查看: 947|回復(fù): 1
最近寫了個(gè)單片機(jī)小車的程序分享一下
ID:463527 發(fā)表于 2019-6-17 10:13 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
喜歡32的朋友可以看一下 ,遙控的32小車程序
  1. #include "reg52.h"
  2. #include<intrins.h>
  4. #define uint unsigned int
  5. uchar count;      //0.5ms次數(shù)標(biāo)識(shí)
  6. uchar jd;         //角度標(biāo)識(shí)
  7. sbit DJ0 = P1^0;
  8. sbit DJ1 = P1^1;
  9. sbit DJ2 = P1^2;
  10. sbit DJ3 = P1^3;
  11. sbit Trig = P2^2;                        //超聲波引腳
  12. sbit Echo = P2^3;
  13. unsigned int  time=0;
  14. unsigned long S=0;
  15. bit      flag =0;
  16. unsigned char disbuff[4]           ={ 0,0,0};
  17. sbit pwm = P2^4;          //PWM信號(hào)輸出
  18. sbit led = P1^4 ;          //led信號(hào)輸出
  19. uchar code table[]="I LOVE MCU!";
  20. sbit lcden=P2^6;        //液晶 使能
  21. sbit lcdrs=P2^7;        //液晶 數(shù)據(jù)命令
  22. void delay(uint z)                //延時(shí)函數(shù)
  23. {
  24.         uint x,y;
  25.         for(x=z;x>0;x--)
  26.                 for(y=110;y>0;y--);
  27. }
  28. void Stop()                                //小車停止
  29. {
  30.         DJ0 = 0;
  31.         DJ1 = 0;
  32.         DJ2 = 0;
  33.         DJ3 = 0;
  34.
  35. }
  36. void XiaoChe_GO()           //小車前進(jìn)
  37. {
  38.         DJ0 = 0;
  39.         DJ1 = 1;
  40.         DJ2 = 0;
  41.         DJ3 = 1;
  42.
  43. }
  44. void XiaoChe_Back()           //小車后退
  45. {
  46.         DJ0 = 1;
  47.         DJ1 = 0;
  48.         DJ2 = 1;
  49.         DJ3 = 0;
  50. }
  51. void XiaoChe_Zuo()           //小車左轉(zhuǎn)
  52. {
  53.         DJ0 = 1;
  54.         DJ1 = 0;
  55.         DJ2 = 0;
  56.         DJ3 = 1;
  57. }
  58. void XiaoChe_You()           //小車右轉(zhuǎn)
  59. {
  60.         DJ0 = 0;
  61.         DJ1 = 1;
  62.         DJ2 = 1;
  63.         DJ3 = 0;
  64. }
  65. void write_com(uchar com)
  66. {
  67.         lcdrs=0;
  68.         P0=com;
  69.         delay(5);
  70.         lcden=1;
  71.         delay(5);
  72.         lcden=0;
  73. }
  74. void write_data(uchar date)
  75. {
  76.         lcdrs=1;
  77.         P0=date;
  78.         delay(5);
  79.         lcden=1;
  80.         delay(5);
  81.         lcden=0;
  82. }
  83. void init()
  84. {
  85.         lcden=0;
  86.         write_com(0x38);
  87.         write_com(0x0c);
  88.         write_com(0x06);
  89.         write_com(0x01);
  90. }
  91. void Time0_Init()          //定時(shí)器初始化
  92. {
  93.         TMOD = 0x11;           //定時(shí)器0工作在方式1   定時(shí)器1工作在方式1
  94.         TH0  = 0xfe;
  95.         TL0  = 0x33;                   //11.0592MZ晶振,0.5ms
  96.         TH1 = 0;
  97.         TL1 = 0;
  98.
  99.         EA=1;
  100.         ET0=1;
  101.         ET1=1;
  102.         TR0=1;                 //定時(shí)器開始  用于舵機(jī)轉(zhuǎn)向
  103. }
  104. /*
  105. void Time0_Int() interrupt 1 //中斷程序
  106. {
  107.                 TH0  = 0xfe;             //重新賦值
  108.                 TL0  = 0x33;
  109.     if(count<jd)              //判斷0.5ms次數(shù)是否小于角度標(biāo)識(shí)
  110.       pwm=1;                  //確實(shí)小于,PWM輸出高電平
  111.     else
  112.       pwm=0;                  //大于則輸出低電平
  113.     count=(count+1);          //0.5ms次數(shù)加1
  114.     count=count%40;                          //次數(shù)始終保持為40 即保持周期為20ms
  115. }
  116. */
  117. void zd0() interrupt 3                  //T0中斷用來計(jì)數(shù)器溢出,超過測(cè)距范圍
  118.   {
  119.     flag=1;                                                         //中斷溢出標(biāo)志
  120.   }
  121. void  StartModule()                          //啟動(dòng)模塊
  122.   {
  123.           Trig=1;                                             //啟動(dòng)一次模塊
  124.           _nop_();
  125.           _nop_();
  126.           _nop_();
  127.           _nop_();
  128.           _nop_();
  129.           _nop_();
  130.           _nop_();
  131.           _nop_();
  132.           _nop_();
  133.           _nop_();
  134.           _nop_();
  135.           _nop_();
  136.           _nop_();
  137.           _nop_();
  138.           _nop_();
  139.           _nop_();
  140.           _nop_();
  141.           _nop_();
  142.           _nop_();
  143.           _nop_();
  144.           _nop_();
  145.           Trig=0;
  146.   }
  147. void Conut(void)                        //計(jì)算結(jié)果
  148. {
  149.          time=TH1*256+TL1;
  150.          TH1=0;
  151.          TL1=0;
  152.
  153.          S=(time*1.7)/10;     //算出來是MM
  154.         if((S>=700)||flag==1) //超出測(cè)量范圍顯示“-”
  155.          {
  156.                  flag=0;
  157.                  XiaoChe_GO();
  158.                  disbuff[0]=45;
  159.            disbuff[1]=45;
  160.            disbuff[2]=45;
  161.          }
  162.          else if(S < 100)
  163.          {
  164.                  XiaoChe_Zuo();
  165.                  delay(300);
  166.                  Stop();
  167.                  disbuff[0]=S%1000/100 + 0x30;
  168.            disbuff[1]=S%1000%100/10 + 0x30;
  169.            disbuff[2]=S%1000%10 %10 + 0x30;
  170.          }
  171.         else
  172.         {
  173.                  disbuff[0]=S%1000/100 + 0x30;
  174.            disbuff[1]=S%1000%100/10 + 0x30;
  175.            disbuff[2]=S%1000%10 %10 + 0x30;
  176.         }
  177.
  178. }
  179. void main()
  180. {
  181.         int x=0;
  182.         uchar num;
  183.   Time0_Init();
  184.         init();
  185.         write_com(0x80);
  186.         for(num=0;num<11;num++)
  187.         {
  188.                 write_data(table[num]);
  189.                 delay(5);
  190.         }
  191. while(1)
  192. {
  193.                          x++;
  194.                          StartModule();
  195.              while(!Echo);                //當(dāng)RX為零時(shí)等待
  196.              TR1=1;                            //開啟計(jì)數(shù)
  197.              while(Echo);                        //當(dāng)RX為1計(jì)數(shù)并等待
  198.              TR1=0;                                //關(guān)閉計(jì)數(shù)
  199.        Conut();                        //計(jì)算
  200.                          write_com(0x80+0x40);
  201.                                 for(num=0;num<3;num++)
  202.                                 {
  203.                                         write_data(disbuff[num]);
  204.                                         delay(5);
  205.                                 }
  206.                          delay(50);
  207.                         jd = 1;
  208.                         count = 0;
  209.                         delay(100);
  210.                         jd = 2;
  211.                         count = 0;
  212.                         delay(100);
  213.                         jd = 3;
  214.                         count = 0;
  215.                         delay(100);
  216.                         jd = 4;
  217.                         count = 0;
  218.                         delay(100);
  219.                         jd = 5;
  220.                         count = 0;
  221.                         delay(100);
  222.
  223.
  224.                         if(x%2 == 0)
  225.                                 led = !led;
  226.
  227. }
  228. }
ID:1 發(fā)表于 2019-6-17 14:49 | 只看該作者
本帖需要重新編輯補(bǔ)全電路原理圖,源碼,詳細(xì)說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
