常見功能模塊例程
- #include "MMA7455.H"
- //sbit sda=P2^3; //I2C 數(shù)據(jù)傳送位
- //sbit scl=P2^4; //I2C 時(shí)鐘傳送位
- unsigned char sign_flag; //輸出數(shù)據(jù)正負(fù)標(biāo)記位
- void IIC_MMA7455_init()
- IIC_start();
- IIC_writebyte(MMA7455_ADDER_WRITE); //1. 在IIC總線上尋址MMA7455
- while(IIC_respons());
- IIC_writebyte(MMA7455_Mode_Control_Register); //2. 模式設(shè)置寄存器尋址
- IIC_writebyte(MMA7455_2G_Measurement_Mode); //3. 模式寄存器數(shù)據(jù)寫入
- IIC_stop();
- IIC_start();
- IIC_stop();
- void IIC_MMA7455_writedata(uchar byte_add,uchar wdata)//函數(shù)功能:按地址寫入一字節(jié)數(shù)據(jù)
- unsigned char temp;
- temp=(IIC_WRITE<<1);
- IIC_start();
- IIC_writebyte(temp);
- IIC_writebyte(byte_add);
- IIC_writebyte(wdata);
- IIC_stop();
- unsigned char IIC_MMA7455_readdata(uchar byte_add) //函數(shù)功能:按地址讀出一字節(jié)數(shù)據(jù)
- char x_y_z ;
- IIC_start();
- IIC_writebyte(0x3A);
- temp=((IIC_READ<<1)|0x01);
- IIC_start();
- IIC_writebyte(0x3B);
- x_y_z=IIC_readbyte();
- IIC_stop();
- return x_y_z;
- unsigned char IIC_MMA7455_test()
- for(temp=255;temp<=1;temp--);
- IIC_MMA7455_writedata(0x16,0x05);
- temp=IIC_MMA7455_readdata(0x16);
- if(temp==0x05) {return 1;}
- else{return 0;}
- unsigned char IIC_MMA7455_checkbusy()
- temp=IIC_MMA7455_readdata(MMA7455_READ_STATUS);
- if((temp&0x01)==1)
- return 1;
- else
- return 0;
- unsigned char IIC_MMA7455_getvalue(unsigned char address_byte)
- while(!IIC_MMA7455_checkbusy());
- temp=IIC_MMA7455_readdata(address_byte);
- if((temp&0x80)==0x00)
- sign_flag=0;
- return temp;
- else
- sign_flag=1;
- temp=temp-0x01;
- temp=~temp;
- return temp;
- unsigned char IIC_MMA7455_getaverage(unsigned char address_byte)
- unsigned char num,temp;
- unsigned int temps=0x00;
- for(num=50;num>0;num--)
- temp=IIC_MMA7455_getvalue(address_byte);
- temps=temps+temp;
- temp=temps/50;
- return temp;
- unsigned char IIC_MMA7455_getacceleration(unsigned char address_byte)
- unsigned int temp;
- temp=IIC_MMA7455_getaverage(address_byte);
- temp=temp*200;
- temp=temp>>7;
- return temp;
- unsigned char IIC_MMA7455_calibrate_X()
- unsigned char tempX,time;
- tempX=IIC_MMA7455_readdata(MMA7455_READ_X);
- for(time=100;time>0;time--)
- if((tempX&0x80)==0x00)
- tempX=tempX+tempX;
- tempX=~tempX+1;
- IIC_MMA7455_writedata(MMA7455_RW_XOFFL,tempX);
- else
- tempX=tempX-1;
- tempX=~tempX;
- if((tempX<=10)&&(tempX>=-10)){break;}
- return 1;
- unsigned char IIC_MMA7455_calibrate_Y()
- unsigned char tempY,time;
- tempY=IIC_MMA7455_readdata(MMA7455_READ_Y);
- if((tempY&0x80)==0x00)
- tempY=tempY+tempY;
- tempY=~tempY+1;
- IIC_MMA7455_writedata(MMA7455_RW_XOFFL,tempY);
- else
- tempY=tempY-1;
- tempY=~tempY;
- if((tempY<=10)&&(tempY>=-10)){break;}
- return 1;
- unsigned char IIC_MMA7455_calibrate_Z()
- unsigned char tempZ,time;
- tempZ=IIC_MMA7455_readdata(MMA7455_READ_Z);
- if((tempZ&0x80)==0x00)
- tempZ=64-tempZ;
- if(tempZ==0){break;}
- if(tempZ>0)
- tempZ=tempZ+tempZ;
- tempZ=~tempZ+1;
- IIC_MMA7455_writedata(MMA7455_RW_XOFFL,tempZ);
- if(tempZ<0)
- else
- tempZ=tempZ-1;
- tempZ=~tempZ;
- tempZ=64+tempZ;
- if((tempZ<=70)&&(tempZ>=50)){break;}
- return 1;
常見功能模塊例程.zip
(20.76 KB, 下載次數(shù): 10)
2019-7-3 20:58 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
