適合初學(xué)者的簡(jiǎn)易水位控制系統(tǒng)仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
2019-6-25 22:01 上傳
- #include "reg52.h"
- //宏定義
- #define uint unsigned int
- #define uchar unsigned char
- //LCD管腳聲明
- sbit LCDRS = P1^1;
- sbit LCDEN= P1^2;
- //初始化時(shí)顯示的內(nèi)容
- uchar code Init1[]="Tp:00.0 C Ti:000";
- uchar code Init2[]="Up:00 Down:00 ";
- //液晶的基本操作程序
- //LCD延時(shí)
- void LCDdelay(uint z)
- uint x,y;
- for(x=z;x>0;x--)
- for(y=10;y>0;y--);
- //寫命令
- void write_com(uchar com)
- LCDRS=0;
- P0=com;
- LCDdelay(5);
- LCDEN=1;
- LCDdelay(5);
- LCDEN=0;
- //寫數(shù)據(jù)
- void write_data(uchar date)
- LCDRS=1;
- P0=date;
- LCDdelay(5);
- LCDEN=1;
- LCDdelay(5);
- LCDEN=0;
- //顯示時(shí)間溫度數(shù)據(jù)程序
- void Display_1602(uint aa,uchar dss,uchar sxx,uchar xxx)
- //溫度顯示
- write_com(0x80+3);
- write_data('0'+aa/100);
- write_data('0'+aa/10%10);
- write_data('.');
- write_data('0'+aa%10);
- write_data(0xdf);
- //定時(shí)顯示
- write_com(0x80+13);
- write_data('0'+dss/100);
- write_data('0'+dss/10%10);
- write_data('0'+dss%10);
- //上限顯示
- write_com(0x80+0x40+3);
- write_data('0'+sxx/10%10);
- write_data('0'+sxx%10);
- //下限顯示
- write_com(0x80+0x40+13);
- write_data('0'+xxx/10%10);
- write_data('0'+xxx%10);
- //字符顯示程序
- void Display_wd()
- //溫度顯示
- write_com(0x80);
- write_data('S');
- write_data('e');
- write_data('t');
- write_data(' ');
- write_data('s');
- write_data('t');
- write_data('a');
- write_data('t');
- write_data('e');
- //1602初始化程序
- //1602初始化
- void Init1602()
- uchar i=0;
- // write_com(0x01);//清屏
- write_com(0x38);//屏幕初始化
- write_com(0x0c);//打開(kāi)顯示 無(wú)光標(biāo) 無(wú)光標(biāo)閃爍
- write_com(0x06);//當(dāng)讀或?qū)懸粋(gè)字符是指針后一一位
- write_com(0x80);//設(shè)置位置
- for(i=0;i<16;i++)
- write_data(Init1[i]);
- write_com(0x80+0x40);//設(shè)置位置
- for(i=0;i<16;i++)
- write_data(Init2[i]);
- //程序頭函數(shù)
- #include <reg52.h>
- //顯示函數(shù)
- #include <display.h>
- //宏定義
- //LCD管腳聲明
- sbit jdq= P1^0; //加熱繼電器
- sbit shui=P1^3;//加水繼電器
- sbit Feng = P2^6; //蜂鳴器
- //按鍵
- sbit Key1=P1^4; //設(shè)置
- sbit Key2=P1^5; //加
- sbit Key3=P1^6; //減
- sbit Key4=P1^7; //確定
- sbit shang=P3^7;//上限
- sbit xia=P3^6;//下限
- sbit DQ=P2^2; //定義DS18B20總線I/O
- signed char w,bj,bjx,bjd; //溫度值全局變量
- uchar c; //溫度值全局變量
- bit bdata flag=0,flag_BJ,flag_off=1,que;
- //時(shí)間計(jì)算
- #define Imax 14000 //此處為晶振為11.0592時(shí)的取值,
- #define Imin 8000 //如用其它頻率的晶振時(shí),
- #define Inum1 145 //要改變相應(yīng)的取值。
- #define Inum2 700
- #define Inum3 3000
- //解碼變量
- unsigned char Im[4]={0x00,0x00,0x00,0x00};
- //全局變量
- uchar f;
- unsigned char m,Tc;
- unsigned char IrOK;
- //設(shè)置變量
- uchar xx=29;
- //下限
- uchar sx=35;
- //上限
- int ds=0;
- uchar Mode=0;
- void delay(uint z)
- uint i,j;
- for(i=0;i<z;i++)
- for(j=0;j<121;j++);
- //溫度工作程序
- /*****延時(shí)子程序*****/
- void Delay_DS18B20(int num)
- while(num--) ;
- /*****初始化DS18B20*****/
- void Init_DS18B20(void)
- unsigned char x=0;
- DQ = 1; //DQ復(fù)位
- Delay_DS18B20(8); //稍做延時(shí)
- DQ = 0; //單片機(jī)將DQ拉低
- Delay_DS18B20(8); //精確延時(shí),大于480us
- DQ = 1; //拉高總線
- Delay_DS18B20(14);
- x = DQ; //稍做延時(shí)后,如果x=0則初始化成功,x=1則初始化失敗
- Delay_DS18B20(20);
- /*****讀一個(gè)字節(jié)*****/
- unsigned char ReadOneChar(void)
- unsigned char i=0;
- unsigned char dat = 0;
- for (i=8;i>0;i--)
- DQ = 0; // 給脈沖信號(hào)
- dat>>=1;
- DQ = 1; // 給脈沖信號(hào)
- if(DQ)
- dat|=0x80;
- Delay_DS18B20(4);
- return(dat);
- /*****寫一個(gè)字節(jié)*****/
- void WriteOneChar(unsigned char dat)
- for (i=8; i>0; i--)
- DQ = 1;
- DQ = dat&0x10;
- Delay_DS18B20(5);
- DQ = 0;
- dat>>=1;
- /*****讀取溫度*****/
- unsigned int ReadTemperature(void)
- unsigned char a=0;
- unsigned char b=0;
- unsigned int t=0;
- float tt=0;
- Init_DS18B20();
- WriteOneChar(0xC1); //跳過(guò)讀序號(hào)列號(hào)的操作
- WriteOneChar(0x44); //啟動(dòng)溫度轉(zhuǎn)換
- Init_DS18B20();
- WriteOneChar(0xBE); //讀取溫度寄存器
- a=ReadOneChar(); //讀低8位
- b=ReadOneChar(); //讀高8位
- t=b;
- t<<=8;
- t=t|a;
- tt=t*0.00625;
- t= tt*10+0.5; //放大10倍輸出并四舍五入
- return(t);
- /*****讀取溫度*****/
- void check_wendu(void)
- c=ReadTemperature()-5; //獲取溫度值并減去DS18B20的溫漂誤差
- w=c/10; //計(jì)算得到整數(shù)位
- if(w<0){w=0;} //設(shè)置溫度顯示上限
- if(w>99){w=99;} //設(shè)置溫度顯示上限
- //按鍵工作程序
- void Key()
- //模式選擇
- if(Key1==0)
- while(Key1==0);
- Feng=0;
- Mode++;
- Display_wd();
- if(Mode==4)
- Mode=1;
- Feng=1;
- write_com(0x0d);//打開(kāi)顯示 無(wú)光標(biāo) 光標(biāo)閃爍
- switch(Mode)
- case 1:
- write_com(0x80+15);//位置
- Feng=1;
- break;
- case 2:
- write_com(0x80+0x40+4);//位置
- Feng=1;
- break;
- case 3:
- write_com(0x80+0x40+14);//位置
- Feng=1;
- break;
- if(Key2==0&&Mode!=0)
- while(Key2==0);
- Feng=0;
- switch(Mode)
- case 1:
- if(ds<999)
- ds++;
- write_data('0'+ds/100);
- write_data('0'+ds/10%10);
- write_data('0'+ds%10);
- Feng=1;
- break;
- case 2:
- if(sx<99-1)
- sx++;
- write_data('0'+sx/10%10);
- write_data('0'+sx%10);
- Feng=1;
- break;
- case 3:
- if(xx<sx-1)
- xx++;
- write_data('0'+xx/10%10);
- write_data('0'+xx%10);
- Feng=1;
- break;
- if(Key3==0&&Mode!=0)
- while(Key3==0);
- Feng=0;
- switch(Mode)
- case 1:
- if(ds>0)
- ds--;
- Feng=1;
- break;
- case 2:
- if(sx>xx+1)
- sx--;
- Feng=1;
- break;
- case 3:
- if(xx>0)
- xx--;
- Feng=1;
- break;
- if(Key4==0)
- while(Key4==0);
- Feng=0;
- Mode=0;
- // write_com(0x38);//屏幕初始化
- // write_com(0x0c);//打開(kāi)顯示 無(wú)光標(biāo) 無(wú)光標(biāo)閃爍
- Init1602();
- if(ds>0)
- flag=1;
- jdq=1;
- TR1=1;
- Feng=1;
- /* if(IrOK==1)
- if(Im[2]==0x0d) //遙控設(shè)置鍵
- Feng=0;
- Mode++;
- Display_wd();
- if(Mode==4)
- Mode=1;
- Feng=1;
- switch(Mode)
- case 1:
- Feng=1;
- break;
- case 2:
- write_com(0x80+0x40+5);//位置
- Feng=1;
- break;
- case 3:
- Feng=1;
- break;
- //+鍵
- else if(Im[2]==0x40)
- if(Mode!=0)
- Feng=0;
- switch(Mode)
- case 1:
- if(ds<999)
- ds++;
- Feng=1;
- break;
- case 2:
- if(sx<99-1)
- sx++;
- Feng=1;
- break;
- case 3:
- if(xx<sx-1)
- xx++;
- Feng=1;
- break;
- //-鍵
- else if(Im[2]==0x19)
- if(Mode!=0)
- Feng=0;
- switch(Mode)
- case 1:
- if(ds>0)
- ds--;
- Feng=1;
- break;
- case 2:
- if(sx>xx+1)
- sx--;
- Feng=1;
- break;
- case 3:
- if(xx>0)
- xx--;
- Feng=1;
- break;
- //確定鍵
- else if(Im[2]==0x15)
- Feng=0;
- Mode=0;
- Init1602();
- if(ds>0)
- flag=1;
- jdq=1;
- TR1=1;
- Feng=1;
- IrOK=0;
- //報(bào)警部分程序
- void Alam()
- if(flag_BJ==1&&flag_off==1)
- Feng=0;
- delay(1000);
- Feng=1;
- flag_off=0;
- // flag_BJ=0;
- //主程序
- void main()
- Init1602();
- EA=1;//打開(kāi)中斷總開(kāi)關(guān)
- IT1=1;//下降沿有效
- EX1=1;//外部中斷1開(kāi)
- ET1=1;//打開(kāi)允許開(kāi)關(guān)
- TMOD=0x01;//設(shè)置工作方式
- TL1=0x3c;
- TH1=0xb0;//賦初值
- TH0=0;//T0賦初值
- TL0=0;
- TR0=0;//t0開(kāi)始計(jì)時(shí)
- check_wendu();
- delay(1000);
- bjd=99;
- bjx=0;
- while(1)
- check_wendu();
- if(Mode==0)
- Display_1602(c,ds,sx,xx);
- if((xia==1)&&(shang==1)) //低于下限
- que=1;
- shui=0;
- jdq=1;
- else
- que=0;
- if((shang==0)&&(xia==0)) //高于上限
- shui=1;
- if(flag_BJ==0)
- flag_BJ=1;
- if((shang==0)&&(xia==1)) //錯(cuò)誤
- shui=1;
- jdq=1;
- Feng=0;
- que=1;
- if(flag==0)
- if((w<bjd)&&(w>bjx))
- if(w>=sx)
- jdq=1;
- if(flag_BJ==0)
- flag_BJ=1;
- else if((w<xx)&&(que==0))
- jdq=0;
- if(flag_BJ==0)
- flag_BJ=1;
- else
- flag_BJ=0;
- flag_off=1;
- bjd=w+5;
- bjx=w-5;
- Key();
- Alam();
- //定時(shí)器工作程序
- void time1() interrupt 3//定時(shí)器函數(shù)
- uint s;
- TH1=0x3c;
- TL1=0xb0;//重新賦初值
- s++;
- if(s==1200) //s=20為1s鐘 1200為1分鐘
- s=0;
- ds--;
- if(ds==0)
- flag=0;
- if(w>=sx)
- jdq=1;
- if(flag_BJ==0)
- flag_BJ=1;
- jdq=0;
- if(flag_BJ==0)
- flag_BJ=1;
- else
- flag_BJ=0;
- flag_off=1;
- bjd=w+10;
- bjx=w-10;
- TR1=0;
- //準(zhǔn)備讀下一碼
簡(jiǎn)易水位控制.rar
(178.59 KB, 下載次數(shù): 83)
2019-6-25 22:01 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
