查看: 4078|回復(fù): 2
基于DS1621的多點(diǎn)測(cè)溫單片機(jī)程序及Proteus仿真
做的很細(xì),ds18B20的網(wǎng)上很多,DS1621的沒(méi)有,花了一點(diǎn)時(shí)間做出來(lái)了,現(xiàn)在整理到一塊,有緣者取
  1. #include "reg51.h"
  2. #include "intrins.h"
  3. #define  uchar unsigned char
  4. #define  uint  unsigned int
  5. #define  DiSdata P0           //七段碼數(shù)據(jù)輸出口
  6. #define  discan  P2           //掃描數(shù)據(jù)輸出口
  7. sbit     DIN=P0^7;           //小數(shù)點(diǎn)控制
  8. sbit     Scl=P3^0;            //串行時(shí)鐘
  9. sbit     Sda=P3^1;            //串行數(shù)據(jù)
  10. sbit     alarm=P1^7;
  11. sbit     alarm2=P1^6;
  12. uint     i;
  13. uint     h;
  14. uint     temp;
  15. uchar dath[2];                 //溫度輸入口
  16. uchar ff2,ff1=0,t3=0;
  17. uchar code
  18. dis_7[12]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xff}; //共陰LED段碼表 "0"  "1"  "2"  "3"  "4"  "5"  "6"  "7"  "8"  "9" "滅" "-"
  19. uchar code scan_con[5]={0xfd,0xfb,0xf7,0xef,0xdf};  //LED顯示控制,對(duì)應(yīng)0的LED有效
  20. uchar data display[5]={0x00,0x00,0x00,0x00,0x002};   //顯示單元數(shù)據(jù),共6個(gè)數(shù)據(jù)和一個(gè)運(yùn)算暫用
  21. uchar data display1[5]={0x01,0x02,0x03,0x04,0x052};
  22. uchar data DD[4]={0x90,0x92,0x94};
  23. //
  24. void
  25.   delay_us(uint t)            //延時(shí)函數(shù)
  26. {
  27. for (;t>0;t--);   }
  28.   //
  29. scan()                        //LED掃描函數(shù)
  30. {
  31. uchar k;
  32. for(k=0;k<5;k++)
  33. {
  34. discan=scan_con[k];        //控制位送P2口
  35. DiSdata=dis_7[display[k]];   //數(shù)據(jù)位送P0口
  36. if (k==3){DIN=1;}
  37. else
  38. DIN=0;                   //小數(shù)點(diǎn)顯示
  39. delay_us(150);
  40. }
  41. }
  42. //
  43. void delay(void)    //延時(shí)函數(shù)
  44. {
  45. _nop_();
  46. _nop_();
  47. _nop_();
  48. _nop_();
  49. _nop_();
  50. _nop_();
  51. }
  52. //
  53. void i_start(void)
  54. {
  55. Sda=1;
  56. Scl=1;
  57. delay();
  58. Sda=0;
  59. delay();
  60. Scl=0;
  61. }
  62. //
  63. void i_stop(void)
  64. {
  65. Sda=0;
  66. Scl=1;
  67. delay();
  68. Sda=1;
  69. delay();
  70. Scl=0;
  71. Sda=0;
  72. }
  73. //
  74. bit i_clock(void)     //應(yīng)答信號(hào)
  75. {    bit sample;
  76. Scl=1;
  77. delay();
  78. sample=Sda;
  79. _nop_();
  80. _nop_();
  81. Scl=0;
  82. delay();
  83. return(sample);
  84. }
  85. //
  86. void i_ack(void)
  87. {
  88. Sda=0;
  89. i_clock();
  90. Sda=1;    }
  91. //
  92. bit i_send(uchar i_data)
  93. {
  94.
  95. uchar i;    for(i=0;i<8;i++)
  96. {
  97. Sda=(bit)(i_data & 0x80);
  98. i_data=i_data<<1;
  99. i_clock();
  100. }
  101. Sda=1;
  102. return(~i_clock());    }
  103. //
  104. uchar i_receive(void)
  105. {
  106. uchar i_data=0;
  107. uchar i;
  108. for(i=0;i<8;i++)
  109. {
  110. i_data<<=1;
  111. Scl=0;delay();
  112. Scl=1;delay() ;
  113. i_data|=Sda;     }
  114. Scl=0; delay();
  115. return(i_data);    }
  116. //
  117. bit start_temperature_T(unsigned char d)  //開(kāi)始轉(zhuǎn)換命令
  118. {
  119. uchar t1;
  120. t1=DD[d];
  121. i_start();
  122. if(i_send(t1))
  123. {
  124. if(i_send(0xee))
  125. {
  126. i_stop();
  127. delay();
  128. return(1);
  129. }
  130. else
  131. {
  132. i_stop();
  133. delay();
  134. return(0);
  135. }
  136. }
  137. else
  138. {
  139. i_stop();
  140. delay();
  141. return(0);
  142. }
  143. }
  144. //
  145. bit read_temperature_T(unsigned char *p,unsigned char d)
  146. {
  147. unsigned char t1,t2;
  148. t1=DD[d];
  149. t2=DD[d]+0x01;
  150. i_start();
  151. if(i_send(t1))
  152. {
  153. if(i_send(0xaa))
  154. {
  155. i_start();
  156. if(i_send(t2))
  157. {
  158. *(p+1)=i_receive();
  159. i_ack();
  160. *p=i_receive();
  161. i_stop();
  162. delay();
  163. i_send(t1);
  164. i_send(0x22);
  165. delay();
  166. return(1);
  167. }
  168. else
  169. {
  170. i_stop();
  171. delay();
  172. return(0);
  173. }
  174. }
  175. else
  176. {
  177. i_stop();
  178. delay();
  179. return(0);
  180. }
  181. }
  182. else
  183. {
  184. i_stop();
  185. delay();
  186. return(0);
  187. }
  188. }
  189. bit ds1621(unsigned char d)
  190. {
  191. unsigned char t1;
  192. t1=DD[d];
  193.
  194. i_start();
  195. if(i_send(t1))
  196. {
  197. if(i_send(0xac))
  198. {
  199. i_start();
  200. if(i_send(0x0a))
  201. {
  202. i_stop();
  203. delay();
  204. return(1);
  205. }
  206. else
  207. {
  208. i_stop();
  209. delay();
  210. return(0);
  211. }
  212. }
  213. else
  214. {
  215. i_stop();
  216. delay();
  217. return(0);
  218. }
  219. }
  220. else
  221. {
  222. i_stop();
  223. delay();
  224. return(0);
  225. }
  226. }
  227. //
  228. void chuli_temp(unsigned char d)
  229. {
  230. unsigned char datah,f=1,datal,t;
  231. while(f)
  232. {
  233. t=start_temperature_T(d);
  234. if(t)
  235. {
  236. read_temperature_T(dath,d);
  237. f=0;
  238. }
  239. delay_us(20);
  240. }
  241. datah=dath[1];
  242. datal=dath[0];
  243. if(datal<20)
  244. alarm2=1;
  245. else
  246. alarm2=0;
  247. if(datah>80)
  248. alarm2=1;
  249. else
  250. alarm2=0;
  251. display[0]=d;
  252. f=0;
  253. if((datah&0x80)!=0)
  254. {f=1;
  255. display[1]=10;
  256. datah=datah+1;
  257. datah=~datah;
  258. datah=datah+1;
  259. display[2]=((datah/10)%10);
  260. display[3]=datah%10;
  261. if((datal&0x80)==0x80)
  262. display[4]=5;
  263. else
  264. display[4]=0;
  265. }
  266. else
  267.
  268. {
  269. display[1]=datah/100;
  270. display[2]=((datah/10)%10);
  271. display[3]=datah%10;
  272. if((datal&0x80)==0x80)
  273. display[4]=5;
  274. else
  275. display[4]=0;
  276. }
  277. if(!display[1])                //符號(hào)位顯示判斷
  278. {
  279. display[1]=0x0a;             //最高位為0時(shí)不顯示
  280. if(!display[2])
  281. {
  282. display[2]=0x0a;
  283. if(f) {display[2]=0x0b;f=2;}   //次高位為0時(shí)不顯示
  284. }
  285. }
  286. if(f==1)display[1]=0x0b;       //負(fù)溫度時(shí)最高位顯示"-"
  287. }
  288. void  ex_int0() interrupt 0
  289. {
  290. ff2=1;
  291. ff1=0;
  292. }
  293. //
  294. void  ex_int1() interrupt 2
  295. {
  296. EA=0;
  297. ff1=1;
  298. ff2=0;
  299. EA=1;
  300. }
  301. //
  302. main()             //主函數(shù)
  303. {
  304. uchar d=0,t4=1;
  305. DiSdata=0xff;     //初始化端口
  306. discan=0xff;
  307. alarm=0;
  308. EA=1;
  309. EX0=1;
  310. EX1=1;
  311. IT0=1;
  312. IT1=1;
  313. for(h=0;h<5;h++)   //開(kāi)機(jī)顯示"0000"
  314. {
  315. display[h]=0;
  316. }
  317. scan();
  318. delay_us(3);
  319. for(d=0;d<3;d++)
  320. {
  321. ds1621(d);}
  322. d=0;
  323. while(1)
  324. {
  325. if(ff1)
  326. {
  327. chuli_temp(d);
  328. for(h=0;h<100;h++)
  329. scan();
  330. d++;
  331. if(d==3)
  332. d=0;      }
  333. if(ff2)
  334. {
  335. t3=t3+ff2;
  336. if(t3==3)
  337. t3=0;
  338. chuli_temp(t3);
  339. ff2=0;
  340. }
  341. scan();
  342. }
  343. }
多點(diǎn)測(cè)溫.zip (935.42 KB, 下載次數(shù): 73)
收藏收藏3 分享淘帖 頂 踩
ID:575483 發(fā)表于 2019-12-30 11:32 | 只看該作者
18行共陰改成共陽(yáng)吧,要么會(huì)顯示不出來(lái)
ID:863391 發(fā)表于 2021-7-20 15:30 | 只看該作者
fanli 發(fā)表于 2019-12-30 11:32
那不是共陽(yáng)段碼表嗎
