查看: 2531|回復(fù): 0
求大神幫看看這單片機(jī)程序!
ID:513931 發(fā)表于 2019-5-13 23:22 來自手機(jī) | 只看該作者 |只看大圖 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
200黑幣
要做一個(gè)時(shí)鐘電路 有四個(gè)按鈕 k1切換狀態(tài):時(shí)鐘狀態(tài)或者調(diào)時(shí)狀態(tài)   k2選擇調(diào)時(shí)調(diào)小時(shí) 分鐘還是秒  k3k4為加減
#include<reg51.h>
#include<intrins.h>
uchar code DSY_CODE[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,
0x88,0x83,0xc6,0xa1,0x86,0x8e,0x00,0xbf};
uint a=0,b=0;
uchar shi=0;
uchar shi1=0;
uchar shi2=0;
uchar fen=0;
uchar fen1=0;
uchar fen2=0;
uchar miao=0;
uchar miao1=0;
uchar miao2=0;
uchar set1=1,set2=1;
sbit k1=P1^0;
sbit k2=P1^1;
sbit k3=P1^2;
sbit k4=P1^3;
//延時(shí)
void DelayMS(uint x)
        uchar i;
        while(x--) for(i=0;i<120;i++);
//顯示程序
void xianshi(shi,fen,miao)
   shi=a/3600;
   shi1=shi%10;
   shi2=shi/10;
   fen=(a-shi*3600)/60;
   fen1=fen%10;
   fen2=fen/10;
   miao=a-shi*3600-fen*60;
   miao1=miao%10;
   miao2=miao/10;
   P3=0x80;
   P0=DSY_CODE[miao1];
   DelayMS(5);
   P3=0x00;
   P3=0x40;
   P0=DSY_CODE[miao2];
   DelayMS(5);
   P3=0x00;
   P3=0x20;
   P0=0xbf;
   DelayMS(5);
   P3=0x00;
   P3=0x10;
   P0=DSY_CODE[fen1];
   DelayMS(5);
   P3=0x00;
   P3=0x08;
   P0=DSY_CODE[fen2];
   DelayMS(5);
   P3=0x00;
   P3=0x04;
   P0=0xbf;
   DelayMS(5);
   P3=0x00;
   P3=0x02;
   P0=DSY_CODE[shi1];
   DelayMS(5);
   P3=0x00;
   P3=0x01;
   P0=DSY_CODE[shi2];
   DelayMS(5);
   P3=0x00;
uchar jia (uchar n)
    if(k3==0)
           DelayMS(20);
       if(k3==0)
              n++;
              while(!k3);
        return n;
uchar jian (uchar m)
    if(k4==0)
           DelayMS(20);
       if(k4==0)
              m++;
              while(!k4);
                  if(m<0)
                     m=0;
        return m;
void one()
           if(k1==0)
           DelayMS(20);
       if(k1==0)
              set1++;
              while(!k1);
                  if(set1==3)
                     set1=1;
void two()
   if(k2==0)
           DelayMS(20);
       if(k2==0)
              set2++;
              while(!k2);
                  if(set2==4)
                     set2=1;
void time()
   if(set1==2)
      if(set2==1)
             shi=jia(shi);
                 if(shi==24)
                    shi=0;
                 if(shi==-1)
                    shi=23;
                 shi=jian(shi);
          if(set2==2)
             fen=jia(fen);
                 if(fen==60)
                    fen=0;
                 if(fen==-1)
                    fen=59;
                 fen=jian(fen);
          if(set2==3)
             miao=jia(miao);
                 if(miao==60)
                    miao=0;
                 if(miao==-1)
                    miao=59;
                 miao=jian(miao);
    TMOD=0x01;
   TH0=(65536-50000)/256;
   TL0=(65536-50000)%256;
   IE=0x82;
   TR0=1;
          if(set1==1)
             xianshi(shi,fen,miao);
          if(set1==2)
          one();
          two();
          time();
void zhongduan() interrupt 1
    b++;
        if(b==20)
        {a++; b=0;}
        if(miao==60)
           miao=0;
           fen++;
        if(fen==60)
           fen=0;
           shi++;
        if(shi==24)
           shi=0;
