查看: 2127|回復: 3
用單片機對28BYJ-48進行加減速,正反轉(zhuǎn)。加減速的每個檔位的轉(zhuǎn)速怎么看出來啊,有...
ID:538670 發(fā)表于 2019-5-15 10:47 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
//數(shù)碼管位 高位-----低位
//四個按鍵控制步進電機:正轉(zhuǎn),反轉(zhuǎn),加1,減1
//上電時電機啟動,數(shù)碼管上顯示速度最小檔1,加減檔位均能通過數(shù)碼管顯示出來,電機采用單雙八拍方式
//電機轉(zhuǎn)速一共10檔,通過按鍵調(diào)節(jié)轉(zhuǎn)速
//電機正轉(zhuǎn)時最高位數(shù)碼管顯示0,反轉(zhuǎn)時顯示1
#include<reg51.h>
#define led P0//數(shù)碼管段選
//#define haha P2
sbit s1 = P3^4;sbit s2 = P3^5;sbit s3 = P3^6;sbit s4 = P3^7;//按鍵定義,s1正轉(zhuǎn),s2反轉(zhuǎn),s3加1,s4減1
sbit wei3 = P2^0;sbit wei2 = P2^2;sbit wei1 = P2^4;sbit wei0 = P2^6;//數(shù)碼管位選定義
sbit a = P1^7;sbit b = P1^6;sbit c = P1^5;sbit d = P1^4;//脈沖信號輸入端定義
uchar code tab[11]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xff};//共陽數(shù)碼管驅(qū)動信號0---9,不顯示
uchar code time_counter[10][2]={{0xda,0x1c},{0xde,0xe4},{0xe1,0xec},{0xe5,0xd4},{0xe9,0xbc},  //9.7 ----1ms
           {0xed,0xa4},{0xf1,0x8c},{0xf5,0x74},{0xf9,0x5c},{0xfc,0x18}};
uchar code qudong[8]={0x80,0xc0,0x40,0x60,0x20,0x30,0x10,0x90};
uchar num1 = 0;//控制取勵磁信號變量
uchar num2 = 8;
uchar k=1;//加減檔位控制,1為最小檔
bit flag1 = 0;//初始正轉(zhuǎn),正反轉(zhuǎn)標志
uchar buf[4]={0,10,0,1};//數(shù)碼管顯示緩存,正轉(zhuǎn),不顯示,不顯示,顯示1檔位,高----低
//================================定時器0/1初始化函數(shù)================================
void T0_T1_init()
TMOD = 0x11;//定時器0/1均工作于方式1,16位計時方式
    TH1 = time_counter[k-1][0];
TL1 = time_counter[k-1][1];//定時器1,定時10ms用于步進電機轉(zhuǎn)速控制
TR1 = 1;
ET1= 1;//開定時器中斷
EA = 1;//開總中斷
//================================ms級延時函數(shù)=======================================
void delay1m(uint x)
    uint i,j;
    for(i=0;i<x;i++)      //連數(shù)x次,約 x ms
      for(j=0;j<120;j++);   //數(shù)120 次,約1 ms
void display()
wei3=1;wei2=1;wei1=1;wei0=0;led = tab[buf[3]];delay1m(1);led=0xff;
    wei3=1;wei2=1;wei1=0;wei0=1;led = tab[buf[2]];delay1m(1);led=0xff;
    wei3=1;wei2=0;wei1=1;wei0=1;led = tab[buf[1]];delay1m(1);led=0xff;
wei3=0;wei2=1;wei1=1;wei0=1;led = tab[buf[0]];delay1m(1);led=0xff;
//================================主函數(shù)=============================================
T0_T1_init();
buf[1] = 10;//不顯示
  display();
  if(s1 == 0)
   delay1m(3);
   if(s1 == 0)
    flag1 = 0;//正轉(zhuǎn)
    buf[0] = 0;//最高位顯示0
  //  haha = 0x00;//停止
   while(!s1) display();
  if(s2 == 0 )
   delay1m(3);
   if(s2 == 0)
    flag1 = 1;//反轉(zhuǎn)
    buf[0] = 1;//最高位顯示1
  //  haha = 0x00;//停止
   while(!s2) display();
  if(s3 == 0)    //速度加1檔
   delay1m(3);
   if(s3 == 0)
    k++;
    if(k > 10 )
     k = 1;
    buf[2]= k/10;
    buf[3]= k%10;
   while(!s3) display();
  if(s4 == 0)  //速度減1檔
   delay1m(3);
   if(s4 == 0)
    k--;
    if(k == 0)
     k = 10;
    buf[2]= k/10;
    buf[3]= k%10;
   while(!s4) display();
//==================================定時器1中斷函數(shù),用于脈沖頻率控制=====================================
void time1_interrupt()interrupt 3
static num1 = 0;
static num2 = 0;
TL1 = time_counter[k-1][1];//定時器1,定時1 用于步進電機轉(zhuǎn)速控制
if(flag1 == 0)//正轉(zhuǎn)
  switch(num1)
   case 0:a = 1;b = 0;c = 0;d = 0;break;
   case 1:a = 1;b = 1;c = 0;d = 0;break;
   case 2:a = 0;b = 1;c = 0;d = 0;break;
   case 3:a = 0;b = 1;c = 1;d = 0;break;
   case 4:a = 0;b = 0;c = 1;d = 0;break;
   case 5:a = 0;b = 0;c = 1;d = 1;break;
   case 6:a = 0;b = 0;c = 0;d = 1;break;
   case 7:a = 1;b = 0;c = 0;d = 1;break;
  num1++;
  if(num1 == 8)num1 = 0;
else    //反轉(zhuǎn)
  switch(num2)
   case 0:a = 1;b = 0;c = 0;d = 1;break;
   case 1:a = 0;b = 0;c = 0;d = 1;break;
   case 2:a = 0;b = 0;c = 1;d = 1;break;
   case 3:a = 0;b = 0;c = 1;d = 0;break;
   case 4:a = 0;b = 1;c = 1;d = 0;break;
   case 5:a = 0;b = 1;c = 0;d = 0;break;
   case 6:a = 1;b = 1;c = 0;d = 0;break;
   case 7:a = 1;b = 0;c = 0;d = 0;break;
  num2++;
  if(num2 == 8)num2 = 0;
ID:94031 發(fā)表于 2019-5-15 11:25 | 只看該作者
通過輸入脈沖的頻率可以算出。
ID:538670 發(fā)表于 2019-5-15 19:10 | 只看該作者
xuyaqi 發(fā)表于 2019-5-15 11:25
通過輸入脈沖的頻率可以算出。
可以具體一點在程序中嗎?
ID:538670 發(fā)表于 2019-5-15 20:33 | 只看該作者
通過輸入脈沖的頻率可以算出。
是不是二位數(shù)組2對應十個檔位的,怎么計算出每個檔位的脈沖
