查看: 2672|回復(fù): 3
超聲波避障小車
ID:567008 發(fā)表于 2019-6-19 16:52 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
本帖最后由 anan111 于 2019-6-19 16:58 編輯
這是我自己做的超聲波避障小車。
1.51單片機
2.L298N驅(qū)動板
3.電機2
4.差速輪2,萬向輪1
enA,enB可不接
#include<reg52.h>
//定義L298N端口
sbit in1 = P0^0;
sbit in2 = P0^1;
sbit in3 = P0^2;
sbit in4 = P0^3;
sbit enA = P0^4;
sbit enB = P0^5;
//定義超聲波模塊端口
sbit Trig = P1^2;
sbit Echo = P1^3;
unsigned int distance_cm = 0;   //距離
unsigned int overflow_count = 0;  //溢出計數(shù)
unsigned int status = 0;    //超聲波模塊狀態(tài)
unsigned int dis_count = 0;    //計數(shù)
unsigned char tmp, dat, flat;
unsigned int num, model, c=0;
unsigned int speed = 100;
void chaoshengbo_init(void);
void GetDistance(void);
void delay(unsigned int z)
unsigned int x, y;
for(x = z; x > 0 ; x--)
  for(y=110;y>0;y--)
void delay_us(unsigned int aa)
while(aa--);
//小車右轉(zhuǎn)
void right(unsigned char pwm)
enA = 1;
in1 = 0;
in2 = 1;
in3 = 0;
in4 = 0;
delay_us( pwm );
enA = 1;
in1 = 0;
in2 = 0;
in3 = 0;
in4 = 0;
delay_us( 100 - pwm );
void r(void)
enA = 1;
in1 = 0;
in2 = 1;
in3 = 0;
in4 = 0;
//小車左轉(zhuǎn)
void left(unsigned char pwm)
enA = 1;
in1 = 0;
in2 = 0;
in3 = 1;
in4 = 0;
delay_us( pwm );
enA = 1;
in1 = 0;
in2 = 0;
in3 = 0;
in4 = 0;
void l(void)
enA = 1;
in1 = 0;
in2 = 0;
in3 = 1;
in4 = 0;
//小車后退
void back(unsigned char pwm)
enA = 1;
enB = 1;
in1 = 1;
in2 = 0;
in3 = 1;
in4 = 0;
delay_us( pwm );
enA = 1;
in1 = 0;
in2 = 0;
in3 = 0;
in4 = 0;
void b(void)
enA = 1;
enB = 1;
in1 = 1;
in2 = 0;
in3 = 1;
in4 = 0;
//小車前進
void forward(unsigned char pwm)
enA = 1;
enB = 1;
in1 = 0;
in2 = 1;
in3 = 0;
in4 = 1;
delay_us( pwm );
enA = 1;
in1 = 0;
in2 = 0;
in3 = 0;
in4 = 0;
void f(void)
enA = 1;
enB = 1;
in1 = 0;
in2 = 1;
in3 = 0;
in4 = 1;
//小車停止
void stop(void)
enB = 1;
in1 = 0;
in2 = 0;
in3 = 0;
in4 = 0;
void main(void)
chaoshengbo_init();
  b();
  GetDistance();
  if(distance_cm > 0 && distance_cm <= 15)
   f();
   delay(1000);
   r();
   delay(1000);
//超聲波模塊初始化
Trig = 0;
//TH2 = RCAP2H = 0;
//TL2 = RCAP2L = 0;
TH0 = TL0 = 0;
TR0 = 0; //關(guān)閉定時器2
ET0 = 1; //允許T2中斷
//超聲波模塊獲取距離
Trig = 1; //發(fā)送觸發(fā)信號
status = 1;   //status狀態(tài)默認位1
TH0 = 0;
TL0 = 0;
TR0 = 1; //打開定時器2
while(TL0 < 42)  //產(chǎn)生超過10us的脈沖
status = 2;   //狀態(tài)設(shè)為2
Trig = 0;
TR0 = 0;
TH0 = 0;
TL0 = 0;
overflow_count = 0;
TR0 = 1;    //打開定時器2
while(Echo == 0)   //當無信號返回時
  if(status == 5)
   status = 0;
   distance_cm = 0;
   break ; //失敗
TR0 = 0; //清空計數(shù)
TH0 = 0;
TL0 = 0;
overflow_count = 0;
TR0 = 1;
while(Echo == 1) //有信號返回時,開始計算長度
  if(status == 5) //status為5時失敗
   status = 0;
   distance_cm = 0;
   TR0 = 0;
   break ;
dis_count = overflow_count * 65536 + TH0 * 256 + TL0;
TR0 = 0;
distance_cm = (unsigned int)( (long)(dis_count) * 34 / 10000);
status = 0 ; //準備下次發(fā)送
//定時器2中斷
void Timer0Int() interrupt 1
TF0 = 0;
overflow_count++;
TH0 = 0;
TL0 = 0;
if(overflow_count == 2)
  status = 5;  //超時
car_chaoshengbo.zip
1.21 KB, 下載次數(shù): 51, 下載積分: 黑幣 -5
ID:415234 發(fā)表于 2019-10-1 22:16 | 只看該作者
感謝分享
ID:617305 發(fā)表于 2019-10-2 07:58 | 只看該作者
感謝分享,不知道實測效果如何?
ID:644311 發(fā)表于 2019-12-17 08:57 來自觸屏版 | 只看該作者
有仿真圖嗎
