- #include<reg51.h>
- #include<intrins.h>
- sbit E=P3^0;
- sbit RW=P3^1;
- sbit DI=P3^2;
- sbit CS2=P3^3;
- sbit CS1=P3^4;
- #define uchar unsigned char
- #define uint unsigned int
- unsigned char cons,cont;
- //uchar code
- //l[]=
- //{0x00,0x10,0x10,0x10,0x10,0x10,0xFF,0x10,0x10,0xF0,0x10,0x11,0x16,0xD0,0x10,0x10,
- //0x00,0x80,0x40,0x20,0x18,0x06,0x41,0x20,0x10,0x3F,0x44,0x42,0x41,0x40,0x40,0x78},
- //c[]=
- //{0x00,0x24,0x24,0xA4,0xFE,0x23,0x22,0x00,0x3E,0x22,0x22,0x22,0x22,0x22,0x3E,0x00,
- //0x00,0x08,0x06,0x01,0xFF,0x01,0x06,0x40,0x49,0x49,0x49,0x7F,0x49,0x49,0x49,0x41},
- //dian[]=
- //{0x00,0x00,0xF8,0x88,0x88,0x88,0x88,0xFF,0x88,0x88,0x88,0x88,0xF8,0x00,0x00,0x00,
- //0x00,0x00,0x1F,0x08,0x08,0x08,0x08,0x7F,0x88,0x88,0x88,0x88,0x9F,0x80,0xF0,0x00},
- //qi[]=
- //{0x20,0x10,0x4C,0x47,0x54,0x54,0x54,0x54,0x54,0x54,0x54,0xD4,0x04,0x04,0x00,0x00,
- //0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0x30,0x40,0xF0,0x00},
- //ban[]=
- //{0x84,0x84,0xFC,0x84,0x84,0x00,0xF8,0x00,0xFF,0x00,0x84,0x84,0xFC,0x84,0x84,0x00,
- //0x10,0x30,0x1F,0x08,0x88,0x42,0x21,0x18,0x07,0x00,0x20,0x20,0x3F,0x20,0x20,0x00};
- uchar code
- shuzi[16][32]={{0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"0",0*/
- {0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"1",1*/
- {0x00,0x70,0x08,0x08,0x08,0x88,0x70,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"2",2*/
- {0x00,0x30,0x08,0x88,0x88,0x48,0x30,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x18,0x20,0x20,0x20,0x11,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"3",3*/
- {0x00,0x00,0xC0,0x20,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x07,0x04,0x24,0x24,0x3F,0x24,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"4",4*/
- {0x00,0xF8,0x08,0x88,0x88,0x08,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x19,0x21,0x20,0x20,0x11,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"5",5*/
- {0x00,0xE0,0x10,0x88,0x88,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x0F,0x11,0x20,0x20,0x11,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"6",6*/
- {0x00,0x38,0x08,0x08,0xC8,0x38,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"7",7*/
- {0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"8",8*/
- {0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x31,0x22,0x22,0x11,0x0F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"9",9*/
- {0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x19,0x24,0x22,0x22,0x22,0x3F,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"a",
- 0*/
- {0x08,0xF8,0x00,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x3F,0x11,0x20,0x20,0x11,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"b",
- 1*/
- {0x00,0x00,0x00,0x80,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x0E,0x11,0x20,0x20,0x20,0x11,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"c",
- 2*/
- {0x00,0x00,0x00,0x80,0x80,0x88,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x0E,0x11,0x20,0x20,0x10,0x3F,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"d",
- 3*/
- 0x00,0x1F,0x22,0x22,0x22,0x22,0x13,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"e",
- 4*/
- {0x00,0x80,0x80,0xF0,0x88,0x88,0x88,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00}};/*"f"
- ,5*/
- unsigned char i;
- void delay(uint x)//延時(shí)
- uint a,b;
- for(a=x;a>0;a--)
- for(b=10;b>0;b--);
- void keycan(void)
- for(i=0;i<4;i++)
- switch(i)
- case 0:
- P1=0x7f;
- delay(5);
- switch(P1|0xf0)
- case 0xfe:cont=0;break;
- case 0xfd:cont=1;break;
- case 0xfb:cont=2;break;
- case 0xf7:cont=3;break;
- default:break;
- case 1:
- P1=0xbf;
- delay(5);
- switch(P1|0xf0)
- case 0xfe:cont=4;break;
- case 0xfd:cont=5;break;
- case 0xfb:cont=6;break;
- case 0xf7:cont=7;break;
- default:break;
- case 2:
- P1=0xdf;
- delay(5);
- switch(P1|0xf0)
- case 0xfe:cont=8;break;
- case 0xfd:cont=9;break;
- case 0xfb:cont=10;break;
- case 0xf7:cont=11;break;
- default:break;
- case 3:
- P1=0xef;
- delay(5);
- switch(P1|0xf0)
- case 0xfe:cont=12;break;
- case 0xfd:cont=13;break;
- case 0xfb:cont=14;break;
- case 0xf7:cont=15;break;
- default:break;
- default:break;
- } void readbusy(void) /* 判斷最高位是否為 1,為 0 才讀寫數(shù)據(jù) */
- P0=0x00;
- cons=P0;
- DI=0;
- RW=1;
- E=1;
- while(cons&0x80);
- E=0;
- void Select(uchar i)
- switch(i)
- case 0:CS1=0;CS2=0;break;
- case 1:CS1=0;CS2=1;break;
- case 2:CS1=1;CS2=0;break;
- default:break;
- void xieminling(uchar value)
- readbusy();/* 每次讀寫都要忙判斷 */
- DI=0;
- RW=0;
- P0=value;
- E=1;
- _nop_();
- _nop_();
- E=0;
- void Setonoff(uchar onoff)
- onoff=0x3e|onoff;
- xieminling(onoff);
- void xieshuju(uchar dat)
- readbusy();
- DI=1;
- RW=0;
- P0=dat;
- E=1;
- _nop_();
- _nop_();
- E=0;
- void Setpage(uchar page)/* 設(shè)置頁(yè) */
- page=0xb8|page;
- xieminling(page);
- void Setline(uchar line) /* 設(shè)置列 */
- line=0x40|line;
- xieminling(line);
- void qingping(uchar screen) /* 清屏*/
- uchar i,j;
- Select(screen);
- for(i=0;i<8;i++)
- Setline(0);
- Setpage(i);
- for(j=0;j<64;j++)
- xieshuju(0x00);
- void chushihua(void)
- Select(0);
- Setonoff(0);
- Select(0);
- Setonoff(1);
- Select(0);
- qingping(0);
- void xianshi(uchar ss,uchar lie,uchar page1,uchar *p)
- uchar i;
- Select(ss);
- Setpage(page1);
- Setline(lie);
- for(i=0;i<16;i++)
- xieshuju(p[i]);
- Setpage(page1+1);
- Setline(lie);
- for(i=0;i<16;i++)
- {xieshuju(p[i+16]);
- void main()
- //xianshi(2,0,2,l);
- //xianshi(2,16*2,2,c);
- //xianshi(1,0,2,dian);
- //xianshi(1,16,2,qi);
- //xianshi(1,16*2,2,shuzi[1]);
- //xianshi(1,16*3,2,ban);
- //xianshi(2,0,4,shuzi[2]);
- //xianshi(2,8,4,shuzi[0]);
- //xianshi(2,16,4,shuzi[1]);
- //xianshi(2,16+8,4,shuzi[1]);
- //xianshi(2,16*2,4,shuzi[0]);
- //xianshi(2,16*2+8,4,shuzi[2]);
- //xianshi(2,16*3,4,shuzi[4]);
- //xianshi(1,0,4,shuzi[1]);
- //xianshi(1,8,4,shuzi[0]);
- //xianshi(1,8+8,4,shuzi[9]);
- while(1)
- chushihua();
- keycan();
- xianshi(2,0,0,shuzi[cont]);
- delay();
12864液晶顯示4x4矩陣鍵盤鍵值 仿真電路.zip
(71.6 KB, 下載次數(shù): 82)
2019-6-12 17:01 上傳
點(diǎn)擊文件名下載附件
