查看: 7333|回復(fù): 8
51單片機(jī)洗衣機(jī)設(shè)計 Proteus仿真原理圖程序代碼
ID:553817 發(fā)表于 2019-6-9 12:54 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
單片機(jī)洗衣機(jī)的仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
單片機(jī)代碼如下
#include <REG52.H>
#define uint  unsigned int
#define qiang_ledon qiang_led=1;
#define qiang_ledoff qiang_led=0;
#define biao_ledon biao_led=1;
#define biao_ledoff biao_led=0;
#define ruo_ledon ruo_led=1;
#define ruo_ledoff ruo_led=0;
#define piao_ledon piao_led=1;
#define piao_ledoff piao_led=0;
#define sgan_ledon sgan_led=1;
#define sgan_ledoff sgan_led=0;
#define jin_ledon jin_led=1;
#define jin_ledoff jin_led=0;
#define pai_ledon pai_led=1;
#define pai_ledoff pai_led=0;
unsigned char code Tab[11]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F}; //數(shù)碼管顯示0~9的段碼表
unsigned char int_time;        //記錄中斷次數(shù)
unsigned char second;        //儲存秒
uint t=0,tt=0;
   sbit k1=P0^0;
   sbit k2=P0^1;
   sbit k3=P0^2;
   sbit sg=P0^3;
   sbit hk1=P0^4;
   sbit hk2=P0^5;
   sbit ledon=P0^7;
   sbit qiang_led=P2^0;
   sbit biao_led=P2^1;
   sbit ruo_led=P2^2;
   sbit piao_led=P2^3;
   sbit sgan_led=P2^4;
   sbit jin_led=P2^5;
   sbit pai_led=P2^6;
   sbit p30=P3^0;
   sbit p31=P3^1;
   sbit beepon=P2^7;
   sbit sm1=P3^6;
   sbit sm2=P3^7;
void delay2(void)
  unsigned char m;
  for(m=0;m<200;m++)
void delay1(int s)
   int i;
   for(;s>0;s--)
   for(i=0;i<65;i++);
void delay(uint i)
   uchar j;
   for(i;i>0;i--)
   for(j=255;j>0;j--);
void DisplaySecond(unsigned char k)
   sm1=0;        //P2.6引腳輸出低電平, DS6點(diǎn)亮
   P1=Tab[k/10];          //顯示十位
     delay2();
     delay2();
   sm1=1;
   sm2=0;       //P2.7引腳輸出低電平, DS7點(diǎn)亮
   P1=Tab[k%10];         //顯示個位
     delay2();
     delay2();
   P3=0xff;     //關(guān)閉所有數(shù)碼管
   P1=1;        //顯示個位
     delay2();
     delay2();
void beep()
          p30=0;
    p31=0;
           t=0;
          beepon^=1;
      delay(300);
      if(t>=80) break;
        beepon=0;
        biao_led=0;
void f_qiang()
         qiang_ledon;
         t=0;
         tt=0;
     int_time=0;
     second=00;
          if(tt>=400) break;
      t=0;
          while(t<80&&tt<=400)
            p31=0;
            p30=1;        //正轉(zhuǎn) 4s
        DisplaySecond(second);
          t=0;          //反轉(zhuǎn) 4s
            p30=0;
            p31=1;
          p30=0;
          p31=0;
void f_biao()
          qiang_led=0;
      biao_led=1;
          t=0;
          tt=0;
      int_time=0;
      second=00;
           if(tt>=400) break;
           t=0;
          while(t<60&&tt<=400)
          p31=0;
                  p30=1;        //正轉(zhuǎn)3s
                t=0;          //反轉(zhuǎn)3s
              p30=0;
                  p31=1;
       p30=0;
           p31=0;
void f_ruo()
          qiang_led=0;
          biao_led=0;
          ruo_led=1;
          t=0;
          tt=0;
      int_time=0;
       second=00;
                    if(tt>=400) break;
                 t=0;
               while(t<40&&tt<=400)
           {        p31=0;
                        p30=1;        //正轉(zhuǎn)2s
             t=0;          //反轉(zhuǎn) 2s
            {   p30=0;
                        p31=1;
                p30=0;
            p31=0;
void f_piao()
           qiang_ledoff;
           biao_ledoff;
           piao_ledon;
           t=0;
           tt=0;
       int_time=0;
       second=00;
                      if(tt>=400) break;
                   t=0;
               {        p31=0;
                   t=0;          //反轉(zhuǎn)2s
               {    p30=0;
                            p31=1;
          p30=0;
      p31=0;
          piao_ledoff;
void pai_leds()
            p30=0;
            p31=0;
               pai_led=1;        //排水閥燈亮 等待霍爾開關(guān)2
            while(hk2);
            if(hk2==0)  //如果閉合
            pai_led=0;        //排水燈滅
void jin()
            p30=0;
            p31=0;
            jin_ledon;
             while(hk1);
            if(hk1==0)
            jin_ledoff;
void sgan()
            sgan_ledon;         //甩干燈亮
             t=0;
        int_time=0;
        second=00;
             while(t<=400)
                            p31=0;
                        p30=1;
        sgan_ledoff;
void sgan1()
           sgan_ledon;
            t=0;
       int_time=0;
       second=00;
             while(t<=400)
                           p31=0;
                   p30=1;
        piao_ledoff;
        sgan_ledoff;
        beep();
            t=401;
void f_an1()
        qiang_ledon; //方案1燈亮
        jin();  //進(jìn)入強(qiáng)洗
        f_qiang();         //循環(huán)20S
        delay1(4000);//延時4s
        f_biao();  //循環(huán)20S
        delay1(4000);//延時4s
        f_ruo();  //循環(huán)20S
        ruo_ledoff;
        pai_leds();
        delay1(1000); //延時1S 進(jìn)入甩干
        sgan(); //甩干20s
        sgan_ledoff;
        ruo_ledoff;
        piao_ledoff;
        jin();
        delay1(1000); //延時1S 進(jìn)入漂洗
        f_piao();  //循環(huán)20S
        sgan_ledoff;
        piao_ledoff;
        pai_leds();
        sgan1();//最終甩干20S
        delay(500);//延時
        beep();
void f_an2()
        biao_ledon; //方案1燈亮
        jin();
        delay1(4000); //延時4S
        ruo_ledoff;
        pai_leds();
        sgan(); //甩干20s
        ruo_ledoff;
        piao_ledoff;
        jin();
        sgan_led=0;
        pai_leds();
        sgan();//最終甩干20s
        delay(500);//延時5s
        piao_led=0;
        beep();
void f_an3()
        ruo_led=1; //方案1燈亮
        jin();
        ruo_ledoff;
        pai_leds();
        sgan(); //甩干20S
        ruo_ledoff;
        piao_ledoff;
        jin();
        sgan_led=0;
        pai_leds();
        sgan();//最終甩干20s
        delay(500);//延時5s
        piao_led=0;
        p30=0;
        beep();
int main(void)
  TMOD=0x01;       //方式1 16位計數(shù)器
  TH0=-50000/256;   //設(shè)定初值
  TL0=-50000%256;
  EA=1;               //開總中斷
  ET0=1;             //開定時器0中斷
  TR0=1;             //啟動定時器0
  P2=0;
  int_time=0;     //中斷次數(shù)初始化
  second=00;           //秒初始化
          if(k1==0)
                delay(10);
                if(k1==0)
                        f_an1();
        if(k2==0)
                delay(10);
                if(k2==0)
                        f_an2();
        if(k3==0)
            delay(10);
           if(k3==0)
                    f_an3();
         if(sg==0)
                delay(10);
                if(sg==0)
                   sgan1();
        return 0;
void time0() interrupt 1 using 1
     int_time ++;        //每來一次中斷,中斷次數(shù)int_time自加1
    if(int_time==20)   //夠20次中斷,即1秒鐘進(jìn)行一次檢測結(jié)果采樣
        int_time=0;    //中斷次數(shù)清0
        second++;    //秒加1
   TH0=-50000/256;   //50000  =50ms中斷一次
   TL0=-50000%256;
   t++;
   tt++;
全部資料51hei下載地址:
洗衣機(jī)protues仿真程序 51單片機(jī)洗衣機(jī)設(shè)計 洗衣機(jī)程序仿真代碼.rar (157.75 KB, 下載次數(shù): 229)
admin + 50 共享資料的黑幣獎勵!
收藏收藏13 分享淘帖 頂1 踩
ID:603234 發(fā)表于 2019-8-24 20:16 | 只看該作者
未見數(shù)碼管亮 電機(jī)轉(zhuǎn)動?
ID:282095 發(fā)表于 2019-8-25 07:12 | 只看該作者
沒太明白什么意思
ID:342822 發(fā)表于 2019-8-25 08:55 | 只看該作者
全靠水位來控制
ID:342822 發(fā)表于 2019-8-25 09:05 | 只看該作者
萬古琴 發(fā)表于 2019-8-24 20:16
調(diào)整水位與進(jìn)水傳感器后自動順序執(zhí)行~~
ID:720869 發(fā)表于 2020-4-18 19:02 | 只看該作者
l298芯片電源處加電容是作何種保護(hù)。
ID:721525 發(fā)表于 2020-4-24 21:50 | 只看該作者
數(shù)碼管代碼有問題
ID:773862 發(fā)表于 2020-6-9 18:16 來自觸屏版 | 只看該作者
請問壓縮包里有protues仿真文件嗎?
ID:892025 發(fā)表于 2021-3-15 10:19 | 只看該作者
可以向你討論一下你的洗衣機(jī)設(shè)計?
