SX1262 在stm32單片機(jī)上的完整例子,SX1262TR4-GC資料包,包括:芯片數(shù)據(jù)手冊(cè),模塊規(guī)格書(shū),接線示意圖,PCB封裝,Demo程序(完整代碼,keil5驗(yàn)證通過(guò))
完整的資料,非常難得。
電路原理圖如下:
PCB封裝:
STM32單片機(jī)源程序如下:
- #include <string.h>
- #include "user.h"
- #include "sx126x-board.h"
- Demo 程序流程 EnableMaster=true 為主機(jī)端,主機(jī)端發(fā)送一個(gè)"PING"數(shù)據(jù)后切換到接收,等待從機(jī)返回的應(yīng)答"PONG"數(shù)據(jù)LED閃爍
- EnableMaster=false 為從機(jī)端,從機(jī)端接收到主機(jī)端發(fā)過(guò)來(lái)的"PING"數(shù)據(jù)后LED閃爍并發(fā)送一個(gè)"PONG"數(shù)據(jù)作為應(yīng)答
- #define USE_MODEM_LORA
- #define REGION_CN779
- #if defined( REGION_AS923 )
- #define RF_FREQUENCY 923000000 // Hz
- #elif defined( REGION_AU915 )
- #define RF_FREQUENCY 915000000 // Hz
- #elif defined( REGION_CN779 )
- #define RF_FREQUENCY 434000000 // Hz
- #elif defined( REGION_EU868 )
- #define RF_FREQUENCY 868000000 // Hz
- #elif defined( REGION_KR920 )
- #define RF_FREQUENCY 920000000 // Hz
- #elif defined( REGION_IN865 )
- #define RF_FREQUENCY 865000000 // Hz
- #elif defined( REGION_US915 )
- #elif defined( REGION_US915_HYBRID )
- #else
- #error "Please define a frequency band in the compiler options."
- #endif
- #define TX_OUTPUT_POWER 22 // 22 dBm
- extern bool IrqFired;
- bool EnableMaster=false;//主從選擇
- uint16_t crc_value;
- * Radio events function pointer
- static RadioEvents_t RadioEvents;
- #if defined( USE_MODEM_LORA )
- #define LORA_BANDWIDTH 1 // [0: 125 kHz,
- // 1: 250 kHz,
- // 2: 500 kHz,
- // 3: Reserved]
- #define LORA_SPREADING_FACTOR 11 // [SF7..SF12]
- #define LORA_CODINGRATE 2 // [1: 4/5,
- // 2: 4/6,
- // 3: 4/7,
- // 4: 4/8]
- #define LORA_PREAMBLE_LENGTH 8 // Same for Tx and Rx
- #define LORA_SYMBOL_TIMEOUT 0 // Symbols
- #define LORA_FIX_LENGTH_PAYLOAD_ON false
- #define LORA_IQ_INVERSION_ON false
- #elif defined( USE_MODEM_FSK )
- #define FSK_FDEV 5e3 // Hz
- #define FSK_DATARATE 2.4e3 // bps
- #define FSK_BANDWIDTH 20e3 // Hz >> DSB in sx126x
- #define FSK_AFC_BANDWIDTH 100e3 // Hz
- #define FSK_PREAMBLE_LENGTH 5 // Same for Tx and Rx
- #define FSK_FIX_LENGTH_PAYLOAD_ON false
- #else
- #error "Please define a modem in the compiler options."
- #endif
- typedef enum
- LOWPOWER,
- RX,
- RX_TIMEOUT,
- RX_ERROR,
- TX,
- TX_TIMEOUT,
- }States_t;
- #define RX_TIMEOUT_VALUE 1000
- #define BUFFER_SIZE 64 // Define the payload size here
- const uint8_t PingMsg[] = "PING";
- const uint8_t PongMsg[] = "PONG";
- uint16_t BufferSize = BUFFER_SIZE;
- uint8_t TX_Buffer[BUFFER_SIZE];
- uint8_t RX_Buffer[BUFFER_SIZE];
- States_t State = LOWPOWER;
- int8_t RssiValue = 0;
- int8_t SnrValue = 0;
- void OnTxDone( void );
- void OnRxDone( uint8_t *payload, uint16_t size, int16_t rssi, int8_t snr );
- void OnTxTimeout( void );
- void OnRxTimeout( void );
- void OnRxError( void );
- void SysClock_48()
- RCC_PLLCmd(DISABLE);
- RCC_PLLConfig(RCC_PLLSource_HSI_Div2, RCC_PLLMul_12);//48M
- RCC_PLLCmd(ENABLE);
- while(!RCC_GetFlagStatus(RCC_FLAG_PLLRDY));
- RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
- void Tick_Configration()
- /* Setup SysTick Timer for 1ms interrupts ( not too often to save power ) */
- if( SysTick_Config( SystemCoreClock / 1000 ) )
- /* Capture error */
- while (1);
- void RCC_Configuration()
- /* Enable GPIO clock */
- RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA|RCC_AHBPeriph_GPIOB|RCC_AHBPeriph_GPIOC|RCC_AHBPeriph_GPIOF, ENABLE);
- /* Enable peripheral Clock */
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2|RCC_APB1Periph_PWR, ENABLE);
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1|RCC_APB2Periph_SYSCFG, ENABLE);
- void HW_int(void)
- SysClock_48();
- Tick_Configration();
- RCC_Configuration();
- GPIO_int();
- SPI2_Int();
- void LedToggle(void)
- GPIO_WriteBit( LED1_PORT, LED1_PIN,Bit_RESET);//LED閃爍
- HAL_Delay_nMS(10);
- GPIO_WriteBit( LED1_PORT, LED1_PIN,Bit_SET);
- int main( void )
- // uint8_t data[2]={0x12,0x34};
- // static uint8_t test[2];
- HW_int();//MCU外圍資源初始化
- // Radio initialization
- RadioEvents.TxDone = OnTxDone;
- RadioEvents.RxDone = OnRxDone;
- RadioEvents.TxTimeout = OnTxTimeout;
- RadioEvents.RxTimeout = OnRxTimeout;
- RadioEvents.RxError = OnRxError;
- Radio.Init( &RadioEvents );
- Radio.SetChannel( RF_FREQUENCY );
- // Radio.WriteBuffer(0x06C0,data,2);
- // Radio.ReadBuffer(0x06C0,test,2);
- Radio.SetTxConfig( MODEM_LORA, TX_OUTPUT_POWER, 0, LORA_BANDWIDTH,
- LORA_SPREADING_FACTOR, LORA_CODINGRATE,
- LORA_PREAMBLE_LENGTH, LORA_FIX_LENGTH_PAYLOAD_ON,
- true, 0, 0, LORA_IQ_INVERSION_ON, 3000 );
- Radio.SetRxConfig( MODEM_LORA, LORA_BANDWIDTH, LORA_SPREADING_FACTOR,
- LORA_CODINGRATE, 0, LORA_PREAMBLE_LENGTH,
- LORA_SYMBOL_TIMEOUT, LORA_FIX_LENGTH_PAYLOAD_ON,
- 0, true, 0, 0, LORA_IQ_INVERSION_ON, false );
- Radio.SetTxConfig( MODEM_FSK, TX_OUTPUT_POWER, FSK_FDEV, 0,
- FSK_DATARATE, 0,
- FSK_PREAMBLE_LENGTH, FSK_FIX_LENGTH_PAYLOAD_ON,
- true, 0, 0, 0, 3000 );
- Radio.SetRxConfig( MODEM_FSK, FSK_BANDWIDTH, FSK_DATARATE,
- 0, FSK_AFC_BANDWIDTH, FSK_PREAMBLE_LENGTH,
- 0, FSK_FIX_LENGTH_PAYLOAD_ON, 0, true,
- 0, 0,false, true );
- #else
- #endif
- if(EnableMaster)
- TX_Buffer[0] = 'P';
- TX_Buffer[1] = 'I';
- TX_Buffer[2] = 'N';
- TX_Buffer[3] = 'G';
- crc_value=RadioComputeCRC(TX_Buffer,4,CRC_TYPE_IBM);//計(jì)算得出要發(fā)送數(shù)據(jù)包CRC值
- TX_Buffer[4]=crc_value>>8;
- TX_Buffer[5]=crc_value;
- Radio.Send( TX_Buffer, 6);
- else
- Radio.Rx( RX_TIMEOUT_VALUE );
- while( 1 )
- Radio.IrqProcess( ); // Process Radio IRQ
- Radio.Standby();
- Radio.Rx( RX_TIMEOUT_VALUE ); //進(jìn)入接收
- BufferSize = size;
- memcpy( RX_Buffer, payload, BufferSize );
- RssiValue = rssi;
- SnrValue = snr;
- Radio.Standby();
- if(EnableMaster)
- if(memcmp(RX_Buffer,PongMsg,4)==0)
- LedToggle();//LED閃爍
- else
- if(memcmp(RX_Buffer,PingMsg,4)==0)
- TX_Buffer[1] = 'O';
- else
- Radio.Standby();
- if(EnableMaster)
- else
SX1262TR4-GC資料包.7z
(5.78 MB, 下載次數(shù): 288)
2019-7-24 03:45 上傳
點(diǎn)擊文件名下載附件
