51單片機(jī)16X32LED點(diǎn)陣顯示屏由單片機(jī)最小系統(tǒng)、行驅(qū)動(dòng)電路74HC154、列驅(qū)運(yùn)電路74HC595組成,實(shí)現(xiàn)漢字、數(shù)字的顯示。電路簡(jiǎn)單。程序中以20個(gè)漢字作為顯示示例。資料含51單片機(jī)C語(yǔ)言源程序、PROTEUS7.8仿真源文件。附送取模軟件及取模說(shuō)明文檔,方便你自己更換顯示內(nèi)容。顯示移動(dòng)速度可在程序中進(jìn)行設(shè)置。
基于51單片機(jī)16X32LED點(diǎn)陣顯示屏程序設(shè)計(jì)
附件
#include <REG51.H>
#define FOSC 12 //定義晶振頻率
#define INIT_TH0 0x3C //定時(shí)器T0初始值
#define INIT_TL0 0xB0
#define TMOD_T00 0x00 //定義T0為方式0,GATE=0,C/T=0,13位計(jì)數(shù)器
#define TMOD_T01 0x01 //定義T0為方式1,GATE=0,C/T=0,16位計(jì)數(shù)器
#define TMOD_T02 0x02 //定義T0為方式2,GATE=0,C/T=0,自動(dòng)裝入8位計(jì)數(shù)器
#define TMOD_T03 0x03 //定義T0為方式3,GATE=0,C/T=0,定時(shí)器0分成兩個(gè)8位計(jì)數(shù)器,定時(shí)器1停止計(jì)數(shù)
/*縮定定義*/
/************位定義***************/
sbit STTP = P2^7;
/************函數(shù)聲明*************/
void delay(uint c); //延時(shí)函數(shù)
void out_rxd(uchar *d); //漢字輸出
/************漢字點(diǎn)陣*************/
char code hanzi[32][32]={
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //顯示空屏,如果只有一個(gè)字或?qū)⒆秩恳瞥霰仨氃O(shè)置一個(gè)空屏幕
/*-- 文字: 基 --*/
/*-- 宋體12; 此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x高=16x16 --*/
0x00,0x88,0x20,0x88,0x20,0x91,0x20,0xA1,0xFF,0xC9,0x2A,0x89,0x2A,0x89,0x2A,0xBF,
0x2A,0x89,0x2A,0x89,0xFF,0xC9,0x20,0xA1,0x20,0x91,0x20,0x88,0x00,0x88,0x00,0x00,
/*-- 文字: 于 --*/
0x02,0x00,0x02,0x00,0x42,0x00,0x42,0x00,0x42,0x00,0x42,0x02,0x42,0x01,0x7F,0xFE,
0x42,0x00,0x42,0x00,0x42,0x00,0x42,0x00,0x42,0x00,0x02,0x00,0x02,0x00,0x00,0x00,
/*-- 文字: 5 --*/
/*-- 宋體12; 此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x高=8x16 --*/
0x00,0x00,0x1F,0x98,0x10,0x84,0x11,0x04,0x11,0x04,0x10,0x88,0x10,0x70,0x00,0x00,
/*-- 文字: 1 --*/
0x00,0x00,0x08,0x04,0x08,0x04,0x1F,0xFC,0x00,0x04,0x00,0x04,0x00,0x00,0x00,0x00,
/*-- 文字: 單 --*/
0x00,0x08,0x00,0x08,0x1F,0xC8,0x92,0x48,0x52,0x48,0x32,0x48,0x12,0x48,0x1F,0xFF,
0x12,0x48,0x32,0x48,0x52,0x48,0x92,0x48,0x1F,0xC8,0x00,0x08,0x00,0x08,0x00,0x00,
/*-- 文字: 片 --*/
0x00,0x00,0x00,0x01,0x00,0x06,0x7F,0xF8,0x04,0x40,0x04,0x40,0x04,0x40,0x04,0x40,
0x04,0x40,0xFC,0x40,0x04,0x7F,0x04,0x00,0x04,0x00,0x04,0x00,0x00,0x00,0x00,0x00,
/*-- 文字: 機(jī) --*/
0x08,0x20,0x08,0xC0,0x0B,0x00,0xFF,0xFF,0x09,0x00,0x08,0xC1,0x00,0x06,0x7F,0xF8,
0x40,0x00,0x40,0x00,0x40,0x00,0x7F,0xFC,0x00,0x02,0x00,0x02,0x00,0x1E,0x00,0x00,
/*-- 文字: 的 --*/
0x00,0x00,0x1F,0xFE,0x30,0x84,0xD0,0x84,0x10,0x84,0x10,0x84,0x1F,0xFE,0x02,0x00,
0x0C,0x00,0xF1,0x00,0x10,0xC2,0x10,0x01,0x10,0x02,0x1F,0xFC,0x00,0x00,0x00,0x00,
/*-- 文字: 1 --*/
/*-- 文字: 6 --*/
0x00,0x00,0x07,0xF0,0x08,0x88,0x11,0x04,0x11,0x04,0x18,0x88,0x00,0x70,0x00,0x00,
/*-- 文字: × --*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x10,0x08,0x20,0x04,0x40,0x02,0x80,
0x01,0x00,0x02,0x80,0x04,0x40,0x08,0x20,0x10,0x10,0x00,0x00,0x00,0x00,0x00,0x00,
/*-- 文字: 3 --*/
0x00,0x00,0x0C,0x18,0x10,0x04,0x11,0x04,0x11,0x04,0x12,0x88,0x0C,0x70,0x00,0x00,
/*-- 文字: 2 --*/
0x00,0x00,0x0E,0x0C,0x10,0x14,0x10,0x24,0x10,0x44,0x11,0x84,0x0E,0x0C,0x00,0x00,
/*-- 文字: 點(diǎn) --*/
0x00,0x01,0x00,0x02,0x03,0xEC,0x02,0x20,0x02,0x20,0x02,0x28,0xFE,0x26,0x12,0x20,
0x12,0x28,0x12,0x26,0x12,0x20,0x13,0xE0,0x10,0x08,0x10,0x07,0x00,0x00,0x00,0x00,
/*-- 文字: 陣 --*/
0x00,0x00,0x7F,0xFF,0x40,0x10,0x44,0x08,0x5B,0x10,0x60,0xE0,0x10,0x10,0x13,0x10,
0x1D,0x10,0xF1,0x10,0x17,0xFF,0x11,0x10,0x11,0x10,0x11,0x10,0x10,0x10,0x00,0x00,
/*-- 文字: 顯 --*/
0x00,0x02,0x00,0x42,0x00,0x22,0x7F,0x1A,0x49,0x02,0x49,0xFE,0x49,0x02,0x49,0x02,
0x49,0x02,0x49,0xFE,0x49,0x02,0x7F,0x0A,0x00,0x12,0x00,0x62,0x00,0x02,0x00,0x00,
/*-- 文字: 示 --*/
0x02,0x04,0x02,0x08,0x42,0x10,0x42,0x60,0x42,0x00,0x42,0x02,0x42,0x01,0x43,0xFE,
0x42,0x00,0x42,0x00,0x42,0x00,0x42,0x40,0x42,0x20,0x02,0x10,0x02,0x0C,0x00,0x00,
/*-- 文字: 屏 --*/
0x00,0x02,0x00,0x0C,0x7F,0xF0,0x48,0x20,0x49,0x21,0x4D,0x26,0x4B,0xF8,0x49,0x20,
0x49,0x20,0x49,0x20,0x4B,0xFF,0x4D,0x20,0x79,0x20,0x00,0x20,0x00,0x00,0x00,0x00,
/*-- 文字: 程 --*/
0x24,0x10,0x24,0x60,0x25,0x80,0x7F,0xFF,0xC4,0x80,0x44,0x60,0x00,0x02,0x7C,0x92,
0x44,0x92,0x44,0x92,0x44,0xFE,0x44,0x92,0x44,0x92,0x7C,0x92,0x00,0x82,0x00,0x00,
/*-- 文字: 序 --*/
0x00,0x02,0x00,0x0C,0x3F,0xF0,0x20,0x00,0x20,0x80,0x20,0x80,0x28,0x80,0xA8,0x82,
0x6A,0x81,0x29,0xFE,0x2A,0x80,0x2C,0x80,0x28,0x80,0x20,0xA0,0x20,0xC0,0x00,0x00,
/*-- 文字: 設(shè) --*/
0x02,0x00,0x02,0x00,0x42,0x00,0x33,0xFC,0x00,0x09,0x02,0x11,0x05,0x02,0x79,0xC2,
0x41,0x34,0x41,0x08,0x41,0x14,0x79,0x62,0x05,0x82,0x04,0x01,0x04,0x01,0x00,0x00,
/*-- 文字: 計(jì) --*/
0x02,0x00,0x02,0x00,0x42,0x00,0x33,0xFE,0x00,0x04,0x02,0x08,0x02,0x00,0x02,0x00,
0x02,0x00,0xFF,0xFF,0x02,0x00,0x02,0x00,0x02,0x00,0x02,0x00,0x02,0x00,0x00,0x00,
/*-- 文字: 與 --*/
0x00,0x10,0x00,0x10,0x07,0x10,0xF9,0x10,0x11,0x10,0x11,0x10,0x11,0x10,0x11,0x10,
0x11,0x10,0x11,0x12,0x11,0x01,0x11,0x02,0x11,0xFC,0x10,0x00,0x00,0x00,0x00,0x00,
/*-- 文字: 仿 --*/
0x00,0x80,0x01,0x00,0x06,0x00,0x1F,0xFF,0xE0,0x01,0x10,0x02,0x10,0x0C,0x1F,0xF0,
0x91,0x00,0x71,0x02,0x11,0x01,0x11,0x02,0x11,0xFC,0x10,0x00,0x10,0x00,0x00,0x00,
/*-- 文字: 真 --*/
0x00,0x08,0x20,0x08,0x20,0x09,0x2F,0xFA,0x2A,0xAC,0x2A,0xA8,0x2A,0xA8,0xFA,0xA8,
0x2A,0xA8,0x2A,0xA8,0x2A,0xAC,0x2F,0xFA,0x20,0x09,0x20,0x08,0x00,0x08,0x00,0x00,
/************主函數(shù)***************/
uchar i,j,k; //i:每個(gè)字的顯示循環(huán);j每個(gè)字的顯示碼除以2;k每列刷新次數(shù)
uint b=0; //顯示偏移控制,char類型最多只能顯示14個(gè)漢字+一個(gè)空白位字符
uchar a; //控制移動(dòng)間隔時(shí)間
SCON = 0x00;
j=0;
if(a>6) //移動(dòng)間隔時(shí)間;取值0-20
a=0;
b+=2;
if(b>=700) //顯示到最后一個(gè)字,回頭顯示,判斷值=字?jǐn)?shù)*32
b=0;
for(i=0;i<16;i++)
P1=i;
for(k=0;k<1;k++)
STTP = 0;
out_rxd(&hanzi[3][j+b+1]);
out_rxd(&hanzi[3][j+b]);
out_rxd(&hanzi[2][j+b+1]);
out_rxd(&hanzi[2][j+b]);
out_rxd(&hanzi[1][j+b+1]);
out_rxd(&hanzi[1][j+b]);
out_rxd(&hanzi[0][j+b+1]);
out_rxd(&hanzi[0][j+b]);
STTP = 1;
delay(15);
j=j+2;
a++;
/************子函數(shù)**************/
void delay(uint c)
int i,j;
for(i=0;i<c;i++)
for(j=0;j<10;j++)
.......................................................................完整程序請(qǐng)自行下載附件
全部資料51hei下載地址:
_基于51單片機(jī)16X32點(diǎn)陣顯示屏程序設(shè)計(jì)與仿真.rar
(434.46 KB, 下載次數(shù): 357)
2019-5-14 06:20 上傳
點(diǎn)擊文件名下載附件
