查看: 3001|回復: 0
SHT3x溫濕度傳感器pdf資料手冊下載
ID:165814 發(fā)表于 2019-5-29 18:31 | 顯示全部樓層 |閱讀模式
SHT溫濕度傳感器數(shù)據(jù)手冊摘要:
Datasheet SHT3x-DIS
Humidity and Temperature Sensor
  Fully calibrated, linearized, and temperature compensated digital output
  Wide supply voltage range, from 2.4 V to 5.5 V
  I2C Interface with communication speeds up to 1 MHz and two user selectable addresses
  Typical accuracy of  1.5 %RH and  0.2 °C for SHT35
  Very fast start-up and measurement time
  Tiny 8-Pin DFN package
完整的pdf格式文檔51黑下載地址:
SHT3x_DIS.pdf (910.44 KB, 下載次數(shù): 16)
admin + 50 共享資料的黑幣獎勵!
