return 0; case (__LINE__+((__LINE__%256)==0))%256:??currdt=SubTaskName(); if(currdt!=255) return currdt;} while(0);
  11. #define InitTasks() {unsigned char i; for(i=MAXTASKS;i>0 ;i--) timers[i]=0; }
  12. #define UpdateTimers() {unsigned char i; for(i=MAXTASKS;i>0 ;i--){if((timers[i-1]!=0)&&(timers[i-1]!=255)) timers[i-1]--;}}
  13. #define SEM unsigned int
  14. //初始化信號量
  15. #define InitSem(sem) sem=0;
  16. //等待信號量
  17. #define WaitSem(sem) do{ sem=1; WaitX(0); if (sem>0) return 1;} while(0);
  18. //等待信號量或定時器溢出, 定時器tickets 最大為0xFFFE
  19. #define WaitSemX(sem,tickets)??do { sem=tickets+1; WaitX(0); if(sem>1){ sem--;??return 1;} } while(0);
  20. //發(fā)送信號量
  21. #define SendSem(sem)??do {sem=0;} while(0);
  22. /*****小小調度器結束*******************************************************/
  23. sbit LED1 = P2^1;
  24. sbit LED2 = P2^2;
  25. sbit LED0 = P2^5;
  26. unsigned char task0(){
  27.         _SS
  28.         while(1){
  29.                 WaitX(50);
  30.                 LED0=!LED0;
  31.         }
  32.         _EE
  33. }
  34. unsigned char??task1(){
  35.         _SS
  36.         while(1){
  37.                 WaitX(100);
  38.                 LED1=!LED1;
  39.         }
  40.         _EE
  41. }
  42. unsigned char??task2(){
  43.         _SS
  44.         while(1){
  45.                 WaitX(100);
  46.                 LED2=!LED2;
  47.         }
  48.         _EE
  49. }
  50. void InitT0()
  51. {
  52.         TMOD = 0x21;
  53.         IE |= 0x82;??// 12t
  54.         TL0=0Xff;
  55.         TH0=0XDB;
  56.         TR0 = 1;
  57. }
  58. void INTT0(void) interrupt 1 using 1
  59. {
  60.         TL0=0Xff;? ? //10ms 重裝
  61.         TH0=0XDB;//b7;
  62.         UpdateTimers();
  63.         RunTask(task0,0);//任務0具有精確按時獲得執(zhí)行的權限,要求:task0每次執(zhí)行消耗時間<0.5個 ticket
  64. }
  65. void main()
  66. {
  67.         InitT0();
  68.         InitTasks(); //初始化任務,實際上是給timers清零
  69.         while(1){
  70.                 //? ?? ?? ???RunTask(task0,0);
  71.                 RunTaskA(task1,1);//任務1具有比任務2高的運行權限
  72.                 RunTaskA(task2,2);//任務2具有低的運行權限
  73.         }
  74. }
復制代碼
小小調度器.zip (11.96 KB, 下載次數(shù): 40)
admin + 50 共享資料的黑幣獎勵!
ID:328014 發(fā)表于 2019-5-17 06:25 | 顯示全部樓層
好資料,51黑有你更精彩!!!
ID:105845 發(fā)表于 2022-12-7 14:21 | 顯示全部樓層
編譯后出現(xiàn)test.c(99): warning C294: unreachable code。這個怎么消除呢?
ID:335252 發(fā)表于 2022-12-7 19:38 | 顯示全部樓層
樓主棒棒的
