基于51單片機的led燈控制,
單片機源程序如下:
- * @file: led燈控制器.c
- * @function: 控制led
- * @date: 2019.5.22
- * @version: v1.0
- * @author: xiaohuli
- #include<reg51.h>
- sbit key2=P3^0; //定義獨立按鍵端口
- sbit key3=P3^2;
- sbit key1=P3^1;
- sbit key4=P3^3;
- unsigned char led2[]={
- 0x7f,0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf}; //定義led向右移動
- unsigned char led1[]={
- 0xfe,0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd}; //定義led向左移動
- unsigned char led3[]={
- 0xf7,0xe7,0xe3,0xc3,0xc1,0x81,0x80,0x00}; // 模式2led
- unsigned char led4[]={
- 0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f}; // 模式3led
- unsigned char led5[]={
- 0xfe,0xdf,0xfb,0x7f,0xef,0xfd,0xbf,0xf7}; // 模式3led
- * @file: delay(unsigned int z)
- * @function: 延時
- * @version: v1.0
- void delay(unsigned int z)
- unsigned int y;
- for(;z>0;z--)
- for(y=10;y>0;y--);
- * @file: Timer0Init()
- * @function: 定時器初始化
- * @version: v1.0
- void Timer0Init()
- TMOD|=0X01;//選擇為定時器0模式,工作方式1,僅用TR0打開啟動。
- TH0=0XFC; //給定時器賦初值,定時1ms
- TL0=0X18;
- ET0=1;//打開定時器0中斷允許
- EA=1;//打開總中斷
- TR0=1;//打開定時器
- * @file: interface()
- * @function: 初始界面
- * @version: v1.0
- void interface()
- int i,j;
- for(i=0;i<2;i++)
- for(j=0;j<8;j++)
- P2=led1[j];
- delay(1000);
- i=0; //將ij置0,方便下一次循環(huán)
- j=0;
- for(i=0;i<2;i++)
- for(j=0;j<8;j++)
- P2=led2[j];
- delay(1000);
- i=0;
- j=0;
- for(i=0;i<5;i++)
- P2=0xaa;
- delay(2000);
- P2=0xff;
- delay(2000);
- for(j=0;j<5;j++)
- P2=0x55;
- delay(2000);
- P2=0xff;
- delay(2000);
- * @file: pattern1()
- * @function: 模式1
- * @version: v1.0
- void pattern1()
- P2=0xaa;
- delay(5000);
- P2=0x55;
- delay(5000);
- * @file: pattern2()
- * @function: 模式2
- * @version: v1.0
- void pattern2()
- int i,j;
- for(j=0;j<3;j++)
- for(i=0;i<8;i++)
- P2=led3[i];
- delay(5000);
- if(i==8)
- P2=0xff;
- delay(5000);
- * @file: pattern3()
- * @function: 模式3
- * @version: v1.0
- void pattern3()
- int i,j;
- int flag; // 定義向左向右的標(biāo)志變量
- int keyflag; // 定義處理按鍵按下的標(biāo)志變量
- int count;
- if(key3==0)
- delay(10); //延時消抖
- if(key3==0)
- keyflag=1;
- TR0=1; //開啟定時器
- while(!key3);
- TR0=0; //關(guān)閉定時器
- if(key4==0)
- delay(10);
- if(key4==0)
- keyflag=2;
- TR0=1;
- while(!key4);
- TR0=0;
- if(keyflag==1) //處理按鍵
- if(count>=1500) //長按處理程序
- i++;
- if(i>=4)
- i=3;
- else //短按處理程序
- i++;
- if(i>=4)
- i=3;
- keyflag=0; //將標(biāo)志變量置0;
- count=0;
- if(keyflag==2)
- if(count>=1500)
- flag++;
- if(flag==2)
- flag=0;
- else
- flag++;
- if(flag==2)
- flag=0;
- keyflag=0;
- count=0;
- switch(i) //對i,進(jìn)行分類處理,判斷是左移或右移幾位
- case 0:
- if(flag==0)
- for(j=0;j<8;j++)
- P2=led4[j];
- delay(5000);
- j=0;
- if(flag==1)
- for(j=0;j<8;j++)
- P2=led1[j];
- delay(5000);
- j=0;
- break;
- case 1:
- if(flag==0)
- for(j=0;j<8;j=j+2)
- P2=led4[j];
- delay(5000);
- j=0;
- if(flag==1)
- P2=led1[j];
- delay(5000);
- j=0;
- break;
- case 2: //這個算法可以直接定義一個一維數(shù)組代替
- if(flag==0)
- for(j=0;j<22;j=j+3)
- if(j==9)
- P2=0xfd;
- delay(5000);
- else
- if(j==12)
- P2=0xef;
- delay(5000);
- else
- if(j==15)
- P2=0x7f;
- delay(5000);
- else
- if(j==18)
- P2=0xfb;
- delay(5000);
- else
- if(j==21)
- P2=0xdf;
- delay(5000);
- else
- P2=led4[j];
- delay(5000);
- j=0;
- if(flag==1)
- for(j=0;j<8;j++)
- P2=led5[j];
- delay(5000);
- j=0;
- break;
- case 3:
- if(flag==0)
- for(j=0;j<8;j=j+4)
- P2=led4[j];
- delay(5000);
- j=0;
- if(flag==1)
- P2=led1[j];
- delay(5000);
- j=0;
- break;
- * @file: 主函數(shù)
- * @function: 主函數(shù)
- * @version: v1.0
- void main()
- Timer0Init();
- interface();
- while(1)
- int keyflag2;
- int k;
- int count;
- if(key1==0)
- delay(10);
- if(key1==0)
- keyflag2=1;
- TR0=1;
- while(!key1);
- TR0=0;
- if(key2==0)
- delay(10);
- if(key2==0)
- keyflag2=2;
- TR0=1;
- while(!key2);
- TR0=0;
- if(keyflag2==1)
- if(count>=1500)
- pattern1();
- else
- pattern1();
- //keyflag2=0; 注意,這個標(biāo)志變量不能置0,否則·不會·無限循環(huán)
- count=0;
- if(keyflag2==2)
- if(count>=1500)
- for(k=0;k<1;k++)
- pattern2();
- pattern3();
- else
- for(k=0;k<1;k++)
- pattern2();
- for(k=0;k<100;k++)
- pattern3();
- keyflag2=0;
- count=0;
- * @file: Timer0() interrupt 1
- * @function: 定時器0的1模式中斷
- * @version: v1.0
- void Timer0() interrupt 1
- static int i;
- TL0=0X18;
- i++;
led燈控制器.zip
(27.01 KB, 下載次數(shù): 9)
2019-5-27 23:50 上傳
點擊文件名下載附件
