基于51單片機(jī)的電梯設(shè)計;可控制上下8層電梯
- #include <reg52.h> //調(diào)用單片機(jī)頭文件
- #define uchar unsigned char //無符號字符型 宏定義 變量范圍0~255
- #define uint unsigned int //無符號整型 宏定義 變量范圍0~65535
- //數(shù)碼管段選
- uchar code smg_du[]={0xde,0x90,0xcd,0xd9,0x93,0x5b,0x5f,0xd0,0xdf};//數(shù)碼管段碼 共陰
- uchar code key_table[]={0xee,0xde,0xbe,0x7e, //鍵盤掃描
- 0xed,0xdd,0xbd,0x7d,
- 0xeb,0xdb,0xbb,0x7b,
- 0xe7,0xd7,0xb7,0x77};
- uchar code table[]={1,2,3,4,5,6,7,8,1,2,3,4,5,6,7,8};
- bit flag_100ms,flag_1s;
- bit flag_stop = 1; //要不要在相應(yīng)的樓停下 1:需要?繕(biāo)志 0:開始?
- bit dianji_lock = 1;
- bit key1_flag = 0;//關(guān)門標(biāo)志位
- bit key2_flag = 0;//開門標(biāo)志位
- sbit beep = P2^6;
- sbit xia = P2^0; //LED
- sbit zhong = P2^1; //LED
- sbit shang = P2^2; //LED
- sbit dj_right = P1^0;
- sbit dj_left = P1^1;
- sbit hongwai = P1^2;
- sbit key_right= P1^3;
- sbit key_left = P1^4;
- sbit led_open = P1^5;
- sbit led_close= P1^6;
- uchar flag_start ; //啟動標(biāo)志位 1為起動步進(jìn)電機(jī) 否則關(guān)閉電機(jī)
- uchar flag_z_f; //正反標(biāo)志位 0為順時鐘 1為逆時史上轉(zhuǎn)
- uchar value2; //計數(shù)幾個100ms
- uchar key_can; //按鍵值接收
- sbit dj1 = P2^7; //電機(jī)IO口定義
- sbit dj2 = P2^5;
- sbit dj3 = P2^4;
- sbit dj4 = P2^3;
- uchar dt_1; //1樓電梯標(biāo)志位
- uchar dt_2;
- uchar dt_3;
- uchar dt_4;
- uchar dt_5;
- uchar dt_6;
- uchar dt_7;
- uchar dt_8;
- uchar dt_value = 1; //電梯到哪一層的變量
- uchar dt_s_x ; //電梯上下的標(biāo)志位 0停 1上 2下
- void delay_ms(uchar t) //ms
- uchar a,b;
- for(;t>0;t--)
- for(a=142;a>0;a--)
- for(b=2;b>0;b--);
- void Delay(unsigned int i)//延時
- while(--i);
- /////////////////////直流電機(jī)////////////////////////////////
- void dianji(uchar s)
- if(s == 0) //關(guān)電機(jī)
- dj_right = 0;
- dj_left = 0;
- if(s == 1) //開門
- dj_right = 1;
- dj_left = 0;
- if(s == 2) //關(guān)門
- dj_right = 0;
- dj_left = 1;
- /***********************正轉(zhuǎn)****************************/
- void zheng(uchar dat)
- switch(dat)
- case 0: dj1=1;dj2=0;dj3=0;dj4=0; break;
- case 1: dj1=0;dj2=1;dj3=0;dj4=0; break;
- case 2: dj1=0;dj2=0;dj3=1;dj4=0; break;
- case 3: dj1=0;dj2=0;dj3=0;dj4=1; break;
- void fan(uchar dat)
- switch(dat)
- case 0: dj1=0;dj2=0;dj3=0;dj4=1; break;
- case 1: dj1=0;dj2=0;dj3=1;dj4=0; break;
- case 2: dj1=0;dj2=1;dj3=0;dj4=0; break;
- case 3: dj1=1;dj2=0;dj3=0;dj4=0; break;
- /***********************1ms延時函數(shù)*****************************/
- void delay_1ms(uint q)
- uint i,j;
- for(i=0;i<q;i++)
- for(j=0;j<120;j++);
- /********************獨立按鍵程序*****************/
- void key() //鍵盤掃描程序
- uchar i,temp,temp1,temp2,num;
- key_can = 20; //按鍵值還原
- P3=0xf0;
- if(P3!=0xf0)
- delay_ms(20);
- if(P3!=0xf0)
- temp1 = P3; //記錄高四位的列號
- P3 = 0x0f; //電平轉(zhuǎn)換
- temp2 = P3; //記錄低四位的行號
- temp = temp1|temp2; //行列定位
- for(i=0;i<16;i++)
- if(temp==key_table[i])
- num =i;
- break;
- key_can = table[num];
- delay_ms(1);
- void key_with() //電梯樓層標(biāo)志位
- if(key_can == 1)
- dt_1 = 1; //
- if(key_can == 2)
- dt_2 = 1;
- if(key_can == 3)
- dt_3 = 1;
- if(key_can == 4)
- dt_4 = 1;
- if(key_can == 5)
- dt_5 = 1;
- if(key_can == 6)
- dt_6 = 1;
- if(key_can == 7)
- dt_7 = 1;
- if(key_can == 8)
- dt_8 = 1;
- /*********************當(dāng)電梯不動時、判斷是向上、還是向下并顯示箭頭**********************/
- void tiandi_shang_xia()
- static uchar value;
- if(dt_s_x == 0)
- flag_stop = 1; //需要停靠
- if(dt_value == 1) //電梯在第1層
- value = dt_2 + dt_3 + dt_4 + dt_5 + dt_6 + dt_7 + dt_8;
- if(value != 0)
- dt_s_x = 1; //電梯向上
- shang = 0; //顯示上
- zhong = 0;
- xia = 1;
- if(dt_value == 2) //電梯在第2層
- value = dt_3 + dt_4 + dt_5 + dt_6 + dt_7 + dt_8;
- if(value != 0)
- dt_s_x = 1; //電梯向上走
- shang = 0; //顯示上
- zhong = 0;
- xia = 1;
- value = dt_1;
- if(value != 0)
- dt_s_x = 2; //電梯向下走
- xia = 0; //顯示下
- zhong = 0;
- shang = 1;
- if(dt_value == 3) //電梯在第3層
- value = dt_4 + dt_5 + dt_6 + dt_7 + dt_8;
- if(value != 0)
- shang = 0; //顯示上
- zhong = 0;
- xia = 1;
- value = dt_1 + dt_2;
- if(value != 0)
- xia = 0; //顯示下
- zhong = 0;
- shang = 1;
- if(dt_value == 4) //電梯在第4層
- value = dt_5 + dt_6 + dt_7 + dt_8;
- if(value != 0)
- shang = 0; //顯示上
- zhong = 0;
- xia = 1;
- value = dt_1 + dt_2 + dt_3;
- if(value != 0)
- xia = 0; //顯示下
- zhong = 0;
- shang = 1;
- if(dt_value == 5) //電梯在第5層
- value = dt_6 + dt_7 + dt_8;
- if(value != 0)
- shang = 0; //顯示上
- zhong = 0;
- xia = 1;
- value = dt_1 + dt_2 + dt_3 + dt_4;
- if(value != 0)
- xia = 0; //顯示下
- zhong = 0;
- shang = 1;
- if(dt_value == 6) //電梯在第6層
- value = dt_7 + dt_8;
- if(value != 0)
- shang = 0; //顯示上
- zhong = 0;
- xia = 1;
- value = dt_1 + dt_2 + dt_3 + dt_4 + dt_5;
- if(value != 0)
- xia = 0; //顯示下
- zhong = 0;
- shang = 1;
- if(dt_value == 7) //電梯在第7層
- value = dt_8;
- if(value != 0)
- shang = 0; //顯示上
- zhong = 0;
- xia = 1;
- value = dt_1 + dt_2 + dt_3 + dt_4 + dt_5 + dt_6;
- if(value != 0)
- xia = 0; //顯示下
- zhong = 0;
- shang = 1;
- if(dt_value == 8) //電梯在第8層
- value = dt_8;
- if(value != 0)
- shang = 0; //顯示上
- zhong = 0;
- xia = 1;
- if(value != 0)
- xia = 0; //顯示下
- zhong = 0;
- shang = 1;
- /****************電梯向上、做最后的判斷是否還要繼續(xù)向上****************/
- void dt_shang_guan()
- uchar value;
- if(dt_s_x == 1) //電梯向上 做最后的判斷是否還要繼續(xù)向上
- if(dt_value == 1) //在第1層
- if(value == 0) //說明上面沒有人按下
- dt_s_x = 0; //電梯停下不動了
- shang = 1; //關(guān)閉上字
- zhong = 1;
- else
- flag_stop = 1; //有人按鍵先讓其?,后用td_due函數(shù)判斷是否真需要?
- else if(dt_value == 2) //在第2層
- zhong = 1;
- }else
- flag_stop = 1;
- else if(dt_value == 3) //在第3層
- value = dt_4+ dt_5 + dt_6 + dt_7 + dt_8;
- zhong = 1;
- }else
- flag_stop = 1;
- else if(dt_value == 4) //在第4層
- zhong = 1;
- }else
- flag_stop = 1;
- else if(dt_value == 5) //在第5層
- zhong = 1;
- }else
- flag_stop = 1;
- else if(dt_value == 6) //在第6層
- zhong = 1;
- }else
- flag_stop = 1;
- else if(dt_value == 7) //在第7層
- value = dt_8;
- zhong = 1;
- }else
- flag_stop = 1;
- else if(dt_value == 8) //在第8層
- zhong = 1;
- /****************電梯向下、做最后的判斷是否還要繼續(xù)向下****************/
- void dt_xia_guan()
- uchar value;
- if(dt_s_x == 2) //電梯向下 做最后的判斷是否還要繼續(xù)向下
- xia = 1; //關(guān)閉上字
- zhong = 1;
- flag_stop = 1;
- value = dt_1;
- if(value == 0) //說明下面沒有人按下
- zhong = 1;
- }else
- flag_stop = 1;
- zhong = 1;
- }else
- flag_stop = 1;
- zhong = 1;
- }else
- flag_stop = 1;
- value = dt_1 + dt_2 + dt_3+ + dt_4;
- zhong = 1;
- }else
- flag_stop = 1;
- zhong = 1;
- }else
- flag_stop = 1;
- value = dt_1 + dt_2 +dt_3 + dt_4 + dt_5+ dt_6;
- zhong = 1;
- }else
- flag_stop = 1;
- value = dt_1 + dt_2 + dt_3 + dt_4 + dt_5 + dt_6 + dt_7;
- zhong = 1;
- }else
- flag_stop = 1;
- void dianji_open_lock()
- if(dianji_lock == 1)
- if(dt_s_x == 1)
- flag_start = 1 ; //運行
- flag_z_f = 0; //向上
- if(dt_s_x == 2)
- flag_z_f = 1; //向下
- if(dt_s_x == 0)
- flag_start = 0 ; //停下
- flag_z_f = 1; //
- else flag_start = 0 ; //停下
- /***********************電梯處理函數(shù)************************/
- void td_due() //100ms執(zhí)行1次
- uchar value,value1;
- value = dt_1 + dt_2 + dt_3 + dt_4 + dt_5 + dt_6 + dt_7 + dt_8;
- if(value != 0) //有人按下
- if(flag_stop == 1) //到相應(yīng)的樓了判斷是否真的要停下
- if(dt_s_x != 0) //如果不應(yīng)該停
- value1 ++;
- if(value1 >= 10) //電梯上下運行1s ,再判該層應(yīng)不應(yīng)該停
- value1 = 0;
- if(dt_s_x == 1) //向上走電梯
- dt_value ++;
- shang = 0; //顯示上字
- zhong = 0;
- if(dt_s_x == 2) //向下走電梯
- dt_value --;
- xia = 0; //顯示下字
- zhong = 0;
- if(dt_value == 1) //當(dāng)?shù)搅说谝粚拥臅r候
- if(dt_1 == 1)
- dt_1 = 0; //清零標(biāo)志
- flag_stop = 0; //到停下
- beep = 0; //打開蜂鳴器
- else if(dt_value == 2) //當(dāng)?shù)搅说诙䦟拥臅r候
- if(dt_2 == 1)
- dt_2 = 0;
- beep = 0; //打開蜂鳴器
- else if(dt_value == 3) //當(dāng)?shù)搅说?層的時候
- if(dt_3 == 1)
- dt_3 = 0;
- beep = 0; //打開蜂鳴器
- else if(dt_value == 4) //當(dāng)?shù)搅说?層的時候
- if(dt_4 == 1)
- dt_4 = 0;
- beep = 0; //打開蜂鳴器
- else if(dt_value == 5) //當(dāng)?shù)搅说?層的時候
- if(dt_5 == 1)
- dt_5 = 0;
- beep = 0; //打開蜂鳴器
- else if(dt_value == 6) //當(dāng)?shù)搅说?層的時候
- if(dt_6 == 1)
- dt_6 = 0;
- beep = 0; //打開蜂鳴器
- else if(dt_value == 7) //當(dāng)?shù)搅说?層的時候
- if(dt_7 == 1)
- dt_7 = 0;
- beep = 0; //打開蜂鳴器
- else if(dt_value == 8) //當(dāng)?shù)搅说?層的時候
- if(dt_8 == 1)
- dt_8 = 0; //清零在的標(biāo)志
- beep = 0; //打開蜂鳴器
- if(flag_stop == 0) //開始?块W爍
- value2 ++; //計數(shù)幾個100ms
- dianji_lock = 0;//給電機(jī)判斷加鎖
- dianji(1); //電機(jī)開門
- led_open = 0; //開門指示燈
- led_close = 1; //開門指示燈
- if(key1_flag == 1) //關(guān)門鍵
- key1_flag = 0;
- if(hongwai==0)//沒人
- value2 = 10;
- led_open = 1; //關(guān)門指示燈
- led_close = 0; //關(guān)門指示燈
- dianji(2); //電機(jī)關(guān)門
- if(value2 >= 20) //2.0s
- dianji(0); //關(guān)閉電機(jī)
- if(hongwai==1)//紅外有人則一直?
- value2 = 0; //重新一輪
- dianji(0);
- if(value2 % 5 == 0)
- if(dt_s_x == 1) //上
- shang = ~shang;
- zhong = ~zhong;
- if(dt_s_x == 2) //下
- zhong = ~zhong;
- xia = ~xia;
- if(value2 >= 10) //1.0s
- beep = 1; //關(guān)閉蜂鳴器
- if(value2 >= 50)//?5s,然后判斷是否需要上下
- value2 = 0; //計數(shù)幾個100ms
- dianji_lock = 1; //解鎖電機(jī)判斷
- dt_shang_guan(); //電梯向上 做最后的判斷是否還要繼續(xù)向上
- dt_xia_guan(); //電梯向下 做最后的判斷是否還要繼續(xù)向下
- /*************定時器0初始化程序***************/
- void time_init()
- EA = 1; //開總中斷
- TMOD = 0X01; //定時器0、工作方式1
- ET0 = 1; //開定時器0中斷
- TR0 = 1; //允許定時器0定時
- /******************主程序**********************/
- void main()
- uchar i,num;
- P1 = 0x00;
- P0 = 0X00; //單片機(jī)IO口初始化
- time_init(); //定時器初始化
- dianji(0); //電機(jī)關(guān)閉
- while(1)
- key(); //按鍵掃描程序
- if(key_can < 20)
- if(dt_s_x == 0)
- flag_stop = 1; //1:需要?繕(biāo)志
- key_with();
- if(key_left == 0) //關(guān)門鍵按下
- delay_ms(10);
- key1_flag = 1; //關(guān)門鍵標(biāo)志
- tiandi_shang_xia(); //當(dāng)電梯?繒r(stop=1)、判斷是向上、還是向下,并開關(guān)電機(jī)
- dianji_open_lock(); //電機(jī)開關(guān)判斷是否有效函數(shù)
- P0 = smg_du[dt_value]; //顯示
- if(flag_100ms == 1)
- flag_100ms = 0;
- num++; //用于開門計數(shù)
- td_due(); //電梯處理函數(shù)
- if(key_right==0)//開門鍵
- delay_ms(5);
- key2_flag = 1;//開門標(biāo)志位
- if(key2_flag==1)
- num = 0;
- key2_flag = 0;//開門標(biāo)志位
- if(dt_s_x == 0)
- dianji(1);
- if(num>=20) //2s關(guān)電機(jī)
- dianji(0);
- if(num>=50)
- if(flag_start == 1)
- for(i=0;i<4;i++) //4相
- if(flag_z_f == 0)
- zheng(i); //電機(jī)正轉(zhuǎn)
- else
- fan(i); //電機(jī)反轉(zhuǎn)
- Delay(100); //改變這個參數(shù)可以調(diào)整電機(jī)轉(zhuǎn)速
- /*************定時器0中斷服務(wù)程序***************/
- void time0_int() interrupt 1
- TH0 = 0x3c;
- TL0 = 0xb0; // 50ms
- value ++;
- if(value % 2 == 0)
- flag_100ms = 1 ;
電梯程序keil.zip
(59.87 KB, 下載次數(shù): 34)
2019-6-6 08:30 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
