查看: 7353|回復(fù): 10
基于STM32的ADS1118+uart串口顯示程序
ID:465802 發(fā)表于 2019-5-13 17:06 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
STM32使用SPI1驅(qū)動(dòng)ADS1118
#include "ads1118.h"
#include "sys.h"
#include "delay.h"
#include "usart.h"
void SPI1_Init(void)
        SPI_InitTypeDef SPI_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE );//open the PORTB clock
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE );//open the SPI1 clock
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;//enable PB14/15/13
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //setting PB3/4/5 to push-pull mode
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;  //set GPIO speed
        GPIO_Init(GPIOA, &GPIO_InitStructure);//Initical GPIOA
        GPIO_SetBits(GPIOA,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);  //PA5/6/7上拉
        SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;  //設(shè)置SPI單向或者雙向的數(shù)據(jù)模式:SPI設(shè)置為雙線雙向全雙工
        SPI_InitStructure.SPI_Mode = SPI_Mode_Master;                //設(shè)置SPI工作模式:設(shè)置為主SPI
        SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;                //設(shè)置SPI的數(shù)據(jù)大小:SPI發(fā)送接收8位幀結(jié)構(gòu)
        SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;                //串行同步時(shí)鐘的空閑狀態(tài)為低電平
        SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;        //串行同步時(shí)鐘的第二個(gè)跳變沿(上升或下降)數(shù)據(jù)被采樣
        SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;                //NSS信號(hào)由硬件(NSS管腳)還是軟件(使用SSI位)管理:內(nèi)部NSS信號(hào)有SSI位控制
        SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_8;                //定義波特率預(yù)分頻的值:波特率預(yù)分頻值為256
        SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;        //指定數(shù)據(jù)傳輸從MSB位還是LSB位開(kāi)始:數(shù)據(jù)傳輸從MSB位開(kāi)始
        SPI_InitStructure.SPI_CRCPolynomial = 7;        //CRC值計(jì)算的多項(xiàng)式
        SPI_Init(SPI1, &SPI_InitStructure);  //根據(jù)SPI_InitStruct中指定的參數(shù)初始化外設(shè)SPIx寄存器
        SPI_Cmd(SPI1, ENABLE); //使能SPI外設(shè)
        ADS1118_ReadVotage(0x62eB);//啟動(dòng)傳輸
        delay_ms(8);
void ADS1118_Init(void)
        RCC_APB2PeriphClockCmd(        RCC_APB2Periph_GPIOA, ENABLE );        //PORTF時(shí)鐘使能
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;                                                          //PF0 推挽
         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;                          //推挽輸出
  ADC_CS_High();        //CS拉高,器件不工作
        SPI1_Init();        //初始化SPI1
        SPI1_SetSpeed(SPI_BaudRatePrescaler_8);        //設(shè)置為--M時(shí)鐘,高速模式 9MHZ時(shí)鐘
//SPI 速度設(shè)置函數(shù)
//SpeedSet:
//SPI_BaudRatePrescaler_2   2分頻
//SPI_BaudRatePrescaler_8   8分頻
//SPI_BaudRatePrescaler_16  16分頻
//SPI_BaudRatePrescaler_256 256分頻
void SPI1_SetSpeed(u8 SPI_BaudRatePrescaler)
  assert_param(IS_SPI_BAUDRATE_PRESCALER(SPI_BaudRatePrescaler));
        SPI1->CR1&=0XFFC7;
        SPI1->CR1|=SPI_BaudRatePrescaler;        //設(shè)置SPI1速度
        SPI_Cmd(SPI1,ENABLE);
u8 ADS1118_ReadWrite(u8 ConfigReg1)
                u8 retry=0;
                while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET) //檢查指定的SPI標(biāo)志位設(shè)置與否:發(fā)送緩存空標(biāo)志位
                retry++;
                if(retry>200)return 0;
        SPI_I2S_SendData(SPI1, ConfigReg1);
        while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET) //檢查指定的SPI標(biāo)志位設(shè)置與否:接受緩存非空標(biāo)志位
                retry++;
                return SPI_I2S_ReceiveData(SPI1);
u16 ADS1118_ReadVotage(u16 ConfigReg)        //ADS1118配置,設(shè)置16位數(shù)據(jù)輸入,
        u8  Hbyte=0;        //高8位
        u8  Lbyte=0;        //低8位
        u16 tmp=0;        //數(shù)據(jù)
        ADC_CS_Low();        //CS拉低
        delay_us(2);        //CS下降沿SCK第一個(gè)上升沿需要大于100ns
        Hbyte=        ADS1118_ReadWrite((u8)(ConfigReg>>8));
        Lbyte=  ADS1118_ReadWrite((u8)ConfigReg);
        tmp=((u16)Hbyte<<8)|(u16)Lbyte;
        delay_us(2);        //CS????????SCK????????100ns
        ADC_CS_High();        //CS??,??????
        return tmp;        //??????
全部資料51hei下載地址:
ADS1118_2.7z (205.76 KB, 下載次數(shù): 245)
ID:504038 發(fā)表于 2019-7-19 14:51 | 只看該作者
ADS1118_ReadVotage(0x62eB);//啟動(dòng)傳輸        里面的0x62eb什么意思
ID:314158 發(fā)表于 2019-7-25 18:50 來(lái)自手機(jī) | 只看該作者
斤斤計(jì)較軍 發(fā)表于 2019-7-19 14:51
好像是寫入配置寄存器的
ID:345352 發(fā)表于 2019-10-18 19:56 | 只看該作者
小白的我總算找到一份比較完整的代碼了,謝謝樓主,學(xué)習(xí)了
ID:332464 發(fā)表于 2019-12-20 20:35 | 只看該作者
樓主NB
ID:425031 發(fā)表于 2020-4-4 20:23 | 只看該作者
程序?qū)懙哪:剑珹DS1118四個(gè)輸入和一個(gè)內(nèi)置溫度檢測(cè),到底檢測(cè)的啥
ID:265975 發(fā)表于 2020-4-4 22:26 | 只看該作者
受教頗多,謝謝分享經(jīng)驗(yàn)
ID:724706 發(fā)表于 2020-4-8 12:15 | 只看該作者
謝謝樓主分享
ID:626187 發(fā)表于 2022-4-14 20:51 | 只看該作者
請(qǐng)問(wèn)這程序用的是硬件SPI還是軟件SPI?
ID:228452 發(fā)表于 2022-4-15 17:30 | 只看該作者
SPI1_Init( ); //Initialize SPI1
SPI1_SetSpeed(SPI_BaudRatePrescaler_8); //Set to --M clock, high speed mode 9MHZ clock
Hardware SPI
ID:1041200 發(fā)表于 2024-7-10 22:12 | 只看該作者
最近正好在做熱電偶測(cè)溫,這個(gè)程序剛好,硬件SPI,引腳順序都一樣。只是最后讀出來(lái)的值一直不動(dòng),不知道為啥。還有就是,一共四個(gè)通道,程序里沒(méi)有說(shuō)明數(shù)據(jù)是從哪個(gè)通道進(jìn)來(lái)的。
