查看: 1373|回復: 0
基于lcd1602的秒表
ID:566620 發(fā)表于 2019-6-20 10:28 | 顯示全部樓層 |閱讀模式
#include <reg52.h>
/* 系統(tǒng)時鐘 */
#define SYS_XTAL (11059200UL/12)
/* 定時器T0重載值 */
unsigned char thr0, tlr0;
unsigned char thr1, tlr1;
/* 跑表計數(shù) */
unsigned char timer[9] = {0, 0, 0, 0, 0, 0, 0, 0, 0}; //分別表示跑表的各個位上的數(shù)字
bit flag10ms = 0;
extern bit stopflag;//跑表走停標志位
extern void InitalLCD1602();
extern void LcdShowStr(unsigned char x, unsigned char y, unsigned char * str);
extern void KeyDriver();
extern void KeyScan();
void DisplayTimer();
void ConfigTimer0(unsigned int xms);
void ConfigTimer1(unsigned int xms);
/* 主函數(shù)main() */
void main(void)
    ConfigTimer0(10);                    //定時10ms
    ConfigTimer1(1);
    InitalLCD1602();
    LcdShowStr(0, 0, "stopwatch");
    LcdShowStr(2, 1, "0000000.00 s");     //液晶初始化顯示
    LcdShowStr(10, 0, "stop!");
    while (1)
        KeyDriver();
        DisplayTimer();
        if ((flag10ms == 1) && (stopflag == 1))
            flag10ms = 0;
            timer[0]++;
            if (timer[0] > 9)
                timer[0] = 0;
                timer[1]++;
                if (timer[1] > 9)
                    timer[1] = 0;
                    timer[2]++;
                    if (timer[2] > 9)
                        timer[2] = 0;
                        timer[3]++;
                        if (timer[3] > 9)
                            timer[3] = 0;
                            timer[4]++;
                            if (timer[4] > 9)
                                timer[4] = 0;
                                timer[5]++;
                                if (timer[5] > 9)
                                    timer[5] = 0;
                                    timer[6]++;
                                    if (timer[6] > 9)
                                        timer[6] = 0;
                                        timer[7]++;
                                        if (timer[7] > 9)
                                            timer[7] = 0;
                                            timer[8]++;
                                            if (timer[8] > 9)
                                                timer[8] = 0;
/* 將跑表時間顯示到液晶上 */
void DisplayTimer()
    unsigned char str[20];
    /* 分解timer */
    str[0] = timer[8] + '0';
    str[1] = timer[7] + '0';
    str[2] = timer[6] + '0';
    str[3] = timer[5] + '0';
    str[4] = timer[4] + '0';
    str[5] = timer[3] + '0';
    str[6] = timer[2] + '0';
    str[7] = '.';
    str[8] = timer[1] + '0';
    str[9] = timer[0] + '0';
    str[10] = '\0';
    LcdShowStr(2, 1, str);
/* 定時器T0配置 */
    unsigned long tmp;
    tmp = (SYS_XTAL * xms) / 1000;
    tmp = 65536-tmp + 18;
    thr0 = (unsigned char)(tmp >> 8) ;
    tlr0 = (unsigned char)tmp;
    TMOD &= 0xF0;                   //清零T0控制位
    TMOD |= 0x01;                   //定時器方式1
    TH0 = thr0;
    TL0 = tlr0;
    TR0 = 1;                        //開啟timer0
    ET0 = 1;                        //開啟T0中斷
    EA  = 1;                        //開啟總中斷
/* 配置定時器T1 */
    unsigned long tmp;
    tmp = 65536 - tmp + 18;
    thr1 = (unsigned char)(tmp >> 8);
    tlr1 = (unsigned char)tmp;
    TMOD &= 0x0F;
    TMOD |= 0x10;
    TH1 = thr1;
    TL1 = tlr1;
    TR1 = 1;
    ET1 = 1;
    EA  = 1;
/* 定時器T0中斷服務 */
void Timer0_ISP() interrupt 1
    TH0 = thr0;
    TL0 = tlr0;
    flag10ms = 1; //定時10ms
/* 定時器T1中斷服務 */
void Timer1_ISP() interrupt 3
    TH1 = thr1;
    TL1 = tlr1; //定時1ms
    KeyScan();
  * @file     Lcd1602.c
  * @author   xr
  * @date     2014年5月7日13:33:17
  * @version  V1.2.3
  * @brief    LCD1602液晶底層驅(qū)動
#include <reg52.h>
//LCD1602_IO
sbit LCD1602_RS = P2^6;
sbit LCD1602_RW = P2^5;
sbit LCD1602_EN = P2^7;
#define LCD1602_DB P0
/* 液晶忙碌等待 */
void LCD1602Wait()
    unsigned char sta;
    LCD1602_DB = 0xFF;//總線拉高,檢測液晶狀態(tài)字
    LCD1602_RS = 0;
    LCD1602_RW = 1;
    do
        LCD1602_EN = 1;
        sta = LCD1602_DB;
        LCD1602_EN = 0;//避免液晶輸出數(shù)據(jù)
    } while (sta & 0x80);//狀態(tài)字最高位STA7 == 0空閑,1忙碌
/* 液晶寫命令 */
void LCD1602WriteCmd(unsigned char cmd)
    LCD1602Wait();
    LCD1602_RS = 0;
    LCD1602_RW = 0;
    LCD1602_EN = 0;
    LCD1602_DB = cmd;
    LCD1602_EN = 1;
    LCD1602_EN = 0;
/* 液晶寫數(shù)據(jù) */
void LCD1602WriteData(unsigned char dat)
    LCD1602Wait();
    LCD1602_RS = 1;
    LCD1602_RW = 0;
    LCD1602_EN = 0;
    LCD1602_DB = dat;
    LCD1602_EN = 1;
    LCD1602_EN = 0;
/* 液晶初始化 */
    LCD1602WriteCmd(0x38);
    LCD1602WriteCmd(0x0C);
    LCD1602WriteCmd(0x06);
    LCD1602WriteCmd(0x01);//清屏
/* 寫數(shù)據(jù)到液晶上,字符串str,坐標(x, y),地址addr */
    unsigned char addr;
    if (y == 0)
        addr = 0x00 + x;
        addr = 0x40 + x;
    LCD1602WriteCmd(addr | 0x80);
    while (*str != '\0')
        LCD1602WriteData(*str++);
#include <reg52.h>
/* 按鍵輸出輸入端口定義 */
sbit KEY_IN1 = P1^0;
sbit KEY_IN2 = P1^1;
sbit KEY_IN3 = P1^2;
sbit KEY_IN4 = P1^3;
sbit KEY_OUT1 = P1^7;
sbit KEY_OUT2 = P1^6;
sbit KEY_OUT3 = P1^5;
sbit KEY_OUT4 = P1^4;
extern unsigned char timer[9]; //分別表示跑表的各個位上的數(shù)字
/* 按鍵當前狀態(tài) */
unsigned char volatile keySta[4][4] = {{1, 1, 1, 1}, {1, 1, 1, 1}, {1, 1, 1, 1}, {1, 1, 1, 1}};
/* 按鍵對應標準PC鍵盤編碼 */
const unsigned char code keyCodeMap[4][4] = {
                                 {'1', '2', '3', 0x26},   /* 數(shù)字鍵 1, 2, 3 和 向上鍵 */
                                 {'4', '5', '6', 0x25},   /* 數(shù)字鍵 4, 5, 6 和 向左鍵 */
                                 {'7', '8', '9', 0x28},   /* 數(shù)字鍵 7, 8, 9 和 向下鍵 */
                                 {'0', 0x1B, 0x0D, 0x27}  /* 數(shù)字鍵 0 和 向右鍵 */
bit stopflag = 0;//跑表走停標志位 0 停止,1運行
void KeyAction(unsigned char keycode);
/* 按鍵驅(qū)動函數(shù) */
void KeyDriver()
    /* 上一次按鍵的備份值 */
    static unsigned char keybackup[4][4] = {{1, 1, 1, 1}, {1, 1, 1, 1}, {1, 1, 1, 1}, {1, 1, 1, 1}};
    unsigned char i, j;
    for (i = 0; i < 4; i++)
        for (j = 0; j < 4; j++)
            if (keySta[i][j] != keybackup[i][j])  //當前按鍵狀態(tài)和上一次的按鍵狀態(tài)不同
            {  //按鍵有動作
                if (keybackup[i][j] != 0) //上一次按鍵是彈起
                    KeyAction(keyCodeMap[i][j]); //當前按鍵是想、按下
                keybackup[i][j] = keySta[i][j]; //備份當前按鍵值
/* 按鍵掃描函數(shù) */
void KeyScan()
   unsigned char i = 0;
   static unsigned char keyout = 0;//按鍵行索引
   static unsigned char keybuf[4][4] = {{0xFF, 0xFF, 0xFF, 0xFF}, {0xFF, 0xFF, 0xFF, 0xFF},
   /* 按鍵消抖 */
   keybuf[keyout][0] = (keybuf[keyout][0] << 1) | KEY_IN1;
   keybuf[keyout][1] = (keybuf[keyout][1] << 1) | KEY_IN2;
   keybuf[keyout][2] = (keybuf[keyout][2] << 1) | KEY_IN3;
   keybuf[keyout][3] = (keybuf[keyout][3] << 1) | KEY_IN4;
   /* 更新按鍵的值 */
        if ((keybuf[keyout][i] & 0x1F) == 0x1F)
            //五次檢測按鍵的值都是1
            keySta[keyout][i] = 1;
        else if ((keybuf[keyout][i] & 0x1F) == 0x00)
            //五次檢測的按鍵值都是0
            keySta[keyout][i] = 0;
   /* 按鍵行索引++ */
   keyout++;
   keyout &= 0x03;//到4歸零
   /* 根據(jù)按鍵索引選擇行按鍵進行掃描 */
   switch (keyout)
       case 0: KEY_OUT1 = 0; KEY_OUT4 = 1;//選擇第一行按鍵
       case 1: KEY_OUT2 = 0; KEY_OUT1 = 1;
       case 2: KEY_OUT3 = 0; KEY_OUT2 = 1;
       case 3: KEY_OUT4 = 0; KEY_OUT3 = 1;
       default: break;
/* 按鍵動作函數(shù) */
    if (keycode == 0x3c)       //ESC
        /* 跑表復位 */
        stopflag = 0;
        for (i = 0; i < 9; i++)
            timer[i] = 0;
        LcdShowStr(10, 0, "reset!");
    else if (keycode == 0x0D)  //回車鍵 跑表走停
        if (stopflag == 0)
            stopflag = 1;
            LcdShowStr(10, 0, "start!");
            stopflag = 0;
            LcdShowStr(10, 0, "stop! "); //多寫入一個空格
