#include "stm32f0xx.h"
#include "uart.h"
#include "string.h"
#include "stdlib.h"
//如果使用ucos,則包括下面的頭文件即可.
#if 1
#pragma import(__use_no_semihosting)
//標準庫需要的支持函數(shù)
struct __FILE
int handle;
FILE __stdout;
//定義_sys_exit()以避免使用半主機模式
void _sys_exit(int x)
x = x;
//重定義fputc函數(shù)
int fputc(int ch, FILE *f)
while((USART1->ISR&0X40)==0);//循環(huán)發(fā)送,直到發(fā)送完畢
USART1->RDR = (uint8_t) ch;
return ch;
#endif
//串口1中斷服務程序
//注意,讀取USARTx->SR能避免莫名其妙的錯誤
uint8_t USART_RX_BUF[USART_REC_LEN]; //接收緩沖,最大USART_REC_LEN個字節(jié).
//接收狀態(tài)
//bit15, 接收完成標志
//bit14, 接收到0x0d
//bit13~0, 接收到的有效字節(jié)數(shù)目
uint16_t USART_RX_STA=0; //接收狀態(tài)標記
//初始化IO 串口1
//bound:波特率
void uart_init(uint32_t bound){
//GPIO端口設置
USART_InitTypeDef USART_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB, ENABLE); //使能GPIOA時鐘
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,ENABLE);//使能USART1時鐘
//串口1對應引腳復用映射
GPIO_PinAFConfig(GPIOB,GPIO_PinSource6,GPIO_AF_1); //GPIOB6復用為USART1
GPIO_PinAFConfig(GPIOB,GPIO_PinSource7,GPIO_AF_1); //GPIOB7復用為USART1
//USART1端口配置
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7; //GPIOB6與GPIOB7
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;//復用功能
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //速度50MHz
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; //推挽復用輸出
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; //上拉
GPIO_Init(GPIOB,&GPIO_InitStructure); //初始化PB6,PB7
//Usart1 NVIC 配置
NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;//串口1中斷通道
NVIC_InitStructure.NVIC_IRQChannelPriority=0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道使能
NVIC_Init(&NVIC_InitStructure); //根據(jù)指定的參數(shù)初始化VIC寄存器、
//USART1 初始化設置
USART_InitStructure.USART_BaudRate = bound;//波特率設置
USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字長為8位數(shù)據(jù)格式
USART_InitStructure.USART_StopBits = USART_StopBits_1;//一個停止位
USART_InitStructure.USART_Parity = USART_Parity_No;//無奇偶校驗位
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//無硬件數(shù)據(jù)流控制
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //收發(fā)模式
USART_Init(USART1, &USART_InitStructure); //初始化串口1、
USART_ITConfig(USART1,USART_IT_RXNE,ENABLE);
USART_Cmd(USART1, ENABLE); //使能串口1
//USART_ClearFlag(USART1, USART_FLAG_TC);
void USART1_IRQHandler(void) //串口1中斷服務程序
uint8_t Res;
if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET) //接收中斷(接收到的數(shù)據(jù)必須是0x0d 0x0a結尾)
Res =USART_ReceiveData(USART1);//(USART1->DR); //讀取接收到的數(shù)據(jù)
if((USART_RX_STA&0x8000)==0)//接收未完成
if(USART_RX_STA&0x4000)//接收到了0x0d
if(Res!=0x0a)USART_RX_STA=0;//接收錯誤,重新開始
else USART_RX_STA|=0x8000; //接收完成了
else //還沒收到0X0D
if(Res==0x0d)USART_RX_STA|=0x4000;
USART_RX_BUF[USART_RX_STA&0X3FFF]=Res ;
USART_RX_STA++;
if(USART_RX_STA>(USART_REC_LEN-1))USART_RX_STA=0;//接收數(shù)據(jù)錯誤,重新開始接收
