查看: 2748|回復(fù): 1
C++語言編寫的Calculator計(jì)算器源程序
ID:572563 發(fā)表于 2019-6-26 13:45 | 顯示全部樓層 |閱讀模式
這是一個(gè)非常實(shí)用的計(jì)算器
想要看密碼就請(qǐng)用Notepad打開C語言文件 然后有一行注釋行://mima...
mima后面的一串?dāng)?shù)字即為密碼
  1. #include<cstdlib>
  2. #include<iostream>
  3. #include<iomanip>
  4. #include<cmath>
  5. #include<windows.h>
  6. using namespace std;
  7. #define size 100
  8. int a[size+1],n,d,i=0,j;
  9. //mima267398323513
  10. main(){
  11.         int sf;
  12.         long long mima;
  13.         cout<<"======================================================="<<endl;
  14.         cout<<"|                  Calculator 2019                    |"<<endl;
  15.         cout<<"|                   Version 3.98                      |"<<endl;
  16.         cout<<"|                                                     |"<<endl;
  17.         cout<<"|                                                     |"<<endl;
  18.         cout<<"|  Adminstrator                                       |"<<endl;
  19.         cout<<"|  Welcome to Calculator_64 Professional              |"<<endl;
  20.         cout<<"|  Update 1907 Professional                           |"<<endl;
  21.         cout<<"|  Designed by Howard Lu                              |"<<endl;
  22.         cout<<"|                                                     |"<<endl;
  23.         cout<<"|                                                     |"<<endl;
  24.         cout<<"|  C-2019-2021                                        |"<<endl;
  25.         cout<<"======================================================="<<endl;
  26.         cout<<"Adminstrator,請(qǐng)輸入密碼"<<endl;
  27.         cout<<"密碼:";
  28.         cin>>mima;
  29.         if(mima==267398323513){
  30.                 system("cls");
  31.         cout<<"Initialization";
  32.         for(int i=1;i<=3;i++){
  33.                 Sleep(1000);
  34.                 cout<<".";
  35.         }
  36.         Sleep(1000);
  37.         system("cls");
  38.         cout<<"Initialization";
  39.         for(int i=1;i<=3;i++){
  40.                 Sleep(1000);
  41.                 cout<<".";
  42.         }
  43.         Sleep(1000);
  44.         system("cls");
  45.         cout<<"C";Sleep(100);
  46.         cout<<"a";Sleep(100);
  47.         cout<<"l";Sleep(100);
  48.         cout<<"c";Sleep(100);
  49.         cout<<"u";Sleep(100);
  50.         cout<<"l";Sleep(100);
  51.         cout<<"a";Sleep(100);
  52.         cout<<"t";Sleep(100);
  53.         cout<<"o";Sleep(100);
  54.         cout<<"r";Sleep(100);
  55.         cout<<"_";Sleep(100);
  56.         cout<<"6";Sleep(100);
  57.         cout<<"4";Sleep(100);
  58.         cout<<" ";Sleep(100);
  59.         cout<<"2";Sleep(100);
  60.         cout<<"0";Sleep(100);
  61.         //cout<<"0";Sleep(100);
  62.         //cout<<".";Sleep(100);
  63.         cout<<"1";Sleep(100);
  64.         //cout<<".";Sleep(100);
  65.         cout<<"9";Sleep(100);
  66.         cout<<" ";Sleep(100);
  67.         cout<<"P";Sleep(100);
  68.         cout<<"R";Sleep(100);
  69.         cout<<"O";Sleep(100);
  70.         cout<<endl;
  71.         do{
  72.         cout<<"================================================================="<<endl;
  73.         cout<<"|                                                               |"<<endl;
  74.         cout<<"|                        微型電子計(jì)算器                         |"<<endl;
  75.         cout<<"|                                                               |"<<endl;
  76.         cout<<"|                                                               |"<<endl;
  77.         cout<<"| 請(qǐng)選擇:                                                      |"<<endl;
  78.         cout<<"| 1. 如果想計(jì)算加減乘除,請(qǐng)輸入1                                |"<<endl;
  79.         cout<<"| 2. 如果想計(jì)算開方,請(qǐng)輸入2                                    |"<<endl;
  80.         cout<<"| 3. 如果想轉(zhuǎn)換進(jìn)制數(shù),請(qǐng)輸入3                                  |"<<endl;
  81.         cout<<"| 4. 如果想要算次方,請(qǐng)輸入4                                    |"<<endl;
  82.         cout<<"| 5. 如果想要算階乘,請(qǐng)輸入5                                    |"<<endl;
  83.         cout<<"| 6. 如果想顯示π,請(qǐng)輸入6                                      |"<<endl;
  84.         cout<<"| 7. 如果想做加法統(tǒng)計(jì),請(qǐng)輸入7                                  |"<<endl;
  85.         cout<<"| 8. 想知道這一天是星期幾,請(qǐng)輸入8                              |"<<endl;
  86.         cout<<"| 9. 想知道從1年1月1日到某年某月月底有幾天,請(qǐng)輸入9             |"<<endl;
  87.         cout<<"| 10.想計(jì)算斐波那契數(shù)列,請(qǐng)輸入10                               |"<<endl;
  88.         cout<<"| 11.關(guān)閉程序,請(qǐng)按11                                           |"<<endl;
  89.         cout<<"| 12.像顯示關(guān)于Calculator 請(qǐng)輸入12                              |"<<endl;
  90.         cout<<"| 若想進(jìn)行如1×2+3×4-5+6之類的多項(xiàng)表達(dá)式運(yùn)算,請(qǐng)打開棧計(jì)算器   |"<<endl;
  91.         cout<<"| 若想進(jìn)行24點(diǎn)計(jì)算,請(qǐng)打開24點(diǎn)計(jì)算器                            |"<<endl;
  92.         cout<<"|                                                               |"<<endl;
  93.         cout<<"|                                                               |"<<endl;
  94.         cout<<"================================================================="<<endl;
  95.         int ds,x,y;
  96.         cin>>ds;
  97.         if(ds==1){
  98.                 char x;
  99.             double a,b;int c,d;
  100.             cout<<"請(qǐng)輸入+,-,*,/,%(求余,兩數(shù)不可為小數(shù))中的一個(gè)運(yùn)算符號(hào):";cin>>x;
  101.             cout<<"請(qǐng)輸入A數(shù):";cin>>a;
  102.             cout<<"請(qǐng)輸入B數(shù):";cin>>b;
  103.             if(x=='/'){
  104.                     cout<<"請(qǐng)問,你想保留幾位小數(shù)?:";cin>>c;
  105.             }
  106.             switch(x){
  107.                     case '+':cout<<a+b<<endl;break;
  108.             case '-':cout<<a-b<<endl;break;
  109.             case '*':cout<<a*b<<endl;break;
  110.             case '/':if(b!=0) cout<<fixed<<setprecision(c)<<(double)a/b<<endl;else cout<<"Divided by zero!"<<endl;break;
  111.             case '%':c=a;d=b;
  112.                                  cout<<c%d<<endl;break;
  113.                         default:cout<<"Invalid operator!"<<endl;
  114.             }
  115.             system("pause");
  116.         }
  117.         if(ds==2){
  118.                 cout<<"請(qǐng)輸入一個(gè)你想開方的數(shù):";cin>>x;
  119.             cout<<"請(qǐng)輸入你想保留幾位小數(shù):";cin>>y;
  120.             cout<<fixed<<setprecision(y)<<sqrt(x)<<endl;
  121.             system("pause");
  122.         }
  123.         if(ds==3){
  124.             //cout<<"Please Enter a number(N) base 10:";cin>>n;
  125.             cout<<"輸入一個(gè)十進(jìn)制數(shù):";cin>>n;
  126.             //cout<<"Please Enter a number(d):";cin>>d;
  127.             cout<<"輸入你想把這個(gè)數(shù)轉(zhuǎn)化成的進(jìn)制數(shù)(幾進(jìn)制):";cin>>d;
  128.             do{
  129.                     a[++i]=n%d;
  130.                     n=n/d;
  131.             }while(n!=0);
  132.             for(j=i;j>=1;j--)cout<<a[j];
  133.             cout<<endl;
  134.             system("pause");
  135.         }
  136.     if(ds==4){
  137.             float a,b,c;
  138.             cout<<"請(qǐng)輸入底數(shù):";cin>>a;
  139.             cout<<"請(qǐng)輸入指數(shù):";cin>>b;
  140.             cout<<"請(qǐng)問你想保留幾位小數(shù):";cin>>c;
  141.             cout<<fixed<<setprecision(c)<<(double)pow(a,b)<<endl;
  142.         system("pause");
  143.         }
  144.         if(ds==5){
  145.                 int t,s;
  146.                   s=0;
  147.                   int a,b,c;
  148.                  cout<<"請(qǐng)輸入你想算的階乘的數(shù)1:";cin>>a;
  149.                  cout<<"請(qǐng)輸入你想算的階乘的數(shù)2:";cin>>b;
  150.                   cout<<"我們將幫你累加從數(shù)1的階乘到數(shù)2的階乘"<<endl;
  151.                   Sleep(1000);
  152.                   for(int i=a;i<=b;++i)
  153.             {
  154.                     t=1;
  155.                     for (int j=1;j<=i;++j)            //求i!
  156.                               t*=j;
  157.                               s+=t;                           //累加i!
  158.                }
  159.                   cout<<s<<endl;;
  160.                   system("pause");
  161.         }
  162.         if(ds==6){
  163.                 cout<<"π=3.1415926535897932384626433872395"<<endl;
  164.                 system("pause");
  165.         }
  166.         if(ds==7){
  167.                 int a,b,sum=0;
  168.             cout<<"請(qǐng)輸入你要統(tǒng)計(jì)數(shù)的個(gè)數(shù):";
  169.             cin>>a;
  170.             for(int i=1;i<=a;i++){
  171.                      cin>>b;
  172.                     sum=sum+b;
  173.             }
  174.             cout<<"Sum="<<sum<<endl;
  175.             system("pause");
  176.         }
  177.         if(ds==8){
  178.                 int day,year,month,day2,date,allday;
  179.                 cout<<"請(qǐng)輸入年月日 例 2018 12 31:";
  180.             cin>>year>>month>>date;
  181.             day=year/4-year/100+year/400;
  182.             if (year%400==0) day2=29+31+30+31+30+31+31+30+31+30+31;
  183.             else if (year%100==0) day2=28+31+30+31+30+31+31+30+31+30+31;
  184.                 else if (year%4==0) day2=29+31+30+31+30+31+31+30+31+30+31;
  185.                     else day2=28+31+30+31+30+31+31+30+31+30+31;
  186.             switch(month){
  187.                     case 1:day2=day2+31;break;
  188.                     case 2:day2=30+31+30+31+30+31+31+30+31+30+31;break;
  189.                     case 3:day2=31+30+31+30+31+31+30+31+30+31;break;
  190.                     case 4:day2=30+31+30+31+31+30+31+30+31;break;
  191.             case 5:day2=31+30+31+31+30+31+30+31;break;
  192.             case 6:day2=30+31+31+30+31+30+31;break;
  193.             case 7:day2=31+31+30+31+30+31;break;
  194.             case 8:day2=31+30+31+30+31;break;
  195.             case 9:day2=30+31+30+31;break;
  196.             case 10:day2=31+30+31;break;
  197.             case 11:day2=30+31;break;
  198.             case 12:day2=31;break;
  199.             }
  200.         allday=366*day+365*(year-day)-day2+date;
  201.         if(allday%7==1) cout<<"星期一"<<endl;
  202.         if(allday%7==2) cout<<"星期二"<<endl;
  203.         if(allday%7==3) cout<<"星期三"<<endl;
  204.         if(allday%7==4) cout<<"星期四"<<endl;
  205.         if(allday%7==5) cout<<"星期五"<<endl;
  206.         if(allday%7==6) cout<<"星期六"<<endl;
  207.         if(allday%7==0) cout<<"星期日"<<endl;
  208.
  209.         system("pause");
  210.         }
  211.         if(ds==9){
  212.                 int day,year,month,day2;
  213.                 cout<<"請(qǐng)輸入年月,例:2018 12:";
  214.             cin>>year>>month;
  215.             day=year/4-year/100+year/400;
  216.             if (year%400==0) day2=29+31+30+31+30+31+31+30+31+30+31;
  217.             else if (year%100==0) day2=28+31+30+31+30+31+31+30+31+30+31;
  218.                 else if (year%4==0) day2=29+31+30+31+30+31+31+30+31+30+31;
  219.                     else day2=28+31+30+31+30+31+31+30+31+30+31;
  220.             switch(month){
  221.                     case 1:day2=day2;break;
  222.                     case 2:day2=31+30+31+30+31+31+30+31+30+31;break;
  223.                     case 3:day2=30+31+30+31+31+30+31+30+31;break;
  224.                     case 4:day2=31+30+31+31+30+31+30+31;break;
  225.             case 5:day2=30+31+31+30+31+30+31;break;
  226.             case 6:day2=31+31+30+31+30+31;break;
  227.             case 7:day2=31+30+31+30+31;break;
  228.             case 8:day2=30+31+30+31;break;
  229.             case 9:day2=31+30+31;break;
  230.             case 10:day2=30+31;break;
  231.             case 11:day2=31;break;
  232.             case 12:day2=0;break;
  233.             }
  234.         cout<<366*day+365*(year-day)-day2<<endl;
  235.         system("pause");
  236.         }
  237.         if(ds==10){
  238.                 cout<<"先輸入一個(gè)數(shù)(第幾項(xiàng)):";int n,n2;cin>>n;
  239.                 cout<<"是想輸出從第一項(xiàng)到第"<<n<<"項(xiàng)的所有數(shù),選1"<<endl;
  240.                 cout<<"是想輸出從第一項(xiàng)到第"<<n<<"項(xiàng)的所有數(shù)的和,選2"<<endl;
  241.                 cin>>n2;
  242.                 if(n2==1){
  243.                         int a,b,tmp,i;
  244.             a = 0;
  245.             b = 1;
  246.             for(i=0;i<n;i++)
  247.             {
  248.                 printf("%d\n",b);
  249.                 tmp = b;
  250.                 b = a + b;
  251.                 a = tmp;
  252.             }
  253.             system("pause");
  254.                 }
  255.                 if(n2==2){
  256.                         int a,b,tmp,i,sum=0;
  257.             a = 0;
  258.             b = 1;
  259.             for(i=0;i<n;i++)
  260.             {
  261.                 tmp = b;
  262.                 sum=sum+tmp;
  263.                 cout<<sum<<endl;
  264.                 b = a + b;
  265.                 a = tmp;
  266.             }
  267.             cout<<"Sum="<<sum<<endl;
  268.             system("pause");
  269.                 }
  270.         }
  271.         if(ds==11) return 0;
  272.         if(ds==12) {
  273.                 system("cls");
  274.                 cout<<"下面是您的賬戶信息:"<<endl;
  275.         cout<<"Adminstrator"<<endl;
  276.         cout<<"管理員"<<endl;
  277.         cout<<"創(chuàng)建時(shí)間:2019/7/29"<<endl;
  278.         cout<<"激活狀態(tài):已激活"<<endl;
  279.         cout<<"激活時(shí)間:2019/7/31"<<endl;
  280.         cout<<"管理員認(rèn)證號(hào):2019-07-29-0001-ASDFG-CLOA-CAL-A0001"<<endl;
  281.         cout<<"信用狀態(tài):未違反任何版權(quán)約定,您可以繼續(xù)使用"<<endl;
  282.
  283.         }
  284.             cout<<"是否想要繼續(xù):是1,否2, 發(fā)送錯(cuò)誤信息并關(guān)閉程序3:";cin>>sf;
  285.             Sleep(100);
  286.             system("cls");
  287.             if(sf==3){
  288.                     cout<<"Sending Messages";
  289.                     cout<<".";
  290.                     Sleep(500);
  291.                     cout<<".";
  292.                     Sleep(500);
  293.                     cout<<".";
  294.                     Sleep(500);
  295.                     system("cls");
  296.                     cout<<"Sending Messages";
  297.                     cout<<".";
  298.                     Sleep(500);
  299.                     cout<<".";
  300.                 Sleep(500);
  301.                     cout<<".";
  302.                     Sleep(500);
  303.                     system("cls");
  304.             }
  305.         //do{
  306.         //cout<<"是否想要繼續(xù):是1,否2, 發(fā)送錯(cuò)誤信息3:";cin>>sf;
  307.             //Sleep(100);
  308.             //system("cls");
  309.             //if(sf==3){
  310.                 //    cout<<"正在使用高速通道發(fā)送錯(cuò)誤信息";
  311.                 //    cout<<".";
  312.             //        Sleep(500);
  313.             //        cout<<".";
  314.             //        Sleep(500);
  315.             //        cout<<".";
  316.             //        Sleep(500);
  317.             //        system("cls");
  318.             //        cout<<"正在使用高速通道發(fā)送錯(cuò)誤信息";
  319.             //        cout<<".";
  320.             //        Sleep(500);
  321.             //        cout<<".";
  322.             //    Sleep(500);
  323.             //        cout<<".";
  324.             //        Sleep(500);
  325.             //        system("cls");
  326.             //}
  327.                 //}while(sf==3);
  328.     }while(sf==1);
  329.     }
  330.     else cout<<"Sorry, invaliable password"<<endl;
  331. }
Calculator.rar (382.79 KB, 下載次數(shù): 13)
ID:572563 發(fā)表于 2019-6-26 13:51 | 顯示全部樓層
順便在說一句,如果有什么問題提出哦,還有,軟件的密碼這里我說一下吧:267398323513
本帖最后由 howardlu11 于 2019-6-26 14:04 編輯
