查看: 5522|回復(fù): 7
DAC0832簡(jiǎn)易波形發(fā)生器,產(chǎn)生方波,正弦波,三角波,鋸齒波
ID:559790 發(fā)表于 2019-6-11 17:06 | 顯示全部樓層 |閱讀模式
#include<reg51.h>
#include<math.h>
#include<absacc.h>
sbit key1=P1^0;
sbit key2=P1^1;
uchar count,a=0;
code uchar Sin[256]={0x80,0x83,0x86,0x89,0x8d,0x90,0x93,0x96,0x99,0x9c,0x9f,0xa2,0xa5,0xa8,0xab,0xae,0xb1,
0xb4,0xb7,0xba,0xbc,0xbf,0xc2,0xc5,0xc7,0xca,0xcc,0xcf,0xd1,0xd4,0xd6,0xd8,0xda,0xdd,0xdf,0xe1,0xe3,0xe5,
0xe7,0xe9,0xea,0xec,0xee,0xef,0xf1,0xf2,0xf4,0xf5,0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,0xfc,0xfd,0xfd,0xfe,0xff,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xfd,0xfd,0xfc,0xfb,0xfa,0xf9,0xf8,0xf7,0xf6,
0xf5,0xf4,0xf2,0xf1,0xef,0xee,0xec,0xea,0xe9,0xe7,0xe5,0xe3,0xe1,0xde,0xdd,0xda,0xd8,0xd6,0xd4,0xd1,0xcf,
0xcc,0xca,0xc7,0xc5,0xc2,0xbf,0xbc,0xba,0xb7,0xb4,0xb1,0xae,0xab,0xa8,0xa5,0xa2,0x9f,0x9c,0x99,0x96,0x93,
0x90,0x8d,0x89,0x86,0x83,0x80,0x80,0x7c,0x79,0x76,0x72,0x6f,0x6c,0x69,0x66,0x63,0x60,0x5d,0x5a,0x57,0x55,
0x51,0x4e,0x4c,0x48,0x45,0x43,0x40,0x3d,0x3a,0x38,0x35,0x33,0x30,0x2e,0x2b,0x29,0x27,0x25,0x22,0x20,0x1e,
0x1c,0x1a,0x18,0x16,0x15,0x13,0x11,0x10,0x0e,0x0d,0x0b,0x0a,0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x02,
0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x02,0x02,0x03,0x04,0x05,0x06,0x07,
0x08,0x09,0x0a,0x0b,0x0d,0x0e,0x10,0x11,0x13,0x15,0x16,0x18,0x1a,0x1c,0x1e,0x20,0x22,0x25,0x27,0x29,0x2b,
0x2e,0x30,0x33,0x35,0x38,0x3a,0x3d,0x40,0x43,0x45,0x48,0x4c,0x4e,0x51,0x55,0x57,0x5a,0x5d,0x60,0x63,0x66,
0x69,0x6c,0x6f,0x72,0x76,0x79,0x7c,0x80 };
void delay(uint x)   //延時(shí)函數(shù)
        while(x--);
void fangbo()           //方波
        P0=0xff;
        delay(1000);
        P0=0x00;
        delay(1000);
void sanjiao()          //三角波
        uchar i;
                for(i=0;i<255;i++)
                        P0=i;
                for(i=255;i>0;i--)
                        P0=i;
                        P0=0;
                        if(key1!=0)
                        break;
void juchi()        //鋸齒波
        uchar i;
                for(i=0;i<=255;i++)
                         P0=i;
                        if(key2!=0)
                        break;
void zhengxian()   //正弦波
        uchar i;
                for(i=0;i<256;i++)
                        P0=Sin[i];
void dingshi0(void)  interrupt 1  using 1
          TH0=(65536-50000)/256;
          TL0=(65536-50000)%256;                //50ms
          count++;
          if(count==20)
                   count=0;
                 a++;
void int0(void) interrupt 0  using 0
        zhengxian();
        TMOD=0X01;
        EA=1;                //開(kāi)啟總中斷
        ET0=1;            //開(kāi)中斷ET0
        TR0=1;     //啟動(dòng)中斷ET0
        EX0=1;           //外部中斷0
        IT0=0;
        P1=0xff;
                 if(a==1)
                        fangbo();
                        TR0=0;
                if(key1==0)
                        sanjiao();
            if(key2==0)
                        juchi();
proteus仿真圖
proteus仿真圖
ID:543941 發(fā)表于 2019-7-1 17:59 | 顯示全部樓層
為啥我試的沒(méi)有任何波形,
ID:543941 發(fā)表于 2019-7-1 18:02 | 顯示全部樓層
為啥我這沒(méi)有任何波形,
ID:576194 發(fā)表于 2019-7-2 10:26 | 顯示全部樓層
你好,請(qǐng)問(wèn)這個(gè)有匯編寫(xiě)的嗎
ID:253767 發(fā)表于 2019-7-3 06:51 | 顯示全部樓層
謝謝分享!!!
ID:707115 發(fā)表于 2020-3-12 16:59 | 顯示全部樓層
有梯形波嗎?
ID:712814 發(fā)表于 2020-3-21 13:34 | 顯示全部樓層
你好 仿真可以發(fā)一下嗎
ID:581979 發(fā)表于 2020-11-2 18:48 | 顯示全部樓層
真的有用嘛,我是老實(shí)人
