查看: 1733|回復(fù): 1
基于51單片機(jī)的溫度傳感系統(tǒng)
ID:371051 發(fā)表于 2019-5-23 18:43 | 只看該作者 回帖獎勵 |倒序?yàn)g覽 |閱讀模式
數(shù)碼管顯示當(dāng)前溫度,可設(shè)置報警溫度,蜂鳴器和燈會工作
  1. #include"reg52.h"
  2. #include"temp.h"
  3. sbit LSA=P2^2;
  4. sbit LSB=P2^3;
  5. sbit LSC=P2^4;
  6. sbit led=P2^0;
  7. sbit beep=P1^5;
  8. sbit led1=P2^1;
  9. char num=0;
  10. typedef unsigned int u16;          //對數(shù)據(jù)類型進(jìn)行聲明定義
  11. typedef unsigned char u8;
  12. u16 flag;
  13. u8 receiveData;//     改
  14. u8 n[]="a";
  15. u8 nn[]="b";
  16. u8 DisplayData[8];
  17. u8 code smgduan[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
  18. void initserialport();
  19. void DigDisplay();
  20. void display(int temp);
  21. void delay(u16 i)
  22. {
  23.         while(i--);
  24. }
  25. void main()
  26. {
  27. int tem;
  28.         initserialport();
  29.         while(1)
  30.         {
  31.                 if(flag==0)
  32.                 {
  33.
  34.                         led1=0;
  35.                 }
  36.                 if(flag==1){
  37.
  38.                         led1=1;
  39.                 }
  40.                 display(Ds18b20ReadTemp());         //數(shù)據(jù)處理函數(shù)
  41.                 DigDisplay();//數(shù)碼管顯示函數(shù)
  42.         }
  43.         tem=Ds18b20ReadTemp();
  44.         display(tem);
  45.                 Delay1ms(1);
  46.         }
  47. void initserialport()
  48. {
  49.         SCON=0x50;
  50.         TMOD=0x20;
  51.         PCON=0X80;
  52.         ES=1;
  53.         TR1=1;
  54.         EA=1;
  55.         TL1=0xf3;
  56.         TH1=0xf3;
  57. }
  58. void sound()
  59. {
  60.         u8 i=100;
  61.         while(i--)
  62.         {
  63.                 beep=~beep;
  64.                 led=~led;
  65.                 delay(100);
  66.         }
  67. }
  68. void display(int temp)
  69. {
  70.         float x;
  71.         if(temp<0)
  72.         {
  73.                 temp=~temp;
  74.                 temp=temp+1;
  75.                 x=temp;
  76.                 temp=x*0.0625*100+0.5;
  77.         }
  78.         else
  79.         {
  80.                         x=temp;
  81.                 temp=x*0.0625*100+0.5;
  82.         }
  83.
  84.         if(temp>3000)
  85.         {
  86.         sound();
  87.         }
  88.         DisplayData[1] = smgduan[temp / 10000];
  89.         DisplayData[2] = smgduan[temp % 10000 / 1000];
  90.         DisplayData[3] = smgduan[temp % 1000 / 100] | 0x80;
  91.         DisplayData[4] = smgduan[temp % 100 / 10];
  92.         DisplayData[5] = smgduan[temp % 10];
  93.         if(temp<0)
  94.         {
  95.                 SBUF='-';
  96.         while(!TI);
  97.         TI=0;
  98.         }
  99.         if(temp>0)
  100.         {
  101.                 SBUF='+';
  102.         while(!TI);
  103.         TI=0;
  104.         }
  105.
  106.         SBUF=temp/1000%10+'0';
  107.         while(!TI);
  108.         TI=0;
  109.
  110.         SBUF=temp%1000/100+'0';
  111.         while(!TI);
  112.         TI=0;
  113.
  114.         SBUF='.';
  115.         while(!TI);
  116.         TI=0;
  117.
  118.         SBUF=temp%100/10+'0';
  119.         while(!TI);
  120.         TI=0;
  121.
  122.         SBUF=temp%10+'0';
  123.         while(!TI);
  124.         TI=0;
  125. }
  126. void DigDisplay()
  127. {
  128.         u8 i;
  129.         for(i=0;i<6;i++)
  130.         {
  131.                 switch(i)         //位選,選擇點(diǎn)亮的數(shù)碼管,
  132.                 {
  133.                         case(0):
  134.                                 LSA=0;LSB=0;LSC=0; break;//顯示第0位
  135.                         case(1):
  136.                                 LSA=1;LSB=0;LSC=0; break;//顯示第1位
  137.                         case(2):
  138.                                 LSA=0;LSB=1;LSC=0; break;//顯示第2位
  139.                         case(3):
  140.                                 LSA=1;LSB=1;LSC=0; break;//顯示第3位
  141.                         case(4):
  142.                                 LSA=0;LSB=0;LSC=1; break;//顯示第4位
  143.                         case(5):
  144.                                 LSA=1;LSB=0;LSC=1; break;//顯示第5位
  145.                 }
  146.                 P0=DisplayData[5-i];//發(fā)送數(shù)據(jù)
  147.                 Delay1ms(20); //間隔一段時間掃描
  148.                 P0=0x00;//消隱
  149.         }
  150. }
  151. void UsartInit()
  152. {
  153.         SCON=0X50;
  154.         TMOD=0X20;
  155.         PCON=0X80;
  156.         TH1=0XF3;
  157.         TL1=0XF3;
  158.         ES=1;
  159.         EA=1;
  160.         TR1=1;
  161. }
  162. void ma()
  163. {
  164.         UsartInit();
  165.         while(1);
  166. }
  167. void Usart() interrupt 4
  168. {
  169.         unsigned char m;
  170.         m=SBUF;
  171.               RI = 0;
  172.         if(m==n[0])
  173.         {
  174.                 flag=0;
  175.         }
  176.         if (m==nn[0])
  177.         {
  178.                 flag=1;
  179.         }
  180.
  181.                         }
小項(xiàng)目硬件部分.zip (56.56 KB, 下載次數(shù): 4)
ID:1 發(fā)表于 2019-5-30 18:28 | 只看該作者
本帖需要重新編輯補(bǔ)全電路原理圖,源碼,詳細(xì)說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
