查看: 2327|回復(fù): 0
stm32f103c8 固件庫(kù) I2C相關(guān)問(wèn)題
ID:141497 發(fā)表于 2019-5-27 22:12 | 顯示全部樓層 |閱讀模式
請(qǐng)教各位大大:由于近期要用STM32做一個(gè)項(xiàng)目用到I2C協(xié)議,調(diào)用固件庫(kù)I2C協(xié)議編程,最后發(fā)現(xiàn)是I2C部分程序問(wèn)題,單獨(dú)測(cè)試I2C讀寫24C02失敗.好幾天了沒(méi)有查出原因,請(qǐng)教各位是怎么回事?謝謝了!!!
下面是我寫的代碼:
1 STM32F103C8T6 i2c1(at24c02) TEST HSE8M*9M=72m;
2 display:max7219模塊;
#include "stm32f10x.h"
#include "stm32f10x_i2c.h"
#include "stm32f10x_spi.h"
#include "stm32f10x_gpio.h"
#include "stm32f10x_rcc.h"
uchar leddula[]={0x7e,0x30,0x6d,0x79,0x33,0x5b,0x5f,0x70,0x7f,0x7b,
0x77,0x1f,0x4e,0x3d,0x4f,0x47,0x67,0x3e};//0123456789ABCDEFPU
uchar cf=0x20;
void sysinit(void);
void clock(void);
void sgpio(void);
void sysspi(void);
void init7219(void);
void i2cinit(void);
void delay(vu32 nCount);
void ackst(void);//ACK
void i2cwritebyte(uchar addr,uchar date);
uchar i2creadbyte(uchar addr);
void display(void);
void maxdisp(uchar a,uchar b,uchar c,uchar d,uchar e,uchar f,uchar g,uchar h);
void clear7219(void);
void sendbyte(uchar datt);
void sendword(uchar addr,uchar dat);
int main(void)
        sysinit();
                        display();
void sysinit(void)
        clock();
        sgpio();
        sysspi();
        i2cinit();
void clock(void)
        RCC_HSEConfig(RCC_HSE_ON);
        while(RCC_GetFlagStatus(RCC_FLAG_HSERDY)==RESET);
        RCC_PLLCmd(ENABLE);
        RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);//8m*9m=72m
        while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY)==RESET);
        RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
        RCC_HSICmd(DISABLE);
void sgpio(void)//GPIO
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB,ENABLE);
        GPIO_InitTypeDef GPIO_Initstructure;
        GPIO_Initstructure.GPIO_Pin=GPIO_Pin_5|GPIO_Pin_7;//5 clk,6 mosi
        GPIO_Initstructure.GPIO_Mode=GPIO_Mode_AF_PP;
        GPIO_Initstructure.GPIO_Speed=GPIO_Speed_50MHz;
        GPIO_Init(GPIOA,&GPIO_Initstructure);
        GPIO_Initstructure.GPIO_Pin=GPIO_Pin_6;//6 miso
        GPIO_Initstructure.GPIO_Mode=GPIO_Mode_IN_FLOATING;;
        GPIO_Initstructure.GPIO_Pin=GPIO_Pin_4;//4 cs
        GPIO_Initstructure.GPIO_Mode=GPIO_Mode_Out_PP;
        GPIO_SetBits(GPIOA, GPIO_Pin_4);//cs=1
        GPIO_Initstructure.GPIO_Pin=GPIO_Pin_6|GPIO_Pin_7;//I2C1 6SCL 7SDA
        GPIO_Init(GPIOB,&GPIO_Initstructure);
        GPIO_Initstructure.GPIO_Mode=GPIO_Mode_AF_OD;
void i2cinit(void)//I2C
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1,ENABLE);
        I2C_InitTypeDef I2C_InitStructure;
        I2C_InitStructure.I2C_ClockSpeed=50000;//50khz
  I2C_InitStructure.I2C_Mode=I2C_Mode_I2C;
  I2C_InitStructure.I2C_DutyCycle=I2C_DutyCycle_2;
  I2C_InitStructure.I2C_OwnAddress1=0xcd;
  I2C_InitStructure.I2C_Ack=I2C_Ack_Disable;
        I2C_InitStructure.I2C_AcknowledgedAddress=I2C_AcknowledgedAddress_7bit;
        I2C_Init(I2C1, &I2C_InitStructure);
        GPIO_SetBits(GPIOB, GPIO_Pin_6|GPIO_Pin_7);
        I2C_Cmd(I2C1, ENABLE);
        i2cwritebyte(0x40,0x20);
void sysspi(void)//SPI
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1,ENABLE);
        SPI_InitTypeDef SPI_InitStructure;
  SPI_InitStructure.SPI_Direction=SPI_Direction_2Lines_FullDuplex;
        SPI_InitStructure.SPI_Mode=SPI_Mode_Master;
        SPI_InitStructure.SPI_DataSize=SPI_DataSize_8b;
        SPI_InitStructure.SPI_CPOL=SPI_CPOL_High;
        SPI_InitStructure.SPI_CPHA=SPI_CPHA_1Edge;
        SPI_InitStructure.SPI_NSS=SPI_NSS_Soft;
        SPI_InitStructure.SPI_BaudRatePrescaler=SPI_BaudRatePrescaler_2;
        SPI_InitStructure.SPI_FirstBit=SPI_FirstBit_MSB;
        SPI_InitStructure.SPI_CRCPolynomial=7;
        SPI_Init(SPI1,&SPI_InitStructure);
        SPI_Cmd(SPI1,ENABLE);
        init7219();
void ackst(void)//ACK
        if(I2C_GetFlagStatus(I2C1,I2C_FLAG_AF)==RESET)
                        I2C_ClearFlag(I2C1,I2C_FLAG_AF);
                        I2C_GenerateSTOP(I2C1,ENABLE);
        I2C_GenerateSTART(I2C1,ENABLE);
        while(I2C_GetFlagStatus(I2C1,I2C_FLAG_SB)==RESET);//START OK
        I2C_ClearFlag(I2C1,I2C_FLAG_SB);
        I2C_Send7bitAddress(I2C1,0xa0,I2C_Direction_Transmitter);
        while(I2C_GetFlagStatus(I2C1,I2C_FLAG_ADDR)==RESET);//addr OK
        I2C_ClearFlag(I2C1,I2C_FLAG_ADDR);
        ackst();
        I2C_SendData(I2C1, addr);
        ackst();
        ackst();
        I2C_ClearFlag(I2C1,I2C_FLAG_BTF);
  uchar data;
        ackst();
        ackst();
        while(I2C_GetFlagStatus(I2C1,I2C_FLAG_SB)==RESET);//R START OK
        I2C_Send7bitAddress(I2C1,0xa1,I2C_Direction_Receiver);
        while(I2C_GetFlagStatus(I2C1,I2C_FLAG_ADDR)==RESET);//addr CMD OK
        while(I2C_GetFlagStatus(I2C1,I2C_FLAG_BTF)==RESET);//等待數(shù)據(jù)接收完成
        delay(20);
        data=I2C_ReceiveData(I2C1);
        return data;
void display(void)//顯示
  uchar second,t0,t1,t4,t5;
  second=i2creadbyte(0x40);
  t0=second/10;
  t1=second%10;
  t4=cf/10;
  t5=cf%10;
        maxdisp(leddula[t1],leddula[t0],0x01,0x01,0x01,0x01,leddula[t5],leddula[t4]);
void init7219(void)//顯示初始化
        sendword(0x0c,0x01);
        sendword(0x0a,0x01);
        sendword(0x0b,0x07);
        sendword(0x09,0x00);
        sendword(0x0f,0x00);
void delay(vu32 nCount)//廷時(shí)
        while(nCount--);
        while(SPI_I2S_GetFlagStatus(SPI1,SPI_I2S_FLAG_TXE)==RESET);
        SPI_I2S_SendData(SPI1,datt);
        delay(20);
        GPIO_ResetBits(GPIOA, GPIO_Pin_4);
  sendbyte(addr);
  sendbyte(dat);
  uchar i;
        for(i=1;i<9;i++)
                        sendword(i,0x00);
                clear7219();
                sendword(0x01,a);
                sendword(0x02,b);
                sendword(0x03,c);
                sendword(0x04,d);
                sendword(0x05,e);
                sendword(0x06,f);
                sendword(0x07,g);
                sendword(0x08,h);
