查看: 1220|回復(fù): 0
51單片機(jī)之雙路舵機(jī)程序不穩(wěn)定
ID:515908 發(fā)表于 2019-5-15 21:28 | 顯示全部樓層 |閱讀模式
舵機(jī)程序,不太穩(wěn)定,大佬們看看問題出在哪里
#include<reg52.h>
unsigned char count;
sbit pwm1=P1^0;
sbit pwm2=P1^1;
sbit jia=P3^0;
sbit jan=P3^1;
sbit zuo=P3^2;
sbit you=P3^3;
unsigned char jd1,jd2,m1,m2;
void delay(unsigned int x)
  unsigned char i,j;
  for(i=x;i>0;i--)
     for(j=125;j>0;j--);
void Timer0_Init()
TMOD=0x01;
IE=0x82;
TH0=0xff;
TL0=0x9c;
TR0=1;
void Timer0_Int() interrupt 1
  TH0=0xff;
  TL0=0x9c;
if(m1<jd1)
  pwm1=1;
  pwm1=0;
if(m2<jd2)
  pwm2=1;
  pwm2=0;
  count++;
  count%=200;
  m1=count;
  m2=count;
void keyscan()
if(jia==0)
  delay(50);
  if(jia==0)
   jd1++;
   if(jd1>=26)
     jd1=25;
     while(jia==0);
if(jan==0)
  delay(50);
if(jan==0)
