#include<reg52.h>
#include<intrins.h>
sfr P1ASF=0X9D; //P1口模擬功能控制寄存器
sfr ADC_CONTR=0XBC; //ADC控制寄存器
sfr ADC_RES=0XBD; //AD轉(zhuǎn)換結果存放
sfr ADC_RESL=0XBE; //AD轉(zhuǎn)換結果存放
sfr AUXR1=0XA2;
//sfr IE=0XA8;
//sfr IPH=0XB7; //中斷優(yōu)先級控制寄存器高
//sfr IP=0XB8; //中斷優(yōu)先級控制寄存器低
uchar temp;
unsigned int result=0,resulth=0;
void delay1ms(uint z) //誤差 0us
unsigned char a,b,c;
for(c=z;c>0;c--)
for(b=142;b>0;b--)
for(a=2;a>0;a--);
void ADinit()
P1ASF=0x01; //P1^0口作為AD輸入口
ADC_CONTR=0x20; //P1^0口作為AD輸入口,360個時鐘周期轉(zhuǎn)換一次
AUXR1=0x00; //高八位存放于ADC_RES,低二位存放于ADC_RESL
IE=0XA0; //開總中斷允許AD中斷
void ADser() interrupt 5
P2=0xaa;
_nop_();
_nop_();
_nop_();
_nop_(); //延時4個時鐘周期,使其趨于穩(wěn)定
temp=(ADC_CONTR|0X10)<<4; //此時ADC_FLAG的值被移入CY位;
ADC_CONTR=0xC0; //轉(zhuǎn)換完成,將ADC_FLAG清零
resulth=ADC_RES; //讀取高8位值
P2=ADC_RES;
result=(unsigned int)(resulth*5/256);
P2=result; //把ADC_RES的值以點亮小燈的形式顯示出來
ADinit();
ADC_CONTR=0XA8;;//開始AD轉(zhuǎn)換
delay1ms(1000); //以下延時非必須,為測試程序而加,
delay1ms(1000);
delay1ms(1000);
delay1ms(1000);
delay1ms(1000);
delay1ms(1000);
delay1ms(1000);
delay1ms(1000);
delay1ms(1000);
delay1ms(1000);
delay1ms(1000);
delay1ms(1000);
delay1ms(1000);
delay1ms(1000);
delay1ms(1000);
delay1ms(1000);
delay1ms(1000);
delay1ms(1000);
delay1ms(1000);
delay1ms(1000);
delay1ms(1000);
delay1ms(1000);
delay1ms(1000);
delay1ms(1000);
ADC_CONTR=0X20;;//關閉AD轉(zhuǎn)
P2=0xff;
delay1ms(1000);
delay1ms(1000);
delay1ms(1000);
delay1ms(1000);
delay1ms(1000);
delay1ms(1000);
delay1ms(1000);
delay1ms(1000);
delay1ms(1000);
delay1ms(1000);
delay1ms(1000);
delay1ms(1000);
delay1ms(1000);
delay1ms(1000);
delay1ms(1000);
delay1ms(1000);
delay1ms(1000);
delay1ms(1000);
delay1ms(1000);
delay1ms(1000);
delay1ms(1000);
delay1ms(1000);
delay1ms(1000);
delay1ms(1000);
我用的是普中的板子,P2口接有8個共陽極的LED燈,不同的結果會有不同的現(xiàn)象,可以通過小燈的亮滅讀取結果
