stm32智能鎖AS608指紋識(shí)別 按鍵 APP開(kāi)鎖
- #include "sys.h"
- #include "delay.h"
- #include "beep.h"
- #include "usart2.h"
- #include "key.h"
- #include "led.h"
- #include "stmflash.h"
- #include "string.h"
- #include "oled.h"
- #include "as608.h"
- #include "timer2.h"
- #include "usart.h"
- #include "bmp.h"
- #include "adc.h"
- #include "usart3.h"
- #include "timer3.h"
- #include "gizwits_product.h"
- u8 *in_pwd1=0;
- u8 *in_pwd2=0;
- u8 *in_pwd3=0;
- u8 *in_pwd4=0;
- u8 *in_pwd5=0;
- u8 *in_pwd6=0;
- u8 *in_pwd7=0;
- u8 *in_pwd8=0;
- u8 *str=0;
- int fall_time=0;
- int in_time=0;
- int mykey=0;//控制in_time每按一個(gè)按鍵只加一次的坎兒
- u8 root_pwd[8]="66666666";//管理員密碼
- u8 open_pwd[8]="";//開(kāi)鎖密碼
- #define SIZE_PWD sizeof(open_pwd)
- #define FLASH_SAVE_ADDR 0X08070000
- #define usart2_baund 57600//串口2波特率,根據(jù)指紋模塊波特率更改
- SysPara AS608Para;//指紋模塊AS608參數(shù)
- u16 ValidN;//模塊內(nèi)有效指紋個(gè)數(shù)
- void root_h(void);//管理員函數(shù)
- void Add_FR(void); //錄指紋
- void Del_FR(void); //刪除指紋
- void press_FR(void);//刷指紋
- u16 GET_NUM(void);//獲取數(shù)值
- void AS608_Details(void);//獲取模塊詳情
- extern u8 find_string_flag;
- extern u8 receive_mode;
- //協(xié)議初始化
- void Gizwits_Init(void)
- TIM3_Int_Init(9,7199);//1MS系統(tǒng)定時(shí)
- usart3_init(9600);//WIFI初始化
- userInit();//設(shè)備狀態(tài)結(jié)構(gòu)體初始化
- gizwitsInit();//緩沖區(qū)初始化
- int main(void)
- u8 key_num=0;
- u8 *str=0;
- int ret;
- u16 adcx;
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//設(shè)置系統(tǒng)中斷優(yōu)先級(jí)分組2
- delay_init(); //初始化延時(shí)函數(shù)
- usart2_init(usart2_baund);//初始化串口2,用于與指紋模塊通訊
- USART1_Init_Config(115200); //串口1,用于與A6模塊通信
- Timer2_Init_Config(); //定時(shí)器2初始化,用于A6模塊
- PS_StaGPIO_Init(); //初始化FR讀狀態(tài)引腳
- BEEP_Init(); //初始化蜂鳴器
- KEY_Init();
- OLED_Init();
- LED_Init();
- Adc_Init();
- Gizwits_Init(); //協(xié)議初始化
- receive_mode = 1;
- OLED_Clear();
- //與AS608模塊握手
- do
- Moto=1;
- OLED_ShowString(0,0,"AS608 Ready",8);
- delay_ms(400);
- OLED_Clear();
- OLED_ShowString(0,2,"try connection",8);
- OLED_ShowString(0,5,"wait...",8);
- delay_ms(800);
- OLED_Clear();
- while(PS_HandShake(&AS608Addr));
- while(1)
- STMFLASH_Read(FLASH_SAVE_ADDR,(u16*)open_pwd,SIZE_PWD);
- OLED_ShowString(0,0,"Enter 8 password",16);
- OLED_ShowString(0,2,"Fingerprint",16);
- OLED_ShowNum(0,5,adcx,4,12);//顯示ADC的值
- OLED_DrawBMP(88,3,128,8,BMP2);
- /***************************指紋解鎖*************************************/
- if(PS_Sta) //檢測(cè)PS_Sta狀態(tài),如果有手指按下
- press_FR();//刷指紋
- /***************************短信解鎖*************************************/
- /* set_text_mode();//設(shè)置短信
- CLR_Buf();
- if(find_string_flag == 1)
- delay_ms(200);//延時(shí)一點(diǎn),讓串口把數(shù)據(jù)接收完成
- if(Find("+CMTI"))//說(shuō)明接收到了短信
- ret = read_message();
- if(ret == 1)
- if(Find("ledon"))
- CLR_Buf();
- find_string_flag = 0;
- delay_ms(200);
- OLED_Clear();//清除之前輸入的密碼
- OLED_ShowString(30,0,"Welcome",8);
- OLED_ShowString(0,2,"open the door!",8);
- delay_ms(1000);
- OLED_Clear();
- if(Find("ledoff"))
- CLR_Buf();
- delay_ms(200);
- OLED_ShowString(0,2,"close the door!",8);
- delay_ms(1000);
- OLED_Clear();
- /***************************密碼解鎖**********************************/
- key_num=keyscan();
- if(key_num)
- switch(key_num)
- case 1:Del_FR(); key_num=0;break; //刪指紋
- case 2:AS608_Details(); key_num=0;break; //詳情
- case 3:Add_FR(); key_num=0;break; //錄指紋
- case 13:gizwitsSetMode(WIFI_AIRLINK_MODE);//Air-link模式接入
- LED0 = 0;
- delay_ms(1000);
- LED0 = 1;
- key_num=0;
- break;
- case 16: ret = check_status();
- if(ret == 1)
- ret = send_text_message("SOS!This is a message for help");
- delay_ms(1000);
- delay_ms(1000);
- key_num=0;
- break;
- default: break;
- if(key_num>0)
- switch(key_num)
- case 14:str="0";break;
- case 4:str="1";break;
- case 5:str="2";break;
- case 6:str="3";break;
- case 7:str="4";break;
- case 8:str="5";break;
- case 9:str="6";break;
- case 10:str="7";break;
- case 11:str="8";break;
- case 12:str="9";break;
- default: break;
- if(mykey==0)
- in_time++;
- switch(in_time)
- case 1:in_pwd1=str;OLED_ShowString(0,8,str,8);delay_ms(200);OLED_ShowString(0,8,"*",8);break;
- case 2:in_pwd2=str;OLED_ShowString(11,8,str,8);delay_ms(200);OLED_ShowString(11,8,"*",8);break;
- case 3:in_pwd3=str;OLED_ShowString(23,8,str,8);delay_ms(200);OLED_ShowString(23,8,"*",8);break;
- case 4:in_pwd4=str;OLED_ShowString(35,8,str,8);delay_ms(200);OLED_ShowString(35,8,"*",8);break;
- case 5:in_pwd5=str;OLED_ShowString(47,8,str,8);delay_ms(200);OLED_ShowString(47,8,"*",8);break;
- case 6:in_pwd6=str;OLED_ShowString(59,8,str,8);delay_ms(200);OLED_ShowString(59,8,"*",8);break;
- case 7:in_pwd7=str;OLED_ShowString(71,8,str,8);delay_ms(200);OLED_ShowString(71,8,"*",8);break;
- case 8:in_pwd8=str;OLED_ShowString(83,8,str,8);delay_ms(200);OLED_ShowString(83,8,"*",8);break;
- mykey=1;//設(shè)置為1防止再次進(jìn)入
- if(in_time==8)
- if( //普通用戶配對(duì)成功
- *in_pwd3==open_pwd[2]&&
- *in_pwd4==open_pwd[3]&&
- *in_pwd5==open_pwd[4]&&
- *in_pwd6==open_pwd[5])
- fall_time=0;
- delay_ms(200);
- Moto=0;
- delay_ms(1000);
- Moto=1;
- delay_ms(1000);
- OLED_Clear();
- else if( *in_pwd1==root_pwd[0]&&//管理員用戶配對(duì)成功
- *in_pwd2==root_pwd[1]&&
- *in_pwd3==root_pwd[2]&&
- *in_pwd4==root_pwd[3]&&
- *in_pwd5==root_pwd[4]&&
- *in_pwd6==root_pwd[5]&&
- *in_pwd7==root_pwd[6]&&
- *in_pwd8==root_pwd[7])
- root_h();
- else//配對(duì)失敗
- delay_ms(200);
- OLED_ShowString(0,0,"*Wrong Password*",8);
- OLED_ShowString(0,3,"please try again",8);
- fall_time++;
- LED0=!LED0;//紅燈閃爍提示
- delay_ms(300);
- LED0=!LED0;
- delay_ms(300);
- LED0=!LED0;
- delay_ms(300);
- LED0=!LED0;
- LED0=1;
- OLED_Clear();
- in_time=0;
- if(fall_time==5)
- ret = check_status();
- if(ret == 1)
- ret = send_text_message("You have entered 5 error passwords");
- delay_ms(1000);
- delay_ms(1000);
- fall_time=0;
- OLED_Clear();//清除準(zhǔn)備顯示鎖定
- fall_for_10s();
- LED0=1;
- OLED_Clear();//清除Has been locked please wait
- }else{ delay_ms(10); mykey=0;}
- /***************************緊急情況**********************************/
- adcx=Get_Adc_Average(ADC_Channel_9,10);
- if(adcx>1500)
- OLED_Clear();
- delay_ms(200);
- OLED_ShowString(0,0,"Warning",8);
- if(ret == 1)
- ret = send_text_message("Harmful gas is high, please pay attention to ventilation");
- delay_ms(1000);
- delay_ms(1000);
- OLED_Clear();
- userHandle();//用戶采集
- gizwitsHandle((dataPoint_t *)¤tDataPoint);//協(xié)議處理
- /***************************** 主函數(shù)結(jié)束 ***********************************************/
- /******************************獲取數(shù)值*************************************/
- u16 GET_NUM(void)
- u8 key_num=0;
- u16 num=0;
- while(1)
- if(key_num)
- if(key_num==1)return 0xFFFF;//‘返回’鍵
- if(key_num==3)return 0xFF00;//
- if(key_num>3&&key_num<13&&num<99)//‘1-9’鍵(限制輸入3位數(shù))
- num =num*10+key_num-3;
- if(key_num==13)num =num/10;//‘Del’鍵
- if(key_num==14&&num<99)num =num*10;//‘0’鍵
- if(key_num==15)return num; //‘Enter’鍵
- /******************************管理員**************************************/
- void root_h(void)//管理員用戶函數(shù)
- u8 key_num;
- in_time=0;
- mykey=0;
- in_pwd1="0";
- in_pwd2="0";
- in_pwd3="0";
- in_pwd4="0";
- in_pwd5="0";
- in_pwd6="0";
- in_pwd7="0";
- in_pwd8="0";
- Moto=0;
- delay_ms(1000);
- Moto=1;
- OLED_Clear();// 清除普通用戶界面提示
- OLED_ShowString(30,0,"ROOT MODE",8);
- OLED_ShowString(0,2,"* you can change",8);
- OLED_ShowString(0,4,"* password here",8);
- while(key_num!=82)
- if(key_num)
- switch(key_num)
- default: break;
- if(mykey==0)
- in_time++;
- switch(in_time)
- case 1:in_pwd1=str;OLED_ShowString(0,6,str,8);delay_ms(200);OLED_ShowString(0,6,"*",8);break;
- case 2:in_pwd2=str;OLED_ShowString(11,6,str,8);delay_ms(200);OLED_ShowString(11,6,"*",8);break;
- case 3:in_pwd3=str;OLED_ShowString(23,6,str,8);delay_ms(200);OLED_ShowString(23,6,"*",8);break;
- case 4:in_pwd4=str;OLED_ShowString(35,6,str,8);delay_ms(200);OLED_ShowString(35,6,"*",8);break;
- case 5:in_pwd5=str;OLED_ShowString(47,6,str,8);delay_ms(200);OLED_ShowString(47,6,"*",8);break;
- case 6:in_pwd6=str;OLED_ShowString(59,6,str,8);delay_ms(200);OLED_ShowString(59,6,"*",8);break;
- if(in_pwd1=="6"&&in_pwd2=="6"&&in_pwd3=="6"&&in_pwd4=="6"&&in_pwd5=="6"&&in_pwd6=="6"&&in_pwd7=="6"&&in_pwd8=="6")
- OLED_Clear();//清除輸入新密碼提示以及新密碼
- OLED_ShowString(0,0,"Coudle not set",8);
- OLED_ShowString(0,4,"REC:12345678",8);
- open_pwd[0]=*"1";
- open_pwd[1]=*"2";
- open_pwd[2]=*"3";
- open_pwd[3]=*"4";
- open_pwd[4]=*"5";
- open_pwd[5]=*"6";
- open_pwd[6]=*"7";
- open_pwd[7]=*"8";
- STMFLASH_Write(FLASH_SAVE_ADDR,(u16*)open_pwd,SIZE_PWD);
- delay_ms(500);
- delay_ms(1000);
- else
- open_pwd[0]=*in_pwd1;
- open_pwd[1]=*in_pwd2;
- open_pwd[2]=*in_pwd3;
- open_pwd[3]=*in_pwd4;
- open_pwd[4]=*in_pwd5;
- open_pwd[5]=*in_pwd6;
- open_pwd[6]=*in_pwd7;
- open_pwd[7]=*in_pwd8;
- delay_ms(500);
- delay_ms(1000);
- if(in_time==8)
- in_time=0;
- OLED_ShowString(10,3,"RESET COMPLETE",8);
- delay_ms(700);
- OLED_Clear();
- key_num=82;
- else
- delay_ms(10);
- mykey=0;//放手時(shí),歸零以便下次重新計(jì)數(shù)
- /***************************AS608詳情************************************/
- u8 ensure;
- ensure=PS_ReadSysPara(&AS608Para); //讀參數(shù)
- if(ensure==0x00)
- ensure=PS_ValidTempleteNum(&ValidN);//讀庫(kù)指紋個(gè)數(shù)
- if(ensure==0x00)
- OLED_ShowString(25,0,"AS608_Details",8);
- OLED_ShowString(0,2,"*Remainder:",8);
- OLED_ShowString(0,4,"*Level:",8);
- OLED_ShowNum(90,2,AS608Para.PS_max-ValidN,3,12);
- OLED_ShowNum(90,4,AS608Para.PS_level,3,12);
- delay_ms(1000);
- delay_ms(1000);
- OLED_Clear();
- /*******************************錄指紋*************************************/
- void Add_FR(void)
- u8 i,ensure ,processnum=0;
- u16 ID;
- PS_ReadSysPara(&AS608Para); //讀參數(shù)
- while(1)
- switch (processnum)
- case 0:
- i++;
- OLED_Clear();
- OLED_ShowString(0,2,"Press the finger",8);
- ensure=PS_GetImage();
- if(ensure==0x00)
- BEEP=1;
- ensure=PS_GenChar(CharBuffer1);//生成特征
- BEEP=0;
- if(ensure==0x00)
- OLED_Clear();
- OLED_ShowString(0,2,"Normal",8);
- i=0;
- processnum=1;//跳到第二步
- break;
- case 1:
- i++;
- OLED_Clear();
- OLED_ShowString(0,2,"Confirm again",8);
- if(ensure==0x00)
- BEEP=1;
- ensure=PS_GenChar(CharBuffer2);//生成特征
- BEEP=0;
- if(ensure==0x00)
- OLED_Clear();
- i=0;
- processnum=2;//跳到第三步
- break;
- case 2:
- OLED_Clear();
- OLED_ShowString(0,2,"Compare...",8);
- ensure=PS_Match();
- if(ensure==0x00)
- OLED_Clear();
- OLED_ShowString(0,2,"OK",8);
- processnum=3;//跳到第四步
- else
- OLED_Clear();
- OLED_ShowString(0,2,"Fail",8);
- OLED_ShowString(0,4,"try again",8);
- i=0;
- processnum=0;//跳回第一步
- delay_ms(1200);
- break;
- case 3:
- OLED_Clear();
- OLED_ShowString(0,2,"Saving...",8);
- ensure=PS_RegModel();
- if(ensure==0x00)
- OLED_Clear();
- OLED_ShowString(0,2,"Save success",8);
- processnum=4;//跳到第五步
- }else {processnum=0;}
- delay_ms(1200);
- break;
- case 4:
- OLED_Clear();
- OLED_ShowString(0,2,"Input ID",8);
- OLED_ShowString(0,4,"0=< ID <=299",8);
- OLED_ShowString(0,6,"Your ID:",8);
- do
- ID=GET_NUM();
- OLED_ShowNum(70,6,ID,3,12);
- delay_ms(1000);
- while(!(ID<AS608Para.PS_max));//輸入ID必須小于指紋容量的最大值
- ensure=PS_StoreChar(CharBuffer2,ID);//儲(chǔ)存模板
- if(ensure==0x00)
- OLED_Clear();
- OLED_ShowString(0,2,"Saved to flash",8);
- delay_ms(500);
- delay_ms(1000);
- OLED_Clear();
- return ;
- break;
- delay_ms(400);
- if(i==5)//超過(guò)5次沒(méi)有按手指則退出
- OLED_Clear();
- OLED_ShowString(0,2,"Out",8);
- delay_ms(300);
- OLED_Clear();
- break;
- /*******************************刷指紋*************************************/
- SearchResult seach;
- u8 ensure;
- if(ensure==0x00)//獲取圖像成功
- BEEP=1;//打開(kāi)蜂鳴器
- if(ensure==0x00) //生成特征成功
- BEEP=0;//關(guān)閉蜂鳴器
- ensure=PS_HighSpeedSearch(CharBuffer1,0,AS608Para.PS_max,&seach);
- if(ensure==0x00)//搜索成功
- OLED_Clear();
- OLED_ShowString(0,4,"ID:",8);
- OLED_ShowNum(20,4,seach.pageID,3,12);
- Moto=0;
- delay_ms(1000);
- Moto=1;
- delay_ms(1000);
- OLED_Clear();
- if(seach.pageID==99)
- send_text_message("Open the door under special circumstances");
- delay_ms(1000);
- delay_ms(1000);
- delay_ms(600);
- /*******************************刪除指紋*************************************/
- void Del_FR(void)
- u8 ensure;
- u16 num;
- OLED_Clear();
- OLED_ShowString(30,0,"Delete FR",8);
- delay_ms(50);
- num=GET_NUM();//獲取返回的數(shù)值
- if(num==0xFFFF)
- goto MENU ; //返回主頁(yè)面
- else if(num==0xFF00)
- ensure=PS_Empty();//清空指紋庫(kù)
- else
- OLED_ShowNum(70,6,num,3,12);
- delay_ms(1000);
- ensure=PS_DeletChar(num,1);//刪除單個(gè)指紋
- if(ensure==0)
- OLED_Clear();
- OLED_ShowString(0,2,"Delete success",8);
- delay_ms(1000);
- OLED_Clear();
- MENU:
- OLED_Clear();
- OLED_ShowString(0,0,"Enter 6 password",16);
AS608指紋識(shí)別修改.7z
(260.72 KB, 下載次數(shù): 242)
2019-5-31 18:06 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
