查看: 2105|回復(fù): 3
這是共陽極數(shù)碼管顯示電子鐘的程序。如果是共陰極數(shù)碼管,用74HC138該如何修改呢
ID:548414 發(fā)表于 2019-6-12 18:56 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg51.h>        #include<reg51.h>
//#define char signed char
char code dis_7[12]=
{0xc0,0xf9,0xa4,0x4b0,0x99,0x92,0xb2,0xf8,0x80,0x90,0xff,0xbf};
char code scan_con[8]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
char data dis[8]={0x00,0x00,0x0b,0x00,0x00,0x0b,0x00,0x00};
char data timedata[3]={0x00,0x00,0x00};
char data ms50=0x00,con=0x00,con1=0x00,con2=0x00;
sbit key0=P1^0;
sbit key1=P1^1;
sbit key2=P1^2;
delay1ms(int t)
        int i, j;
        for (i=0; i<t; i++)
           for (j=0; j<120; j++)
keyscan()
EA=0;
if (key0 == 0)
   delay1ms (10);
        while (key0 == 0);
        con++;TR0=0; ET0=0;
        if (con >= 3)
        {con=0;  TR0=1;ET0=1;}
if (con!= 0)
        if(key1==0)
        delay1ms(10);
        while(key1==0);
        timedata[con]++;
        if(con==2) con1=24;else con1=60;
        if(timedata[con]>=con1)
        {timedata[con]=0;}
if (con!=0)
        if (key2==0)
        delay1ms(10);
        while(key2==0);
        timedata[con]--;
        if (con==2) con2=23; else con2=59;
        if(timedata[con]<=0)
        {timedata[con]=con2;}
EA=1;
scan()
        char k;
        dis[0]=timedata[0]%10;dis[1]=timedata[0]/10;
        dis[3]=timedata[1]%10;dis[4]=timedata[1]/10;
        dis[6]=timedata[2]%10;dis[7]=timedata[2]/10;
        for(k=0;k<8;k++)
                P0=dis_7[dis[k]]; P2=scan_con[k]; delay1ms(1); P2=0xff;
main()
TH0=0x3c; TL0=0xb0;
TMOD=0x01; ET0=1; TR0=1; EA=1;
while (1)
scan();
keyscan();
void time_intt0(void) interrupt        1
        ET0=0; TR0=0; TH0=0x3c; TL0=0xb0; TR0=1;
        ms50++;
        if(ms50==20)
ms50=0x00; timedata[0]++;
if(timedata[0]==60)
        timedata[0]=0; timedata[1]++;
        if(timedata[1] ==60)
                timedata[1]=0; timedata[2]++;
                if (timedata[2]==24)
                timedata[2]=0;
ET0=1;
{0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x00,0x40};
sbit key0=P1^0;
sbit key1=P1^1;
sbit key2=P1^2;
sbit LSA=P2^2;
sbit LSB=P2^3;
sbit LSC=P2^4;
delay1ms(int t)
        int i, j;
        for (i=0; i<t; i++)
keyscan()
EA=0;
if (key0 == 0)
   delay1ms (10);
        while (key0 == 0);
        con++;TR0=0; ET0=0;
        if (con >= 3)
if (con!= 0)
        if(key1==0)
        delay1ms(10);
        while(key1==0);
        timedata[con]++;
        {timedata[con]=0;}
if (con!=0)
        if (key2==0)
        delay1ms(10);
        while(key2==0);
        timedata[con]--;
EA=1;
scan()
        char k;
        for(k=0;k<8;k++)
main()
TH0=0x3c; TL0=0xb0;
while (1)
scan();
keyscan();
        ms50++;
        if(ms50==20)
if(timedata[0]==60)
                timedata[2]=0;
ET0=1;
ID:123289 發(fā)表于 2019-6-13 11:43 | 只看該作者
補一下電路基礎(chǔ)課。
ID:343799 發(fā)表于 2019-6-18 16:50 | 只看該作者
程序可以不用改,可以改硬件,38譯碼器的輸出端接八個非門就行了,
ID:517466 發(fā)表于 2019-6-18 21:12 | 只看該作者
138為8選一輸出,被選中的輸出0,用0驅(qū)動共陰數(shù)碼管的陽極,可以考慮加PNP三極管,或者使用與非門+ULN2003的方式。用非門直接驅(qū)動的方式不可取,同時點亮7個筆段的話,輸出需要70mA電流,會燒毀非門芯片的。
