紅外溫度傳感器 MLX90614
// remap_mlx90614.ino
#include "i2cmaster.h"
// New slave address, purposefully left shifted
byte NewMLXAddr = 0x39; //傳感器新I2C地址;傳感器1,2,3,4,5依次為0x1A,0x2A,0x3A,0x4A,0x5A
// 0x5A is the default address - uncomment this to set it back
// byte NewMLXAddr = 0x5A;
void setup(){
Serial.begin(9600);
Serial.println("Setup...");
// Initialise the i2c bus, enable pullups and then wait
i2c_init();
PORTC = (1 << PORTC4) | (1 << PORTC5);
delay(5000);
// Read current address bytes
ReadAddr(0);
// Change address to new value (NewMLXAddr);
ChangeAddr(NewMLXAddr, 0x00);
// Read address bytes
ReadAddr(0);
Serial.print("> Cycle power NOW to set address to: ");
Serial.print(NewMLXAddr, HEX);
Serial.println(" - you have 10 seconds");
// Cycle power to MLX during this 10 second pause
delay(10000);
// Read temperature using default address
ReadTemp(0);
// Read temperature using new address (note left bit shift for reading)
ReadTemp(NewMLXAddr<<1);
Serial.println("**---DONE---**");
void loop(){
delay(5000);
word ChangeAddr(byte NewAddr1, byte NewAddr2) {
Serial.println("> Change address");
// Send start condition and write bit
i2c_start_wait(0 + I2C_WRITE);
// Send command for device to return address
i2c_write(0x2E);
// Send low byte zero to erase
i2c_write(0x00);
// Send high byte zero to erase
i2c_write(0x00);
if (i2c_write(0x6F) == 0) {
// Release bus, end transaction
i2c_stop();
Serial.println("> Data erased.");
else {
i2c_stop();
Serial.println("> Failed to erase data");
return -1;
Serial.print("> Writing data: ");
Serial.print(NewAddr1, HEX);
Serial.print(", ");
Serial.println(NewAddr2, HEX);
for (int a = 0; a != 256; a++) {
i2c_write(0x2E);
i2c_write(NewAddr1);
i2c_write(NewAddr2);
if (i2c_write(a) == 0) {
// Release bus, end transaction then wait 10ms
i2c_stop();
delay(100);
Serial.print("> Found correct CRC: 0x");
Serial.println(a, HEX);
return a;
i2c_stop();
Serial.println("> Correct CRC not found");
return -1;
void ReadAddr(byte Address) {
Serial.println("> Read address");
// Inform the user
Serial.print(" MLX address: ");
Serial.print(Address, HEX);
Serial.print(", Data: ");
i2c_start_wait(Address + I2C_WRITE);
i2c_write(0x2E);
i2c_rep_start(Address + I2C_READ);
// Read 1 byte and then send ack (x2)
Serial.print(i2c_readAck(), HEX);
Serial.print(", ");
Serial.print(", ");
Serial.println(i2c_readNak(), HEX);
i2c_stop();
float ReadTemp(byte Address) {
int data_low = 0;
int data_high = 0;
int pec = 0;
Serial.println("> Read temperature");
// Inform the user
Serial.print(", ");
// Address of temp bytes
i2c_write(0x07);
// Read - the famous repeat start
data_low = i2c_readAck();
data_high = i2c_readAck();
pec = i2c_readNak();
i2c_stop();
// This converts high and low bytes together and processes the temperature
// MSB is a error bit and is ignored for temperatures
// Zero out the data
float temp = 0x0000;
// This masks off the error bit of the high byte, then moves it left
// 8 bits and adds the low byte.
temp = (float)(((data_high & 0x007F) << 8) + data_low);
temp = (temp * 0.02) - 273.16;
Serial.print(temp);
Serial.println(" C");
return temp;
激光測距傳感器 ATK-VL53l0X
#include "Adafruit_VL53L0X.h"
Adafruit_VL53L0X lox=Adafruit_VL53L0X();
void setup() {
// put your setup code here, to run once:
lox.begin(0x29);
void loop() {
// put your main code here, to run repeatedly:
I2C地址修改.zip
2019-6-7 17:50 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
5.58 KB, 下載次數(shù): 39, 下載積分: 黑幣 -5
