查看: 2530|回復: 0
STM32 CUBEMX-usart+led程序 學習的步伐繼續(xù)
ID:481399 發(fā)表于 2019-5-14 15:00 | 顯示全部樓層 |閱讀模式
之前因為事情拉下了一段時間現(xiàn)在繼續(xù)跟上
使用軟件:stm32cubemx+mdk5
硬件平臺:stm32f407
接上一個帖子
見證自己一步步學習的步伐
單片機源程序如下:
  1. /* Includes ------------------------------------------------------------------*/
  2. #include "stm32f4xx_hal.h"
  3. #include "usart.h"
  4. #include "gpio.h"
  5. /* USER CODE BEGIN Includes */
  6. /* USER CODE END Includes */
  7. /* Private variables ---------------------------------------------------------*/
  8. /* USER CODE BEGIN PV */
  9. /* Private variables ---------------------------------------------------------*/
  10. /* USER CODE END PV */
  11. /* Private function prototypes -----------------------------------------------*/
  12. void SystemClock_Config(void);
  13. /* USER CODE BEGIN PFP */
  14. /* Private function prototypes -----------------------------------------------*/
  15. /* USER CODE END PFP */
  16. /* USER CODE BEGIN 0 */
  17. /* USER CODE END 0 */
  18. int main(void)
  19. {
  20.   /* USER CODE BEGIN 1 */
  21. uint8_t  tx_buf[]="USART TEST\r\n";
  22.   /* USER CODE END 1 */
  23.   /* MCU Configuration----------------------------------------------------------*/
  24.   /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  25.   HAL_Init();
  26.   /* Configure the system clock */
  27.   SystemClock_Config();
  28.   /* Initialize all configured peripherals */
  29.   MX_GPIO_Init();
  30.   MX_USART1_UART_Init();
  31.   /* USER CODE BEGIN 2 */
  32.   /* USER CODE END 2 */
  33.   /* Infinite loop */
  34.   /* USER CODE BEGIN WHILE */
  35.   while (1)
  36.   {
  37.   /* USER CODE END WHILE */
  38.   /* USER CODE BEGIN 3 */
  39.         HAL_UART_Transmit(&huart1,"Hello!\r\n",8,10);
  40.                 HAL_Delay(1000);
  41.                         HAL_UART_Transmit(&huart1,tx_buf,12,10);
  42.                 HAL_Delay(1000);
  43.
  44.   }
  45.   /* USER CODE END 3 */
  46. }
  47. /** System Clock Configuration
  48. */
  49. void SystemClock_Config(void)
  50. {
  51.   RCC_OscInitTypeDef RCC_OscInitStruct;
  52.   RCC_ClkInitTypeDef RCC_ClkInitStruct;
  53.   __HAL_RCC_PWR_CLK_ENABLE();
  54.   __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
  55.   RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
  56.   RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  57.   RCC_OscInitStruct.HSICalibrationValue = 16;
  58.   RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
  59.   HAL_RCC_OscConfig(&RCC_OscInitStruct);
  60.   RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
  61.                               |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  62.   RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI;
  63.   RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  64.   RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
  65.   RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  66.   HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0);
  67.   HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
  68.   HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
  69.   /* SysTick_IRQn interrupt configuration */
  70.   HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
  71. }
  72. /* USER CODE BEGIN 4 */
  73. /* USER CODE END 4 */
  74. #ifdef USE_FULL_ASSERT
  75. /**
  76.    * @brief Reports the name of the source file and the source line number
  77.    * where the assert_param error has occurred.
  78.    * @param file: pointer to the source file name
  79.    * @param line: assert_param error line source number
  80.    * @retval None
  81.    */
  82. void assert_failed(uint8_t* file, uint32_t line)
  83. {
  84.   /* USER CODE BEGIN 6 */
  85.   /* User can add his own implementation to report the file name and line number,
  86.     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  87.   /* USER CODE END 6 */
  88. }
  89. #endif
  90. /**
  91.   * @}
  92.   */
  93. /**
  94.   * @}
  95. */
  96. /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
復制代碼
USART.7z (287.45 KB, 下載次數(shù): 12)
admin + 50 共享資料的黑幣獎勵!
Powered by 單片機教程網
