- #include "bsp_pwm_output.h"
- * @brief 配置TIM3復(fù)用輸出PWM時(shí)用到的I/O
- * @param 無
- * @retval 無
- static void TIMx_GPIO_Config(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB| RCC_APB2Periph_AFIO,ENABLE);
- GPIO_PinRemapConfig(GPIO_Remap_SWJ_NoJTRST, ENABLE); //PB4
- GPIO_PinRemapConfig(GPIO_PartialRemap_TIM3, ENABLE);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
- GPIO_Init(GPIOB, &GPIO_InitStructure);
- // /*GPIOB Configuration: TIM3 channel 2 as alternate function push-pull */
- // GPIO_InitStructure.GPIO_Pin = macTIM_CH2_PIN;
- // GPIO_Init(macTIM_CH2_PORT, &GPIO_InitStructure);
- * @brief 配置TIM3輸出的PWM信號的模式,如周期、極性、占空比
- * @param 無
- * @retval 無
- * TIMxCLK/CK_PSC --> TIMxCNT --> TIMx_ARR --> TIMxCNT 重新計(jì)數(shù)
- * TIMx_CCR(電平發(fā)生變化)
- * 信號周期=(TIMx_ARR +1 ) * 時(shí)鐘周期
- * 占空比=TIMx_CCR/(TIMx_ARR +1)
- static void TIMx_Mode_Config(void)
- TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
- TIM_OCInitTypeDef TIM_OCInitStructure;
- /* PWM信號電平跳變值 */
- u16 CCR1_Val = 500;
- u16 CCR2_Val = 0;
- // u16 CCR3_Val = 250;
- // u16 CCR4_Val = 125;
- macTIMx Channel1 duty cycle = (macTIMx_CCR1/ macTIMx_ARR+1)* 100% = 50%
- macTIMx Channel2 duty cycle = (macTIMx_CCR2/ macTIMx_ARR+1)* 100% = 37.5%
- macTIMx Channel3 duty cycle = (macTIMx_CCR3/ macTIMx_ARR+1)* 100% = 25%
- macTIMx Channel4 duty cycle = (macTIMx_CCR4/ macTIMx_ARR+1)* 100% = 12.5%
- /* Time base configuration */
- TIM_TimeBaseStructure.TIM_Period = 999; //當(dāng)定時(shí)器從0計(jì)數(shù)到999,即為1000次,為一個(gè)定時(shí)周期
- TIM_TimeBaseStructure.TIM_Prescaler = 0; //設(shè)置預(yù)分頻:不預(yù)分頻,即為72MHz
- TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1 ; //設(shè)置時(shí)鐘分頻系數(shù):不分頻(這里用不到)
- TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //向上計(jì)數(shù)模式
- TIM_TimeBaseInit(macTIMx, &TIM_TimeBaseStructure);
- /* PWM1 Mode configuration: Channel1 */
- TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1; //配置為PWM模式1
- TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
- TIM_OCInitStructure.TIM_Pulse = CCR1_Val; //設(shè)置跳變值,當(dāng)計(jì)數(shù)器計(jì)數(shù)到這個(gè)值時(shí),電平發(fā)生跳變
- TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; //當(dāng)定時(shí)器計(jì)數(shù)值小于CCR1_Val時(shí)為高電平
- TIM_OC1Init(macTIMx, &TIM_OCInitStructure); //使能通道1
- TIM_OC1PreloadConfig(macTIMx, TIM_OCPreload_Enable);
- // /* PWM1 Mode configuration: Channel2 */
- TIM_OCInitStructure.TIM_Pulse = CCR2_Val; //設(shè)置通道2的電平跳變值,輸出另外一個(gè)占空比的PWM
- TIM_OC2Init(macTIMx, &TIM_OCInitStructure); //使能通道2
- TIM_OC2PreloadConfig(macTIMx, TIM_OCPreload_Enable);
- TIM_ARRPreloadConfig(macTIMx, ENABLE); // 使能TIM3重載寄存器ARR
- /* TIM3 enable counter */
- TIM_Cmd(macTIMx, ENABLE); //使能定時(shí)器3
- * @brief TIM3 輸出PWM信號初始化,只要調(diào)用這個(gè)函數(shù)
- * TIM3的四個(gè)通道就會(huì)有PWM信號輸出
- * @param 無
- * @retval 無
- void TIMx_PWM_Init(void)
- TIMx_GPIO_Config();
- TIMx_Mode_Config();
- /*********************************************END OF FILE**********************/
復(fù)制代碼 |
PwmOutput.zip
2019-7-19 14:29 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
2.27 KB, 下載次數(shù): 3, 下載積分: 黑幣 -5
