DSP2812產(chǎn)生三相SPWM波,有需要的拿走
- 本程序在220V 3400轉(zhuǎn) 5對(duì)級(jí)直流無(wú)刷電機(jī)調(diào)試下通過(guò)
- #include "DSP281x_Device.h" // DSP281x Headerfile Include File
- #include "DSP281x_Examples.h" // DSP281x Examples Include File
- #include "math.h"
- #define C_TIME 20
- #define pwm_half_per 3750 /*3750 pwm=20khz*//*sytemclk=150MHz*/
- /*1875 pwm=40kHz*/
- #define pole 2 /*電機(jī)的級(jí)對(duì)數(shù)*/
- #define timer2_per 60000//234375/* timer2 period with a 1/128 timer prescaler and 150MHz CPUCLK*/
- #define PI 3.1415926
- unsigned int adc_res;
- unsigned int dir=1;
- unsigned int ldd=0;
- unsigned int PWM_DUTY=2000;
- unsigned int I_result[2048];
- unsigned int i=0;
- unsigned int hall=0x000;
- unsigned int time_cnt=C_TIME;
- unsigned int hallspeed=0;
- unsigned int prehall=0;
- unsigned int speed;
- unsigned int a=0,b=0,c=0,d=0;
- unsigned int displaytime=0;
- unsigned int displayflag=0;
- unsigned int fc=10000;
- unsigned int f=50;
- float M=0.9;
- unsigned int k=0;
- // Prototype statements for functions found within this file.
- void init_eva(void);
- void eva_timer1_isr(void);
- //void init_evb(void);
- // Global counts used in this example
- void main(void)
- // Step 1. Initialize System Control:
- // PLL, WatchDog, enable Peripheral Clocks
- // This example function is found in the DSP281x_SysCtrl.c file.
- InitSysCtrl();
- // Step 2. Initalize GPIO:
- // This example function is found in the DSP281x_Gpio.c file and
- // illustrates how to set the GPIO to it's default state.
- // InitGpio(); // Skipped for this example
- // Initialize only GPAMUX and GPBMUX for this test
- EALLOW;
- // Enable PWM pins
- GpioMuxRegs.GPAMUX.all = 0x003F; // EVA PWM 1-6 pins
- GpioMuxRegs.GPAQUAL.all=0x0000;
- EDIS;
- // Step 3. Clear all interrupts and initialize PIE vector table:
- // Disable CPU interrupts
- DINT;
- // Initialize PIE control registers to their default state.
- // The default state is all PIE interrupts disabled and flags
- // are cleared.
- // This function is found in the DSP281x_PieCtrl.c file.
- InitPieCtrl();
- IER = 0x0000;
- IFR = 0x0000;
- // Interrupts that are used in this example are re-mapped to
- // ISR functions found within this file.
- EALLOW; // This is needed to write to EALLOW protected registers
- PieVectTable.T1PINT = &eva_timer1_isr;
- EDIS;
- // Disable CPU interrupts and clear all CPU interrupt flags:
- // Initialize the PIE vector table with pointers to the shell Interrupt
- // Service Routines (ISR).
- // This will populate the entire table, even if the interrupt
- // is not used in this example. This is useful for debug purposes.
- // The shell ISR routines are found in DSP281x_DefaultIsr.c.
- // This function is found in DSP281x_PieVect.c.
- InitPieVectTable();
- EvaRegs.T1CON.all=0x0000;//disable time1
- // Step 4. Initialize all the Device Peripherals:
- // This function is found in DSP281x_InitPeripherals.c
- // InitPeripherals(); // Not required for this example
- init_eva();
- // init_evb();
- // Step 5. User specific code, enable interrupts:
- // Enable PIE group 2 interrupt 4 for T1PINT
- PieCtrlRegs.PIEIER2.all = M_INT4;
- // Enable CPU INT2 for T1PINT, INT3 for T2PINT, INT4 for T3PINT
- // and INT5 for T4PINT:
- IER |= M_INT2;
- // Enable global Interrupts and higher priority real-time debug events:
- EINT; // Enable Global interrupt INTM
- ERTM; // Enable Global realtime interrupt DBGM
- EvaRegs.EVAIMRA.bit.T1PINT = 1;
- EvaRegs.EVAIFRA.bit.T1PINT = 1;
- // Just sit and loop forever:
- // PWM pins can be observed with a scope.
- for(;;)
- void init_eva()
- // EVA Configure T1PWM, T2PWM, PWM1-PWM6
- // Initalize the timers
- EvaRegs.GPTCONA.bit.TCMPOE = 1;//0
- EvaRegs.GPTCONA.bit.T1PIN = 2;//0
- // Initalize EVA Timer1
- //EvaRegs.T1PR=0.0001;
- EvaRegs.T1PR = pwm_half_per; // Timer1 period
- EvaRegs.T1CMPR=0;
- //EvaRegs.T1CMPR = PWM_DUTY; // Timer1 compare
- EvaRegs.T1CNT = 0x0000; // Timer1 counter
- EvaRegs.DBTCONA.all=0x0000; //deadband units off
- EvaRegs.ACTRA.all =0x0fff; //pwm pin set active high*/
- // Enable compare for PWM1-PWM6
- EvaRegs.CMPR1=0;
- //EvaRegs.CMPR1=PWM_DUTY;
- EvaRegs.CMPR2=PWM_DUTY;
- EvaRegs.CMPR3=PWM_DUTY;
- EvaRegs.COMCONA.all = 0xA600;
- EvaRegs.T1CON.all = 0x842;//0x840
- // Compare action control. Action that takes place
- // on a cmpare event
- // output pin 1 CMPR1 - active high
- // output pin 2 CMPR1 - active low
- // output pin 3 CMPR2 - active high
- // output pin 4 CMPR2 - active low
- // output pin 5 CMPR3 - active high
- // output pin 6 CMPR3 - active low
- EvaRegs.DBTCONA.all = 0x1000; // Disable deadband
- EvaRegs.EVAIFRA.all = BIT7;
- EvaRegs.ACTRA.all =0x0666;//0x0c02
- //EvaRegs.CMPR3=pwm_half_per-200;
- //EvaRegs.CMPR2=PWM_DUTY;
- EvaRegs.CMPR1=(pwm_half_per/2)*(1+0.9*sin(PI*k/100));
- EvaRegs.CMPR2=(pwm_half_per/2)*(1+0.9*sin(PI*k/100+2*PI/3));
- EvaRegs.CMPR3=(pwm_half_per/2)*(1+0.9*sin(PI*k/100+4*PI/3));
- k++;
- if(k==200)
- k=0;
- // EvaRegs.CMPR1=PWM_DUTY;
- // EvaRegs.CMPR2=PWM_DUTY;
- // EvaRegs.CMPR3=PWM_DUTY;
- PieCtrlRegs.PIEACK.all = PIEACK_GROUP2;
75448169dsp2812spwm.zip
(422.74 KB, 下載次數(shù): 63)
2019-6-27 15:53 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
