查看: 2604|回復(fù): 1
基于51單片機(jī)的水溫控制系統(tǒng)
ID:440456 發(fā)表于 2019-6-2 17:23 | 只看該作者 回帖獎(jiǎng)勵(lì) |正序?yàn)g覽 |閱讀模式
#include<reg52.h>
#include<stdio.h>
#include "18b20.h"
#include "1602.h"
#include "delay.h"sbit key0=P1^4;
sbit key1=P1^5;
sbit key4=P1^6;
sbit led0=P1^1;
sbit led1=P1^2;
sbit led2=P1^3;
sbit motor=P2^2;
sbit motor1=P2^3;
void  scankey();
bit ReadFlag;                 //定義讀時(shí)間標(biāo)志
char an=0;
unsigned char jiemian=0;
void Init_Timer0(void);       //定時(shí)器初始化
int temp,tempH=60,tempL=30;
void UART_Init(void)     //串口中斷
    SCON  = 0x50;          // SCON: 模式 1, 8-bit UART, 使能接收
    TMOD |= 0x20;               // TMOD: timer 1, mode 2, 8-bit 重裝
    TH1   = 0xFD;               // TH1:  重裝值 9600 波特率 晶振 11.0592MHz
    TR1   = 1;                  // TR1:  timer 1 打開
    //EA    = 1;                  //打開總中斷
    //ES    = 1;                  //打開串口中斷
TI=1;
void main (void)
  float wen;
  char displaywen[16];//定義顯示區(qū)域臨時(shí)存儲(chǔ)數(shù)組
   unsigned char flag=0;    //正常溫度的顯示
  LCD_Init();           //初始化液晶
  DelayMs(200);          //延時(shí)有助于穩(wěn)定
  LCD_Clear();          //清屏
  Init_Timer0();
  UART_Init();
  Lcd_User_Chr();       //寫入自定義字符
  wendu();
  wendu();
    wendu();
  while (1)
          scankey();
     if(ReadFlag==1)
      ReadFlag=0;
      temp=wendu();
      wen=(float)temp*0.0625;     //讀取溫度
      temp>>=4;                  //確保切換高、低溫時(shí)準(zhǔn)確
      sprintf(displaywen,"Temp  % 7.3f",wen);
      LCD_Write_String(0,0,displaywen);              //顯示第二行
      LCD_Write_Char(13,0,0x01);                     //寫入溫度右上角點(diǎn)
      LCD_Write_Char(14,0,'C');                      //寫入字符C
      if(temp>=tempL&&temp<=tempH)
                 {flag=0;led0=0;led2=1;led1=1;motor=1;motor1=1;}
      else if(temp>=tempH)
                 {flag=1;led1=0;led0=1;led2=1;motor1=0;motor=1;}
      else if(temp<=tempL)
                 {flag=2;led2=0;led0=1;led1=1;motor=0;motor1=1;}
    switch(jiemian)
     case 0:switch(flag)
       {        case 0:sprintf(displaywen,"H.%3d    L.%3d ",tempH, tempL);  //正常顯示狀態(tài)
            LCD_Write_String(0,1,displaywen);
               break;
        case 1:LCD_Write_String(0,1,"  shangxian tempH ");
               break;    //高于高溫狀態(tài)
        case 2:LCD_Write_String(0,1,"  xiaxian tempL ");
               break;      //低于低溫狀態(tài)              }  break;
     case 1:sprintf(displaywen,"+h.%3d  l.%3d ",tempH,tempL);
           LCD_Write_String(0,1,displaywen);break;
     case 2:sprintf(displaywen,"h.%3d  +l.%3d ",tempH,tempL);
     case 3:sprintf(displaywen,"-h.%3d  l.%3d ",tempH,tempL);
     case 4:sprintf(displaywen,"h.%3d  -l.%3d ",tempH,tempL);
void Init_Timer0(void)    //定時(shí)器
TMOD |= 0x01;   //使用模式1,16位定時(shí)器,使用"|"符號(hào)可以在使用多個(gè)定時(shí)器時(shí)不受影響
//TH0=0x00;       //給定初值
//TL0=0x00;
EA=1;            //總中斷打開
ET0=1;           //定時(shí)器中斷打開
TR0=1;           //定時(shí)器開關(guān)打開
void Timer0_isr(void) interrupt 1
static unsigned int num;
TH0=(65536-2000)/256;    //重新賦值 2ms
TL0=(65536-2000)%256;
num++;
if(num==1000)
    num=0;
    ReadFlag=1;            //讀標(biāo)志位置1
}void scankey()              //按鍵控制區(qū)域
  if(key0==0)
   DelayMs(10);
   if(key0==0)
   if(jiemian==1)tempH+=10;    //上限溫度的加的標(biāo)志位
    else if(jiemian==2)tempL+=10;
   while(!key0);
else  if(key1==0)
   DelayMs(10);
    if(key1==0)
     if(jiemian==3)tempH-=10;     //下限溫度的加的標(biāo)志位
     else if(jiemian==4)tempL-=10;
    while(!key1);
else  if(key4==0)          //切換界面
   DelayMs(10);
    if(key4==0)
     if(jiemian==0)jiemian=1;
     else if(jiemian==1)jiemian=2;
     else if(jiemian==2)jiemian=3;
     else if(jiemian==3)jiemian=4;
     else if(jiemian==4)jiemian=0;
   while(!key4);
ID:1 發(fā)表于 2019-6-3 04:51 | 只看該作者
此帖僅作者可見
