之前做比賽的時(shí)候通關(guān)網(wǎng)絡(luò)搜集了一些 然后根據(jù)自己的車 做了部分修改 算是一個(gè)整合吧 基于51單片機(jī)
- #include<iom128v.h>
- #include<macros.h>
- #include<BIT.h>
- #include"LCD12864.c"
- #define uint unsigned int
- #define uchar unsigned char
- #pragma interrupt_handler timer0:iv_TIMER0_OVF
- #pragma interrupt_handler int0:iv_INT0
- #define PSB _PA3
- #define REST _PA4
- #define LED_B _PG1
- #define S2 _PE0
- #define S3 _PE1
- #define buzzer _PG0
- uchar table0[]="顏色識(shí)別";
- uchar table1[]="紅色: ";
- uchar table2[]="綠色: ";
- uchar table3[]="藍(lán)色: ";
- uint red,gree,blue,time_count,int_count;
- uchar red_value,gree_value;
- void delay(uint tt)
- uchar j;
- for(;tt>0;tt--)
- for(j=100;j>0;j--);
- void timer_Init()
- TCCR0=0x07;
- TCNT0=0x64;
- // TIMSK|=BIT(0);
- void interrupt0_Init()
- // EIMSK|=BIT(0);
- EICRA=0x02;
- DDR_PD0=0;
- // _PD0=1;
- void PORT_INIT()
- DDR_PA0=1;
- DDR_PA1=1;
- DDR_PA2=1;
- DDR_PA3=1;
- DDR_PA4=1;
- DDRC=0xff;
- DDR_PE0=1;
- DDR_PE1=1;
- DDR_PG0=1;
- DDR_PG1=1;
- PSB=0;
- REST=1;
- LED_B=1;
- void color_Recognition()
- S2=1;
- S3=1;
- EIMSK|=BIT(0);
- TIMSK|=BIT(0);
- void main()
- PORT_INIT();
- timer_Init();
- interrupt0_Init();
- LCD_12864_Init();
- SREG|=BIT(7);
- // PutStr(0,2,table0);
- PutStr(1,1,table1);
- PutStr(2,1,table2);
- PutStr(3,1,table3);
- delay(5000);
- buzzer=1;
- delay(200);
- buzzer=0;
- color_Recognition();
- while(1);
- void timer0()
- uchar ge,shi,bai,qian;
- float temp;
- TIMSK&=~BIT(0);
- time_count++;
- TCNT0=0x64;
- if(time_count==1)
- bai=int_count/100;
- shi=int_count%100/10;
- ge=int_count%10;
- Write_command_12864(0x95);
- Write_data_12864(0x30+bai);
- Write_data_12864(0x30+shi);
- Write_data_12864(0x30+ge);
- red=int_count;
- S2=1;
- S3=1;
- if(time_count==2)
- ge=int_count%10;
- Write_command_12864(0x8d);
- gree=int_count;
- S2=0;
- S3=1;
- if(time_count==3)
- ge=int_count%10;
- Write_command_12864(0x9d);
- blue=int_count;
- S2=0;
- S3=0;
- if(time_count==40)
- time_count=0;
- temp=(float)red/blue;
- red_value=temp*1000;
- temp=(float)gree/blue;
- gree_value=temp*1000;
- qian=red_value/1000;
- bai=red_value%1000/100;
- shi=red_value%100/10;
- ge=red_value%10;
- Write_command_12864(0x81);
- Write_data_12864(0x30+qian);
- qian=gree_value/1000;
- bai=gree_value%1000/100;
- shi=gree_value%100/10;
- ge=gree_value%10;
- Write_command_12864(0x85);
- int_count=0;
- TIMSK|=BIT(0);
- void int0()
- int_count++;
2019-5-17 05:51 上傳
GY-31顏色模塊發(fā)送資料.7z
(4 MB, 下載次數(shù): 14)
2019-5-17 05:52 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
