查看: 5710|回復(fù): 3
stm32f103ze+WS2812b可調(diào)控RGB燈源程序,使用spI+dma進(jìn)行調(diào)光
ID:125878 發(fā)表于 2019-7-10 10:50 | 顯示全部樓層 |閱讀模式
基于stm32f103ze+WS2812b可調(diào)控RGB燈,使用spI+dma進(jìn)行調(diào)光,調(diào)光編碼可自己百度尋找修改本程序
  1. #include "ws2812.h"
  2. /*WS2812B Timing sequence
  3.             ________
  4.            |                |           T0L             |
  5. 0 code |<------>|<-------------->|
  6.            |  T0H   |________________|
  7.
  8.
  9.             ___________
  10.            |                   |           T1L          |
  11. 1 code |<--------->|<--------- -->|
  12.            |  T1H      |______________|
  13.
  14.
  15. RET code
  16.            |             Treset                            |
  17.            |<------------------------->|
  18.            |___________________________|
  19.
  20. Data transefer time:
  21. T0H                 0 code ,high voltage time                 0.4us ±150ns
  22. T1H                 1 code ,high voltage time                 0.8us ±150ns
  23. T0L                 0 code , low voltage time                 0.85us ±150ns
  24. T1L                 1 code ,low voltage time                 0.45us ±150ns
  25. RES                 low voltage time                                 Above 50us
  26.
  27. */
  28. int8_t WS2812_Init(void)
  29. {
  30.         return 0;
  31. }
  32. static int8_t WS2812_BitCode_Packet(uint8_t bit_val,uint8_t *spi_packet_buf)
  33. {
  34.         if(bit_val == 0){
  35.                 spi_packet_buf[0] = 0xFF;
  36.                 spi_packet_buf[1] = 0x00;
  37.                 spi_packet_buf[2] = 0x00;
  38.                 return 0;
  39.         }
  40.         else if(bit_val == 1){
  41.                 spi_packet_buf[0] = 0xFF;
  42.                 spi_packet_buf[1] = 0xFF;
  43.                 spi_packet_buf[2] = 0x00;
  44.                 return 0;
  45.         }
  46.         else
  47.                 return -1;
  48. }
  49. static int8_t WS2812_OnePixel_Packet(T_RGB_CTRL sRGBVal,uint8_t *packet_buf)
  50. {
  51.         uint8_t bit_cnt;
  52.         uint8_t color_cnt;
  53.         uint8_t bit_pos;
  54.         uint8_t singlecolor_val;
  55.
  56.         for(color_cnt = 0; color_cnt < 3; color_cnt++){
  57.                 if(color_cnt == 0)
  58.                         singlecolor_val = sRGBVal.G_Val;
  59.                 else if(color_cnt == 1)
  60.                         singlecolor_val = sRGBVal.R_Val;
  61.                 else if(color_cnt == 2)
  62.                         singlecolor_val = sRGBVal.B_Val;
  63.
  64.                 for(bit_cnt = 0; bit_cnt < 8; bit_cnt++){
  65.                         bit_pos = (7 - bit_cnt);
  66.                         if(singlecolor_val & (1 << bit_pos) )
  67.                                 WS2812_BitCode_Packet(1,packet_buf);
  68.                         else
  69.                                 WS2812_BitCode_Packet(0,packet_buf);
  70.                         packet_buf += SPI_BYTE_LEN_PER_PIXEL;
  71.                 }
  72.         }
  73.         return 0;
  74. }
  75. uint32_t WS2812_Pixels_Packet(uint32_t pixel_num,uint32_t *rgb_buf,uint8_t* spi_packet_buf)
  76. {
  77.         uint32_t pixel_index;
  78.         T_RGB_CTRL rgb_ctrl_val;
  79.         uint32_t spi_packet_buf_index = 0;
  80.
  81.         for(pixel_index = 0; pixel_index < pixel_num; pixel_index++){
  82.                 rgb_ctrl_val.R_Val = (uint8_t)(rgb_buf[pixel_index] >> 16);
  83.                 rgb_ctrl_val.G_Val = (uint8_t)(rgb_buf[pixel_index] >> 8);
  84.                 rgb_ctrl_val.B_Val = (uint8_t)(rgb_buf[pixel_index] >> 0);
  85.                 WS2812_OnePixel_Packet(rgb_ctrl_val,spi_packet_buf + spi_packet_buf_index);
  86.                 spi_packet_buf_index += SPI_BYTE_LEN_PER_PIXEL * 24;
  87.         }
  88.         return spi_packet_buf_index;
  89. }
WS2812_test.7z (189.53 KB, 下載次數(shù): 264)
ID:447445 發(fā)表于 2019-10-31 16:59 | 顯示全部樓層
感謝提供。
ID:384489 發(fā)表于 2020-11-20 16:53 | 顯示全部樓層
這代碼變量風(fēng)格看起來(lái)聽(tīng)舒服的,感謝分享。
ID:349598 發(fā)表于 2024-1-12 21:47 | 顯示全部樓層
不錯(cuò)!謝謝樓主分享。
