SPI初始化講解
第一部分:初始化
1.GPIO和SPI時(shí)鐘使能:
RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOB, ENABLE );//PORTB時(shí)鐘使能
RCC_APB1PeriphClockCmd( RCC_APB1Periph_SPI2, ENABLE );//SPI2時(shí)鐘使能
2.GPIO初始化:
/* Configure SPI2 pins: SCK, MISOand *//
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13 |GPIO_Pin_15;
GPIO_InitStructure.GPIO_Speed =GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode =GPIO_Mode_AF_PP;
GPIO_Init(GPIOB, &GPIO_InitStructure);
//SPI2 NSS
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
GPIO_InitStructure.GPIO_Mode =GPIO_Mode_Out_PP;GPIO_Init(GPIOB, &GPIO_InitStructure);
GPIO_SetBits(GPIOB, GPIO_Pin_12);
/*!< Configure SPI_FLASH_SPIpins: MOSI */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_14; //
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU; //上拉輸入
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
GPIO_Init(GPIOA, &GPIO_InitStructure);
3.SPI初始化:
SPI_InitStructure.SPI_Direction= SPI_Direction_2Lines_FullDuplex;
//設(shè)置SPI單向或者雙向的數(shù)據(jù)模式:SPI設(shè)置為雙線雙向全雙工
SPI_InitStructure.SPI_Mode =SPI_Mode_Master;
//設(shè)置SPI工作模式:設(shè)置為主SPI
SPI_InitStructure.SPI_DataSize =SPI_DataSize_8b;
//設(shè)置SPI的數(shù)據(jù)大小:SPI發(fā)送接收8位幀結(jié)構(gòu)
SPI_InitStructure.SPI_CPOL =SPI_CPOL_High;
//串行同步時(shí)鐘的空閑狀態(tài)為高電平
SPI_InitStructure.SPI_CPHA =SPI_CPHA_2Edge;
//串行同步時(shí)鐘的第二個(gè)跳變沿(上升或下降)數(shù)據(jù)被采樣
SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
//NSS信號(hào)由硬件(NSS管腳)還是軟件(使用SSI位)管理:內(nèi)部NSS信號(hào)有SSI位控制
SPI_InitStructure.SPI_BaudRatePrescaler =SPI_BaudRatePrescaler_256;
//定義波特率預(yù)分頻的值:波特率預(yù)分頻值為256
SPI_InitStructure.SPI_FirstBit =SPI_FirstBit_MSB;
//指定數(shù)據(jù)傳輸從MSB位還是LSB位開始:數(shù)據(jù)傳輸從MSB位開始
SPI_InitStructure.SPI_CRCPolynomial = 7;
//CRC值計(jì)算的多項(xiàng)式
SPI_Init(SPI2,&SPI_InitStructure);
//根據(jù)SPI_InitStruct中指定的參數(shù)初始化外設(shè)SPIx寄存器
4.使能外設(shè):
SPI_Cmd(SPI2,ENABLE); //使能SPI外設(shè)
第二部分:SPI讀寫數(shù)據(jù)
u8 SPI2_ReadWriteByte(u8 TxData)
u8 retry=0;
while (SPI_I2S_GetFlagStatus(SPI2,SPI_I2S_FLAG_TXE) == RESET) //檢查指定的SPI標(biāo)志位設(shè)置與否:發(fā)送緩存空標(biāo)志位
retry++;
if(retry>200)return 0;
SPI_I2S_SendData(SPI2, TxData); //通過外設(shè)SPIx發(fā)送一個(gè)數(shù)據(jù)
retry=0;
while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_RXNE) == RESET) //檢查指定的SPI標(biāo)志位設(shè)置與否:接受緩存非空標(biāo)志位
retry++;
return SPI_I2S_ReceiveData(SPI2); //返回通過SPIx最近接收的數(shù)據(jù)
注意:NSS配置方法:1.可以使用SPI引腳配置,但要注意模式設(shè)置
2.隨便找個(gè)IO口配置也行。
但是配置后NSS代表CS,要先初始拉高,后再手動(dòng)拉低。NSS使用軟件模式,不要硬件
MISO:主設(shè)備輸入/從設(shè)備輸出引腳。該引腳在從模式下發(fā)送數(shù)據(jù),在主模式下接收數(shù)據(jù);
MOSI:主設(shè)備輸出/從設(shè)備輸入引腳。該引腳在主模式下發(fā)送數(shù)據(jù),在從模式下接收數(shù)據(jù);
所以MISO使用上拉輸入
