我給你來個STC8單片機模擬 的I2C程序試試
- void I2C_Delay(void) //for 1T STC delay
- uint16 j,i;
- for(j=0;j<2;j++)
- for(i=0;i<7;i++);
- void I2C_Start(void) //start the I2C, SDA High-to-low when SCL is high
- SDA = 1;
- I2C_Delay();
- SCL = 1;
- I2C_Delay();
- SDA = 0;
- I2C_Delay();
- SCL = 0;
- I2C_Delay();
- void I2C_Stop(void) //STOP the I2C, SDA Low-to-high when SCL is high
- SDA = 0;
- I2C_Delay();
- SCL = 1;
- I2C_Delay();
- SDA = 1;
- I2C_Delay();
- void S_ACK(void) //Send ACK (LOW)
- SDA = 0;
- I2C_Delay();
- SCL = 1;
- I2C_Delay();
- SCL = 0;
- I2C_Delay();
- void S_NoACK(void) //Send No ACK (High)
- SDA = 1;
- I2C_Delay();
- SCL = 1;
- I2C_Delay();
- SCL = 0;
- I2C_Delay();
- void I2C_Check_ACK(void) //Check ACK, If F0=0, then right, if F0=1, then error
- SDA = 1;
- I2C_Delay();
- SCL = 1;
- I2C_Delay();
- F0 = SDA;
- SCL = 0;
- I2C_Delay();
- void I2C_WriteAbyte(uint8 dat) //write a byte to I2C
- uint8 i;
- i = 8;
- do
- if(dat & 0x80) SDA = 1;
- else SDA = 0;
- dat <<= 1;
- I2C_Delay();
- SCL = 1;
- I2C_Delay();
- SCL = 0;
- I2C_Delay();
- while(--i);
- 功能描述:向指定地址寫數(shù)據(jù)
- 入口參數(shù):uint8 addr, uint8 *p, uint8 number
- 返回值:無
- uint8 I2C_ReadAbyte(void) //read A byte from I2C
- uint8 i,dat;
- i = 8;
- SDA = 1;
- do
- SCL = 1;
- I2C_Delay();
- dat <<= 1;
- if(SDA) dat++;
- SCL = 0;
- I2C_Delay();
- while(--i);
- return(dat);
- 返回值:無
- void WriteNbyte(uint8 addr, uint8 *p, uint8 number) /* WordAddress,First Data Address,Byte lenth */
- //F0=0,right, F0=1,error
- I2C_Start();
- I2C_WriteAbyte(SLAW);
- I2C_Check_ACK();
- if(!F0)
- I2C_WriteAbyte(addr);
- I2C_Check_ACK();
- if(!F0)
- do
- I2C_WriteAbyte(*p); p++;
- I2C_Check_ACK();
- if(F0) break;
- while(--number);
- I2C_Stop();
- 功能描述:向指定地址讀取數(shù)據(jù)
- 返回值:無
- void ReadNbyte(uint8 addr, uint8 *p, uint8 number) /* WordAddress,First Data Address,Byte lenth */
- I2C_Start();
- I2C_Check_ACK();
- if(!F0)
- I2C_Check_ACK();
- if(!F0)
- I2C_Start();
- I2C_WriteAbyte(SLAR);
- I2C_Check_ACK();
- if(!F0)
- do
- *p = I2C_ReadAbyte(); p++;
- if(number != 1) S_ACK(); //send ACK
- while(--number);
- S_NoACK(); //send no ACK
- I2C_Stop();
- /*********************************END FILE********************************************/
復制代碼 |
