可以通過(guò)STM32直接上云的源碼。
1、修復(fù)ST V2.1底板時(shí)溫濕度不規(guī)則報(bào)0的問(wèn)題[bug:45027];
2015-08-28 V2.3.1
1、支持GoKit2.2硬件(增加RGB燈使能引腳A0)
2015-07-27 V2.3.0
1、采用uVision V4.70.0.0軟件
2、修改了軟件結(jié)構(gòu),封裝了串口協(xié)議部分,進(jìn)一步提升擴(kuò)展性;
3、解決了app上顯示溫度不準(zhǔn)確的問(wèn)題;
4、修改了入網(wǎng)配置方法;
長(zhǎng)按key1恢復(fù)默認(rèn)配置,短按key2進(jìn)入Soft AP模式,RGB燈紅色,長(zhǎng)按key2進(jìn)入AirLink模式,RGB燈綠色;
5、關(guān)掉了進(jìn)入配置模式時(shí)電機(jī)轉(zhuǎn)動(dòng)操作;
6、解決了APP中自定義燈顏色切換不準(zhǔn)確的問(wèn)題;
7、完善了協(xié)議指令01、03、04、05指令;
8、解決了上電時(shí)RGB高亮一段時(shí)間的問(wèn)題;
先在gizwits_protocol.h將所有數(shù)據(jù)點(diǎn)加入
搜尋custom
修改eventProcess,dataPoint2Event,checkReport函數(shù)
只可讀數(shù)據(jù)點(diǎn)在userHandle內(nèi)加入
- #include <string.h>
- #include "gizwits_product.h"
- #include "Hal_key/Hal_key.h"
- #include "Hal_Usart/hal_uart.h"
- #include "Hal_led/Hal_led.h"
- #include "Hal_motor/Hal_motor.h"
- #include "Hal_rgb_led/Hal_rgb_led.h"
- #include "Hal_temp_hum/Hal_temp_hum.h"
- #include "Hal_infrared/Hal_infrared.h"
- #include "Hal_Watchdog/hal_watchdog.h"
- #include "bsp_key.h"
- /**包頭*/
- unsigned char datahead[32]={0xFE,0xFD,0xFC,0xFB,0xFA,0xF9,0xF8,0xF7,0xF6,0xF5,0xF4,0xF3,0xF2,0xF1,0xF0,0xEF,0xEE,0xED,0xEC,0xEB,0xEA,0xE9,0xE8,0xE7,0xE6,0xE5,0xE4,0xE3,0xE2,0xE1,0xE0,0xDF};
- u8 gesture=0;
- extern unsigned char feeder_rec;//暖奶器開(kāi)關(guān)
- extern unsigned char eat_alert_rec;//喝奶鬧鐘開(kāi)關(guān)
- extern unsigned char humidifier_rec;//加濕器開(kāi)關(guān)
- extern unsigned char anion_rec;//負(fù)離子凈化器開(kāi)關(guān)
- extern unsigned char blanket_rec;//恒溫床墊開(kāi)關(guān)
- extern unsigned char swing_rec;//搖擺檔位選擇
- extern unsigned char eat_hour_rec;//定時(shí)喝奶時(shí)
- extern unsigned char eat_minute_rec;//定時(shí)喝奶分
- extern unsigned char pee_rec;//是否尿床
- extern unsigned char eat_status_rec;//上次是否喝奶
- extern unsigned char temperature_rec;//環(huán)境溫度
- extern unsigned char humidity_rec;//環(huán)境濕度
- extern unsigned char baby_heat_rec;//嬰兒體溫
- extern unsigned char baby_weight_rec;//嬰兒體重
- extern unsigned char co_value_rec;//CO濃度
- extern unsigned char bed_heat_rec;//床墊溫度
- volatile gizwitsReport_t reportData;//dev_status包含在里面
- keyTypedef_t singleKey[2];
- keysTypedef_t keys;
- void userInit(void)
- Key_GPIO_Config();
- delayInit(72);
- uartxInit();
- rgbLedInit();
- ledGpioInit();
- rgbKeyGpioInit();
- motorInit();
- dht11Init();
- irInit();
- watchdogInit(2); //5,625看門(mén)狗復(fù)位時(shí)間2s
- memset((uint8_t*)&reportData, 0, sizeof(gizwitsReport_t));
- motorStatus(MOTOR_SPEED_DEFAULT);
- void userHandle(void)
- /**控制類(lèi)數(shù)據(jù)點(diǎn)*/
- uint8_t curFeeder = 0;
- uint8_t curEat_Alert = 0;
- uint8_t curHumidifier = 0;
- uint8_t curAnion = 0;
- uint8_t curBlanket = 0;
- uint8_t curColor = 0;
- uint8_t curHour = 0;
- uint8_t curMin = 0;
- static uint32_t feederLastTimer=0;
- static uint32_t eat_alertLastTimer=0;
- static uint32_t humidifierLastTimer=0;
- static uint32_t anionLastTimer=0;
- static uint32_t blanketLastTimer=0;
- static uint32_t colorLastTimer=0;
- static uint32_t hourLastTimer=0;
- static uint32_t minLastTimer=0;
- /**傳感器類(lèi)數(shù)據(jù)點(diǎn)*/
- int8_t curTem = 0; //當(dāng)前的溫度
- int8_t curHum = 0; //當(dāng)前的濕度
- uint8_t curInfrared = 0; //當(dāng)前紅外狀態(tài)
- uint8_t curPee = 0; //當(dāng)前是否尿床
- uint8_t curEat = 0; //當(dāng)前的喝奶狀態(tài)
- uint8_t curBaby_Heat = 0; //當(dāng)前嬰兒的體溫
- uint8_t curBaby_Weight = 0; //當(dāng)前嬰兒的體重
- uint8_t curCO_Value = 0; //當(dāng)前CO的濃度
- uint8_t curBed_Heat = 0; //當(dāng)前被窩的溫度
- static int8_t lastTem = 0; //上一次的溫度,只有上次和這次的不一樣才上傳
- static int8_t lastHum = 0; //上一次的濕度,只有上次和這次的不一樣才上傳
- static uint32_t peeLastTimer=0; //上一次尿床檢測(cè)的TimerCount
- static uint32_t eatLastTimer=0; //上一次喝奶狀態(tài)的TimerCount
- static uint32_t babyhLastTimer=0;//上一次嬰兒體溫的TimerCount
- static uint32_t weiLastTimer=0; //上一次嬰兒體重的TimerCount
- static uint32_t COLastTimer=0; //上一次CO濃度的TimerCount
- static uint32_t bedhLastTimer=0; //上一次被窩溫度的TimerCount
- static uint32_t irLastTimer = 0; //上一次紅外的TimerCount
- static uint32_t thLastTimer = 0; //上一次Dht11的TimerCount 只有超過(guò)2s以上才上傳
- /**獲取控制類(lèi)數(shù)據(jù)*/
- curFeeder=feeder_rec;
- curEat_Alert=eat_alert_rec;
- curHumidifier=humidifier_rec;
- curAnion=anion_rec;
- curBlanket=blanket_rec;
- curColor=swing_rec;
- curHour=eat_hour_rec;
- curMin=gesture;
- /**獲取傳感器類(lèi)數(shù)據(jù)*/
- curInfrared = irHandle();
- curPee=pee_rec;
- curEat=eat_status_rec;
- curBaby_Heat=baby_heat_rec;
- curBaby_Weight=baby_weight_rec;
- curCO_Value=co_value_rec;
- curBed_Heat=bed_heat_rec;
- curTem=temperature_rec;
- curHum=humidity_rec;
- /**控制類(lèi)數(shù)據(jù)的更新*/
- if(curFeeder != reportData.devStatus.LED_OnOff)//暖奶器
- if((gizwitsGetTimerCount() - feederLastTimer) > REPORT_TIME_MAX/4) //timeout = 2S
- reportData.devStatus.LED_OnOff = curFeeder;
- feederLastTimer = gizwitsGetTimerCount();
- printf("LED_OnOff %d \r\n", feederLastTimer);
- if(curEat_Alert != reportData.devStatus.Eat_Alert)//喝奶鬧鐘
- if((gizwitsGetTimerCount() - eat_alertLastTimer) > REPORT_TIME_MAX/4) //timeout = 2S
- reportData.devStatus.Eat_Alert = curEat_Alert;
- eat_alertLastTimer = gizwitsGetTimerCount();
- printf("Eat_Alert %d \r\n", eat_alertLastTimer);
- if(curHumidifier != reportData.devStatus.Humidity_OnOff)//加濕器
- if((gizwitsGetTimerCount() - humidifierLastTimer) > REPORT_TIME_MAX/4) //timeout = 2S
- reportData.devStatus.Humidity_OnOff = curHumidifier;
- humidifierLastTimer = gizwitsGetTimerCount();
- printf("Humidity_OnOff %d \r\n", humidifierLastTimer);
- if(curAnion != reportData.devStatus.Anion_OnOff)//負(fù)離子凈化器
- if((gizwitsGetTimerCount() - anionLastTimer) > REPORT_TIME_MAX/4) //timeout = 2S
- reportData.devStatus.Anion_OnOff = curAnion;
- anionLastTimer = gizwitsGetTimerCount();
- printf("Anion_OnOff %d \r\n", anionLastTimer);
- if(curBlanket != reportData.devStatus.Blanket_OnOff)//恒溫床墊
- if((gizwitsGetTimerCount() - blanketLastTimer) > REPORT_TIME_MAX/4) //timeout = 2S
- reportData.devStatus.Blanket_OnOff = curBlanket;
- blanketLastTimer = gizwitsGetTimerCount();
- printf("Blanket_OnOff %d \r\n", blanketLastTimer);
- if(curColor != reportData.devStatus.LED_Color)//搖擺檔位
- if((gizwitsGetTimerCount() - colorLastTimer) > REPORT_TIME_MAX/4) //timeout = 2S
- reportData.devStatus.LED_Color = curColor;
- colorLastTimer = gizwitsGetTimerCount();
- printf("LED_Color %d \r\n", colorLastTimer);
- if(curHour != reportData.devStatus.LED_R)//喝奶時(shí)
- if((gizwitsGetTimerCount() - hourLastTimer) > REPORT_TIME_MAX/4) //timeout = 2S
- reportData.devStatus.LED_R = curHour;
- hourLastTimer = gizwitsGetTimerCount();
- printf("LED_R %d \r\n", hourLastTimer);
- if(curMin != reportData.devStatus.LED_G)//喝奶分
- if((gizwitsGetTimerCount() - minLastTimer) > REPORT_TIME_MAX/4) //timeout = 2S
- reportData.devStatus.LED_G = curMin;
- minLastTimer = gizwitsGetTimerCount();
- printf("LED_G %d \r\n", minLastTimer);
- /**傳感器類(lèi)數(shù)據(jù)狀態(tài)更新*/
- if(curInfrared != reportData.devStatus.Infrared)//紅外反射
- if((gizwitsGetTimerCount() - irLastTimer) > REPORT_TIME_MAX/4) //timeout = 2S
- reportData.devStatus.Infrared = curInfrared;
- irLastTimer = gizwitsGetTimerCount();
- printf("Infrared %d \r\n", irLastTimer);
- if(curPee != reportData.devStatus.Pee_OnOff)//尿床檢測(cè)
- if((gizwitsGetTimerCount() - peeLastTimer) > REPORT_TIME_MAX/4) //timeout = 2S
- reportData.devStatus.Pee_OnOff = curPee;
- peeLastTimer = gizwitsGetTimerCount();
- printf("Pee_OnOff %d \r\n", peeLastTimer);
- if(curEat != reportData.devStatus.Eat_Status)//上次是否喝奶
- if((gizwitsGetTimerCount() - eatLastTimer) > REPORT_TIME_MAX/4) //timeout = 2S
- reportData.devStatus.Eat_Status = curEat;
- eatLastTimer = gizwitsGetTimerCount();
- printf("Eat_Status %d \r\n", eatLastTimer);
- if(curBaby_Heat != reportData.devStatus.Baby_Heat)//嬰兒體溫
- if((gizwitsGetTimerCount() - babyhLastTimer) > REPORT_TIME_MAX/4) //timeout = 2S
- reportData.devStatus.Baby_Heat = curBaby_Heat;
- babyhLastTimer = gizwitsGetTimerCount();
- printf("Baby_Heat %d \r\n", babyhLastTimer);
- if(curBaby_Weight != reportData.devStatus.Baby_Weight)//嬰兒體重
- if((gizwitsGetTimerCount() - weiLastTimer) > REPORT_TIME_MAX/4) //timeout = 2S
- reportData.devStatus.Baby_Weight = curBaby_Weight;
- weiLastTimer = gizwitsGetTimerCount();
- printf("Baby_Weight %d \r\n", weiLastTimer);
- if(curCO_Value != reportData.devStatus.CO_Value)//一氧化碳濃度
- if((gizwitsGetTimerCount() - COLastTimer) > REPORT_TIME_MAX/4) //timeout = 2S
- reportData.devStatus.CO_Value = curCO_Value;
- COLastTimer = gizwitsGetTimerCount();
- printf("CO_Value %d \r\n", COLastTimer);
- if(curBed_Heat != reportData.devStatus.Bed_Heat)//被窩溫度
- if((gizwitsGetTimerCount() - bedhLastTimer) > REPORT_TIME_MAX/4) //timeout = 2S
- reportData.devStatus.Bed_Heat = curBed_Heat;
- bedhLastTimer = gizwitsGetTimerCount();
- printf("Bed_Heat %d \r\n", bedhLastTimer);
- if((gizwitsGetTimerCount()-thLastTimer) > REPORT_TIME_MAX) //timeout = 2S
- if((curTem != lastTem)||(curHum != lastHum))//溫濕度
- reportData.devStatus.Temperature = curTem;
- reportData.devStatus.Humidity = curHum;
- lastTem = curTem;
- lastHum = curHum;
- printf("Temperature&Humidity [%d-%d] %d %d\r\n", gizwitsGetTimerCount(), thLastTimer, curTem, curHum);
- thLastTimer = gizwitsGetTimerCount();
- void key1ShortPress(void)
- printf("KEY1 PRESS\r\n");
- void key1LongPress(void)
- printf("KEY1 PRESS LONG ,Wifi Reset\r\n");
- gizwitsSetDefault();
- void key2ShortPress(void)
- printf("KEY2 PRESS ,Soft AP mode\r\n");
- //Soft AP mode, RGB red
- ledRgbControl(255, 0, 0);
- gizwitsSetMode(SoftAp_Mode);
- void key2LongPress(void)
- //AirLink mode, RGB Green
- printf("KEY2 PRESS LONG ,AirLink mode\r\n");
- ledRgbControl(0, 128, 0);
- gizwitsSetMode(AirLink_Mode);
- void gestureGet(void)
- if(Key_Scan(GPIOA,GPIO_Pin_1)==1)
- gesture|=0x01;
- else
- gesture&=0xfe;
- if(Key_Scan(GPIOA,GPIO_Pin_4)==1)
- gesture|=0x02;
- else
- gesture&=0xfd;
- if(Key_Scan(GPIOA,GPIO_Pin_5)==1)
- gesture|=0x04;
- else
- gesture&=0xfb;
- if(Key_Scan(GPIOA,GPIO_Pin_7)==1)
- gesture|=0x08;
- else
- gesture&=0xf7;
- if(Key_Scan(GPIOB,GPIO_Pin_0)==1)
- gesture|=0x10;
- else
- gesture&=0xef;
- if(Key_Scan(GPIOB,GPIO_Pin_6)==1)
Gokit3智能搖籃 V1.3(+睡姿).7z
(177.18 KB, 下載次數(shù): 42)
2019-5-17 05:56 上傳
點(diǎn)擊文件名下載附件
