查看: 4632|回復: 4
STM32單片機+SHT30溫濕度計程序PCB文件 UART輸出
ID:261562 發(fā)表于 2019-6-20 16:43 | 顯示全部樓層 |閱讀模式
挺不錯的資料,已經(jīng)量產(chǎn),對制作溫濕度計的很有幫助
如果您需要再次燒錄,請按此HEX文件進行燒錄即可,芯片的Option選型按默認配置即可。
演示,燒錄文件STM32F0XX_MD.HEX,HEX格式)放置在這個目錄下面:
...\Project\SHT30\EWARM\STM32F0XX_MD(STM32F0x1xx)\Exe\
燒錄工具一般用 ST-LINK/V2, 或者J-LINK都可以!
Altium Designer畫的PCB圖如下:(51hei附件中可下載工程文件)
單片機源程序如下:
  1. //==============================================================================
  2. //    S E N S I R I O N   AG,  Laubisruetistr. 44, CH-8712 Staefa, Switzerland
  3. //==============================================================================
  4. // Project   :  SHT3x Sample Code (V1.0)
  5. // File      :  sht3x.c (V1.0)
  6. // Author    :  RFU
  7. // Date      :  16-Jun-2014
  8. // Controller:  STM32F100RB
  9. // IDE       :  礦ision V4.71.2.0
  10. // Compiler  :  Armcc
  11. // Brief     :  Sensor Layer: Implementation of functions for sensor access.
  12. //==============================================================================
  13. //-- Includes ------------------------------------------------------------------
  14. #include "sht3x.h"
  15. #include "i2c_hal.h"
  16. //-- Defines -------------------------------------------------------------------
  17. // CRC
  18. #define POLYNOMIAL  0x131 // P(x) = x^8 + x^5 + x^4 + 1 = 100110001
  19. //------------------------------------------------------------------------------
  20. // IO-Pins                             /* -- adapt the defines for your uC -- */
  21. //------------------------------------------------------------------------------
  22. // Reset on port B, bit 12
  23. #define RESET_LOW()  (GPIOB->BSRR = 0x10000000) // set Reset to low
  24. #define RESET_HIGH() (GPIOB->BSRR = 0x00001000) // set Reset to high
  25. // Alert on port B, bit 10
  26. #define ALERT_READ   (GPIOB->IDR  & 0x0400)     // read Alert
  27. //------------------------------------------------------------------------------
  28. //-- Global variables ----------------------------------------------------------
  29. u8t _i2cWriteHeader;
  30. u8t _i2cReadHeader;
  31. //==============================================================================
  32. void SHT3X_Init(u8t i2cAdr){              /* -- adapt the init for your uC -- */
  33. //==============================================================================
  34.         // init I/O-pins
  35.         RCC->APB2ENR |= 0x00000008;  // I/O port B clock enabled
  36.
  37.   // Alert on port B, bit 10
  38.         GPIOB->CRH   &= 0xFFFFF0FF;  // set floating input for Alert-Pin
  39.   GPIOB->CRH   |= 0x00000400;  //
  40.
  41.   // Reset on port B, bit 12
  42.         GPIOB->CRH   &= 0xFFF0FFFF;  // set push-pull output for Reset pin
  43.   GPIOB->CRH   |= 0x00010000;  //
  44.         RESET_LOW();
  45.
  46.   I2c_Init(); // init I2C
  47.   SHT3X_SetI2cAdr(i2cAdr);
  48.
  49.         // release reset
  50.         RESET_HIGH();
  51. }
  52. //==============================================================================
  53. void SHT3X_SetI2cAdr(u8t i2cAdr){
  54. //==============================================================================
  55.   _i2cWriteHeader = i2cAdr << 1;
  56.   _i2cReadHeader = _i2cWriteHeader | 0x01;
  57. }
  58. //==============================================================================
  59. etError SHT3x_ReadSerialNumber(u32t *serialNbr){
  60. //==============================================================================
  61.   etError error; // error code
  62.   u16t serialNumWords[2];
  63.   error = SHT3X_StartWriteAccess();
  64.   // write "read serial number" command
  65.   error |= SHT3X_WriteCommand(CMD_READ_SERIALNBR);
  66.   // if no error, start read access
  67.   if(error == NO_ERROR) error = SHT3X_StartReadAccess();
  68.   // if no error, read first serial number word
  69.   if(error == NO_ERROR) error = SHT3X_Read2BytesAndCrc(&serialNumWords[0], ACK, 100);
  70.   // if no error, read second serial number word
  71.   if(error == NO_ERROR) error = SHT3X_Read2BytesAndCrc(&serialNumWords[1], NACK, 0);
  72.   SHT3X_StopAccess();
  73.
  74.   // if no error, calc serial number as 32-bit integer
  75.   if(error == NO_ERROR)
  76.   {
  77.     *serialNbr = (serialNumWords[0] << 16) | serialNumWords[1];
  78.   }
  79.   return error;
  80. }
  81. //==============================================================================
  82. etError SHT3X_ReadStatus(u16t *status){
  83. //==============================================================================
  84.   etError error; // error code
  85.   error = SHT3X_StartWriteAccess();
  86.   // if no error, write "read status" command
  87.   if(error == NO_ERROR) error = SHT3X_WriteCommand(CMD_READ_STATUS);
  88.   // if no error, start read access
  89.   if(error == NO_ERROR) error = SHT3X_StartReadAccess();
  90.   // if no error, read status
  91.   if(error == NO_ERROR) error = SHT3X_Read2BytesAndCrc(status, NACK, 0);
  92.   SHT3X_StopAccess();
  93.   return error;
  94. }
  95. //==============================================================================
  96. etError SHT3X_ClearAllAlertFlags(void){
  97. //==============================================================================
  98.   etError error; // error code
  99.   error = SHT3X_StartWriteAccess();
  100.   // if no error, write clear status register command
  101.   if(error == NO_ERROR) error = SHT3X_WriteCommand(CMD_CLEAR_STATUS);
  102.   SHT3X_StopAccess();
  103.   return error;
  104. }
  105. //==============================================================================
  106. etError SHT3X_GetTempAndHumi(ft         *temp,
  107.                              ft         *humi,
  108.                              etRepeatab repeatab,
  109.                              etMode     mode,
  110.                              u8t        timeout){
  111. //==============================================================================
  112.   etError error;
  113.
  114.   switch(mode)
  115.   {
  116.     case MODE_CLKSTRETCH: // get temperature with clock stretching mode
  117.       error = SHT3X_GetTempAndHumiClkStretch(temp, humi, repeatab, timeout); break;
  118.     case MODE_POLLING:    // get temperature with polling mode
  119.       error = SHT3X_GetTempAndHumiPolling(temp, humi, repeatab, timeout); break;
  120.     default:
  121.       error = PARM_ERROR; break;
  122.   }
  123.
  124.   return error;
  125. }
  126. //==============================================================================
  127. etError SHT3X_GetTempAndHumiClkStretch(ft         *temp,
  128.                                        ft         *humi,
  129.                                        etRepeatab repeatab,
  130.                                        u8t        timeout){
  131. //==============================================================================
  132.   etError error;        // error code
  133.   u16t    rawValueTemp; // temperature raw value from sensor
  134.   u16t    rawValueHumi; // humidity raw value from sensor
  135.   error = SHT3X_StartWriteAccess();
  136.   // if no error ...
  137.   if(error == NO_ERROR)
  138.   {
  139.     // start measurement in clock stretching mode
  140.     // use depending on the required repeatability, the corresponding command
  141.     switch(repeatab)
  142.     {
  143.       case REPEATAB_LOW:    error = SHT3X_WriteCommand(CMD_MEAS_CLOCKSTR_L); break;
  144.       case REPEATAB_MEDIUM: error = SHT3X_WriteCommand(CMD_MEAS_CLOCKSTR_M); break;
  145.       case REPEATAB_HIGH:   error = SHT3X_WriteCommand(CMD_MEAS_CLOCKSTR_H); break;
  146.       default:              error = PARM_ERROR; break;
  147.     }
  148.   }
  149.   // if no error, start read access
  150.   if(error == NO_ERROR) error = SHT3X_StartReadAccess();
  151.   // if no error, read temperature raw values
  152.   if(error == NO_ERROR) error = SHT3X_Read2BytesAndCrc(&rawValueTemp, ACK, timeout);
  153.   // if no error, read humidity raw values
  154.   if(error == NO_ERROR) error = SHT3X_Read2BytesAndCrc(&rawValueHumi, NACK, 0);
  155.   SHT3X_StopAccess();
  156.   // if no error, calculate temperature in 癈 and humidity in %RH
  157.   if(error == NO_ERROR)
  158.   {
  159.     *temp = SHT3X_CalcTemperature(rawValueTemp);
  160.     *humi = SHT3X_CalcHumidity(rawValueHumi);
  161.   }
  162.   return error;
  163. }
  164. //==============================================================================
  165. etError SHT3X_GetTempAndHumiPolling(ft         *temp,
  166.                                     ft         *humi,
  167.                                     etRepeatab repeatab,
  168.                                     u8t        timeout){
  169. //==============================================================================
  170.   etError error;           // error code
  171.   u16t    rawValueTemp;    // temperature raw value from sensor
  172.   u16t    rawValueHumi;    // humidity raw value from sensor
  173.   error  = SHT3X_StartWriteAccess();
  174.   // if no error ...
  175.   if(error == NO_ERROR)
  176.   {
  177.     // start measurement in polling mode
  178.     // use depending on the required repeatability, the corresponding command
  179.     switch(repeatab)
  180.     {
  181.       case REPEATAB_LOW:    error = SHT3X_WriteCommand(CMD_MEAS_POLLING_L); break;
  182.       case REPEATAB_MEDIUM: error = SHT3X_WriteCommand(CMD_MEAS_POLLING_M); break;
  183.       case REPEATAB_HIGH:                error = SHT3X_WriteCommand(CMD_MEAS_POLLING_H); break;
  184.       default:                                 error = PARM_ERROR; break;
  185.     }
  186.   }
  187.   // if no error, wait until measurement ready
  188.   if(error == NO_ERROR)
  189.   {
  190.     // poll every 1ms for measurement ready until timeout
  191.     while(timeout--)
  192.     {
  193.       // check if the measurement has finished
  194.       error = SHT3X_StartReadAccess();
  195.       // if measurement has finished -> exit loop
  196.       if(error == NO_ERROR) break;
  197.       // delay 1ms
  198.       DelayMicroSeconds(1000);
  199.     }
  200.
  201.                 // check for timeout error
  202.                 if(timeout == 0) error = TIMEOUT_ERROR;
  203.   }
  204.
  205.         // if no error, read temperature and humidity raw values
  206.   if(error == NO_ERROR)
  207.   {
  208.     error |= SHT3X_Read2BytesAndCrc(&rawValueTemp, ACK, 0);
  209.     error |= SHT3X_Read2BytesAndCrc(&rawValueHumi, NACK, 0);
  210.   }
  211.   SHT3X_StopAccess();
  212.   // if no error, calculate temperature in 癈 and humidity in %RH
  213.   if(error == NO_ERROR)
  214.   {
  215.     *temp = SHT3X_CalcTemperature(rawValueTemp);
  216.     *humi = SHT3X_CalcHumidity(rawValueHumi);
  217.   }
  218.   return error;
  219. }
  220. //==============================================================================
  221. etError SHT3X_StartPeriodicMeasurment(etRepeatab  repeatab,
  222.                                       etFrequency freq){
  223. //==============================================================================
  224.   etError error;        // error code
  225.   error = SHT3X_StartWriteAccess();
  226.         // if no error, start periodic measurement
  227.         if(error == NO_ERROR)
  228.         {
  229.     // use depending on the required repeatability and frequency,
  230.           // the corresponding command
  231.                 switch(repeatab)
  232.                 {
  233.                         case REPEATAB_LOW: // low repeatability
  234.                                 switch(freq)
  235.                                 {
  236.                                         case FREQUENCY_HZ5:  // low repeatability,  0.5 Hz
  237.                                                 error |= SHT3X_WriteCommand(CMD_MEAS_PERI_05_L); break;
  238.                                         case FREQUENCY_1HZ:  // low repeatability,  1.0 Hz
  239.                                                 error |= SHT3X_WriteCommand(CMD_MEAS_PERI_1_L); break;
  240.                                         case FREQUENCY_2HZ:  // low repeatability,  2.0 Hz
  241.                                                 error |= SHT3X_WriteCommand(CMD_MEAS_PERI_2_L); break;
  242.                                         case FREQUENCY_4HZ:  // low repeatability,  4.0 Hz
  243.                                                 error |= SHT3X_WriteCommand(CMD_MEAS_PERI_4_L); break;
  244.                                         case FREQUENCY_10HZ: // low repeatability, 10.0 Hz
  245.                                                 error |= SHT3X_WriteCommand(CMD_MEAS_PERI_10_L); break;
  246.                                         default:
  247.                                                 error |= PARM_ERROR; break;
  248.                                 }
  249.                           break;
  250.
  251.                         case REPEATAB_MEDIUM: // medium repeatability
  252.                                 switch(freq)
  253.                                 {
  254.                                         case FREQUENCY_HZ5:  // medium repeatability,  0.5 Hz
  255.                                                 error |= SHT3X_WriteCommand(CMD_MEAS_PERI_05_M); break;
  256.                                         case FREQUENCY_1HZ:  // medium repeatability,  1.0 Hz
  257.                                                 error |= SHT3X_WriteCommand(CMD_MEAS_PERI_1_M); break;
  258.                                         case FREQUENCY_2HZ:  // medium repeatability,  2.0 Hz
  259.                                                 error |= SHT3X_WriteCommand(CMD_MEAS_PERI_2_M); break;
  260.                                         case FREQUENCY_4HZ:  // medium repeatability,  4.0 Hz
  261.                                                 error |= SHT3X_WriteCommand(CMD_MEAS_PERI_4_M); break;
  262.                                         case FREQUENCY_10HZ: // medium repeatability, 10.0 Hz
  263.                                                 error |= SHT3X_WriteCommand(CMD_MEAS_PERI_10_M); break;
  264.                                         default:
  265.                                                 error |= PARM_ERROR; break;
  266.                                 }
  267.                           break;
  268.
  269.                         case REPEATAB_HIGH: // high repeatability
  270.                                 switch(freq)
  271.                                 {
  272.                                         case FREQUENCY_HZ5:  // high repeatability,  0.5 Hz
  273.                                                 error |= SHT3X_WriteCommand(CMD_MEAS_PERI_05_H); break;
  274.                                         case FREQUENCY_1HZ:  // high repeatability,  1.0 Hz
  275.                                                 error |= SHT3X_WriteCommand(CMD_MEAS_PERI_1_H); break;
  276.                                         case FREQUENCY_2HZ:  // high repeatability,  2.0 Hz
  277.                                                 error |= SHT3X_WriteCommand(CMD_MEAS_PERI_2_H); break;
  278.                                         case FREQUENCY_4HZ:  // high repeatability,  4.0 Hz
  279.                                                 error |= SHT3X_WriteCommand(CMD_MEAS_PERI_4_H); break;
  280.                                         case FREQUENCY_10HZ: // high repeatability, 10.0 Hz
  281.                                                 error |= SHT3X_WriteCommand(CMD_MEAS_PERI_10_H); break;
  282.                                         default:
  283.                                                 error |= PARM_ERROR; break;
  284.                                 }
  285.                           break;
  286.                         default:
  287.                                 error |= PARM_ERROR; break;
  288.                 }
  289.         }
  290.   SHT3X_StopAccess();
  291.   return error;
  292. }
  293. //==============================================================================
  294. etError SHT3X_ReadMeasurementBuffer(ft *temp, ft *humi){
  295. //==============================================================================
  296.   etError  error;        // error code
  297.         u16t     rawValueTemp; // temperature raw value from sensor
  298.   u16t     rawValueHumi; // humidity raw value from sensor
  299.         error = SHT3X_StartWriteAccess();
  300.         // if no error, read measurements
  301.         if(error == NO_ERROR)        error = SHT3X_WriteCommand(CMD_FETCH_DATA);
  302.         if(error == NO_ERROR)        error = SHT3X_StartReadAccess();
  303.         if(error == NO_ERROR)        error = SHT3X_Read2BytesAndCrc(&rawValueTemp, ACK, 0);
  304.         if(error == NO_ERROR) error = SHT3X_Read2BytesAndCrc(&rawValueHumi, NACK, 0);
  305.
  306.         // if no error, calculate temperature in 癈 and humidity in %RH
  307.         if(error == NO_ERROR)
  308.         {
  309.                 *temp = SHT3X_CalcTemperature(rawValueTemp);
  310.                 *humi = SHT3X_CalcHumidity(rawValueHumi);
  311.         }
  312.
  313.         SHT3X_StopAccess();
  314.
  315.         return error;
  316. }
  317. //==============================================================================
  318. etError SHT3X_EnableHeater(void){
  319. //==============================================================================
  320.   etError error; // error code
  321.   error = SHT3X_StartWriteAccess();
  322.   // if no error, write heater enable command
  323.   if(error == NO_ERROR) error = SHT3X_WriteCommand(CMD_HEATER_ENABLE);
  324.   SHT3X_StopAccess();
  325.   return error;
  326. }
  327. //==============================================================================
  328. etError SHT3X_DisbaleHeater(void){
  329. //==============================================================================
  330.   etError error; // error code
  331.   error = SHT3X_StartWriteAccess();
  332.   // if no error, write heater disable command
  333.   if(error == NO_ERROR) error = SHT3X_WriteCommand(CMD_HEATER_DISABLE);
  334.   SHT3X_StopAccess();
  335.   return error;
  336. }
  337. //==============================================================================
  338. etError SHT3X_SoftReset(void){
  339. //==============================================================================
  340.   etError error; // error code
  341.   error = SHT3X_StartWriteAccess();
  342.   // write reset command
  343.   error |= SHT3X_WriteCommand(CMD_SOFT_RESET);
  344.   SHT3X_StopAccess();
  345.
  346.         // if no error, wait 50 ms after reset
  347.         if(error == NO_ERROR) DelayMicroSeconds(50000);
  348.   return error;
  349. }
  350. //==============================================================================
  351. void SHT3X_HardReset(void){
  352. //==============================================================================
  353.         // set reset low
  354.         RESET_LOW();
  355. ……………………
  356. …………限于本文篇幅 余下代碼請從51黑下載附件…………
復制代碼
SHT30評估板模塊_PDF_C85041_.7z (1.97 MB, 下載次數(shù): 139)
ID:601925 發(fā)表于 2019-8-20 12:32 | 顯示全部樓層
看起來不錯
ID:337808 發(fā)表于 2019-12-27 22:56 | 顯示全部樓層
謝謝樓主分享,受用非淺。
ID:702004 發(fā)表于 2020-6-30 02:03 | 顯示全部樓層
壓縮包里有原理圖嗎
ID:845778 發(fā)表于 2021-9-9 11:50 | 顯示全部樓層
請問這個開發(fā)軟件是哪個,是keil5嗎
