查看: 1994|回復(fù): 0
測試產(chǎn)品開關(guān)機100000次自動停止 帶斷電記憶功能
ID:583100 發(fā)表于 2019-7-22 15:05 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
/*開關(guān)機測試程序 單片機AT89S52,晶振11.0592M         制作者:王興    2019.7.22*/
#include<reg52.h>
#include <intrins.h>
sbit sr1=P2^7;
sbit scl1=P2^6;
sbit sj=P2^5;
sbit  kz=P2^2;//控制輸出
sbit wm1=P0^0;
sbit wm2=P0^1;
sbit wm3=P0^2;
sbit wm4=P0^3;
sbit wm5=P0^4;
sbit wm6=P0^5;
sbit k1=P2^0;
sbit k2=P2^1;
sbit scl=P1^1; //時鐘線
sbit sda=P1^0; //數(shù)據(jù)線
sbit led1=P2^3;
sbit led2=P2^4;
uchar temp;
uchar cs1=95;//次數(shù)
uchar cs2=99;
uchar cs3=9;
bit tz;
bit bz;
bit write=0;
uchar code duan[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x7f,0xff};//0 1 2 3 4 5 6 7 8 9 . 滅
void delay1(uchar cc)
uchar j;
for(;cc<40;cc++)
for(j=0;j<20;j++);
void xsj(uchar dat)
  uchar i;
  for(i=0;i<8;i++)
    sj=dat&0x80;
