- //程序如下:
- #include <reg51.h>
- #define uchar unsigned char
- #define uint unsigned int
- sbit key1=P3^2;//按key1可切換花樣
- sbit key2=P3^3;//按key2可切換歌曲
- sbit fm=P3^7;//蜂鳴器連續(xù)的IO口
- uchar code huayang1[]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe,
- 0xfd,0xfb,0xf7,0xef,0xdf,0xbf};//花樣1
- uchar code huayang2[]={0x7f,0xfe,0xbf,0xfd,0xdf,0xfb,0xef,0xf7,
- 0xef,0xfb,0xdf,0xfd,0xbf,0xfe};//花樣2
- uchar code huayang3[]={0x7f,0x3f,0x1f,0x0f,0x07,0x03,0x01,0x0,
- 0x80,0xc0,0xe0,0xf0,0xf8,0xfc,0xfe,0xff};//花樣3
- char code huayang4[]={0x55,0xaa,0xcc,0x33,0x99,0x66,0x0f,0xf0};
- uchar count1;//花樣標志
- uchar count2;//歌曲標志
- uchar timeh,timel,i;
- //---------------------------簡譜---------------------------------------
- //編程規(guī)則:字節(jié)高位是簡譜,低位是持續(xù)時間,
- //代表多少個十六分音符
- //1-7代表中央C調,8-E代表高八度,0代表停頓
- //最后的0是結束標志
- uchar code qnzl[]={ //千年之戀
- 0x12,0x22,0x34,0x84,0x74,0x54,0x38,0x42,0x32,0x22,0x42,0x34,0x84,0x72,0x82,0x94,0xA8,0x08,
- //前奏
- 0x32,0x31,0x21,0x32,0x52,0x32,0x31,0x21,0x32,0x62,
- //竹林的燈火 到過的沙漠
- 0x32,0x31,0x21,0x32,0x82,0x71,0x81,0x71,0x51,0x32,0x22,
- //七色的國度 不斷飄逸風中
- //有一種神秘 灰色的旋渦
- 0x32,0x31,0x21,0x32,0x83,0x82,0x71,0x72,0x02,
- //將我卷入了迷霧中
- 0x63,0xA1,0xA2,0x62,0x92,0x82,0x52,
- //看不清的雙手
- 0x31,0x51,0x63,0x51,0x63,0x51,0x63,0x51,0x62,0x82,0x7C,0x02,
- //一朵花傳來誰經過的溫柔
- 0x61,0x71,0x82,0x71,0x62,0xA2,0x71,0x76,
- //穿越千年的傷痛
- 0x61,0x71,0x82,0x71,0x62,0x52,0x31,0x36,
- //只為求一個結果
- 0x61,0x71,0x82,0x71,0x62,0xA3,0x73,0x62,0x53,
- //你留下的輪廓 指引我
- 0x42,0x63,0x83,0x83,0x91,0x91,
- //黑夜中不寂寞
- 0x61,0x71,0x82,0x71,0x62,0x0A2,0x71,0x76,
- //穿越千年的哀愁
- //是你在盡頭等我
- //最美麗的感動 會值得
- 0x42,0x82,0x88,0x02,0x74,0x93,0x89,0xff//結束標志
- //用一生守候
- uchar code jmszl[]={ //寂寞沙洲冷
- 0x12,0x12,0x22,0x32,0x31,0x22,0x21,0x22,
- //自你走后心憔悴
- 0x21,0x31,0x51,0x52,0x31,0x52,0x61,0x15,0x14,
- //白色油桐風中紛飛
- 0x51,0x52,0x31,0x52,0x62,0x13,0x11,0x13,0x32,0x28,0x08,0x28,
- //落花似人有情 這個季節(jié)
- 0x31,0x32,0x31,0x32,0x11,0x21,0x51,0x52,0x51,0x52,
- //河畔的風放肆拼命地吹
- 0x51,0x51,0x31,0x32,0x31,0x32,0x81,0x72,0x63,
- //不斷撥弄離人的眼淚
- 0x62,0x71,0x81,0x72,0x61,0x61,0x52,0x31,0x21,0x32,0x51,0x54,
- //那樣濃烈的愛再也無法給
- 0x22,0x12,0x11,0x12,0x11,0x12,0x12,0x14,0x26,0x32,0x26,
- //傷感一夜一夜
- 0x32,0x61,0x51,0x51,0x31,0x31,0x21,0x31,0x51,0x61,0x51,0x31,0x51,
- //當記憶的線纏繞過往支離破碎
- 0x02,0x32,0x81,0x81,0x81,0x81,0x62,0x52,0x34,
- //是慌亂占據(jù)了心扉
- 0x31,0x81,0x81,0x81,0x61,0x91,0x82,
- //有花兒伴著蝴蝶
- 0x51,0x51,0x51,0x51,0x31,0x61,0x53,
- //孤雁可以雙飛
- 0x21,0x11,0x21,0x11,0x22,0x11,0x21,0x26,
- //夜深人靜獨徘徊
- 0x32,0x61,0x51,0x51,0x31,0x31,0x21,0x31,0x51,0x61,0x51,0x31,0x51,0x52,
- //當幸福戀人寄來紅色分享喜悅
- 0x31,0x31,0x81,0x81,0x81,0x61,0x91,0x81,0x61,0x31,0x56,
- //閉上雙眼難過頭也不敢回
- 0x32,0x32,0x81,0x81,0x81,0x81,0x91,0x81,0x61,0x81,0x61,0x51,0x31,0x51,0x34,
- //仍然撿盡寒枝不肯安歇微帶著后悔
- 0x21,0x31,0x51,0x31,0x21,0x11,0x61,0x21,0x16,
- //寂寞沙洲我該思念誰
- 0xff};
- //----------------------------簡譜音調對應的定時器初值---------------------------
- //適合11.0592M的晶振
- uchar code cuzhi[]={
- 0xff,0xff,//占位
- 0xFC,0x8E,//中央C調1-7
- 0xFC,0xED,
- 0xFD,0x43,
- 0xFD,0x6A,
- 0xFD,0xB3,
- 0xFD,0xF3,
- 0xFE,0x2D,
- 0xFE,0x47, //高八度1-7
- 0xFE,0x76,
- 0xFE,0xA1,
- 0xFE,0xC7,
- 0xFE,0xD9,
- 0xFE,0xF9,
- 0xFF,0x16
- uchar yinyue[]={0xff,0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f,0x0,0x0};
- //將音調轉化為對應的LED樣式
- void delay1(uint z); //延時1MS
- void delay(uint z); //延時165MS,即十六分音符
- void song();
- void beep();//蜂鳴器叫一聲
- main()
- { uchar x;
- count1=0;//流水燈無花樣
- count2=1;//唱第一首歌
- EA=1;//開總中斷
- EX0=1;//開外部中斷0
- IT0=1;//外部中斷0下降沿觸發(fā)方式
- EX1=1;//開外部中斷1
- IT1=1;//外部中斷1下降沿觸發(fā)方式
- TMOD=0x01;//定時器0工作在方式1
- TH0=0;
- TL0=0;
- ET0=1;
- while(1)
- if(count1!=0)
- switch(count1)
- case 1:
- for(x=0;x<14;x++)
- P1=huayang1[x];
- beep();
- delay1(300);
- if(count1!=1)
- break;
- break;
- case 2:
- for(x=0;x<14;x++)
- P1=huayang2[x];
- beep();
- delay1(300);
- if(count1!=2)
- break;
- break;
- case 3:
- for(x=0;x<16;x++)
- P1=huayang3[x];
- beep();
- delay1(300);
- if(count1!=3)
- break;
- break;
- case 4:
- for(x=0;x<8;x++)
- P1=huayang4[x];
- beep();
- delay1(300);
- if(count1!=4)
- break;
- break;
- else
- song();
- delay1(1000);
- void int0() interrupt 0
- EA=0;//關總中斷
- delay1(1);//去抖
- if(key1==0)
- count2=0;//不讓蜂鳴器唱歌
- TR0=0;
- count1++;
- if(count1==5)
- count1=1;
- EA=1;//開總中斷
- void int1() interrupt 2
- EA=0;//關總中斷
- delay1(1);//去抖
- if(key2==0)
- count1=0;//流水燈無花樣
- TR0=1;
- i=0;//從頭開始唱
- count2++;
- if(count2==3)
- count2=1;
- EA=1;//開總中斷
- void timer0() interrupt 1 //用于產生各種音調
- TH0=timeh;
- TL0=timel;
- fm=~fm;
- void song()
- uint temp,duan;
- uchar jp;//jp是簡譜
- i=0;
- while(1)
- { if(count2==0)
- break;
- if(count2==1) //選曲
- temp=qnzl[i];
- if(count2==2)
- temp=jmszl[i];
- if(temp==0xff)
- break;
- jp=temp/16; //取數(shù)的高4位
- duan=1;
- P1=yinyue[jp];
- duan=0;
- if(jp!=0)
- timeh=cuzhi[jp*2];
- timel=cuzhi[jp*2+1];
- else
- TR0=0;
- fm=1;//關蜂鳴器
- delay(temp%16); //取數(shù)的低4位
- TR0=0; //唱完一個音停10MS
- fm=1;
- delay1(10);
- TR0=1;
- i++;
- TR0=0;
- fm=1;
- void delay(uint z) //延時165MS,即十六分音符
- { uint x,y;
- for(x=z;x>0;x--)
- for(y=19000;y>0;y--);
- void delay1(uint z) //延時1MS
- { uint x,y;
- for(x=z;x>0;x--)
- for(y=112;y>0;y--);
- void beep() //蜂鳴器叫一聲
- { uchar i;
- for(i=0;i<50;i++)
- { fm=~fm;
- delay1(1);
- fm=1;
復制代碼 |
