查看: 1793|回復(fù): 1
STM32 4X4矩形鍵盤代碼
ID:334435 發(fā)表于 2019-7-25 09:58 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
有空做了一個4X4的矩陣鍵盤
單片機源程序如下:
  1. #include "key.h"
  2. #include "Systick.h"
  3. uint8_t Key_Number=0,column=0;
  4. //行做輸出低電平,列讀取電平
  5. void KEY_L_Init(void)
  6. {
  7.    GPIO_InitTypeDef GPIO_InitStructure;
  8.
  9.    RCC_APBxPeriphClockCmd (RCC_APB2Periph_GPIOx,ENABLE);
  10.         //列
  11.          GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IN_FLOATING;   //浮空輸入
  12.    GPIO_InitStructure.GPIO_Pin=KEY_L0_GPIO_PIN;
  13.    GPIO_Init(KEY_L0_PORN,&GPIO_InitStructure);
  14.          GPIO_InitStructure.GPIO_Pin=KEY_L1_GPIO_PIN;
  15.    GPIO_Init(KEY_L1_PORN,&GPIO_InitStructure);
  16.          GPIO_InitStructure.GPIO_Pin=KEY_L2_GPIO_PIN;
  17.    GPIO_Init(KEY_L2_PORN,&GPIO_InitStructure);
  18.          GPIO_InitStructure.GPIO_Pin=KEY_L3_GPIO_PIN;
  19.    GPIO_Init(KEY_L3_PORN,&GPIO_InitStructure);
  20.
  21.
  22.         //行
  23.          GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP;        //推挽輸出
  24.          GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
  25.          GPIO_InitStructure.GPIO_Pin=KEY_R0_PIN;
  26.    GPIO_Init(KEY_R0_PORN,&GPIO_InitStructure);
  27.          GPIO_InitStructure.GPIO_Pin=KEY_R1_PIN;
  28.    GPIO_Init(KEY_R1_PORN,&GPIO_InitStructure);
  29.          GPIO_InitStructure.GPIO_Pin=KEY_R2_PIN;
  30.    GPIO_Init(KEY_R2_PORN,&GPIO_InitStructure);
  31.          GPIO_InitStructure.GPIO_Pin=KEY_R3_PIN;
  32.    GPIO_Init(KEY_R3_PORN,&GPIO_InitStructure);
  33.
  34. }
  35. //列做輸出高電平,行讀取電平
  36. void KEY_R_Init(void)
  37. {
  38.    GPIO_InitTypeDef GPIO_InitStructure;
  39.          RCC_APBxPeriphClockCmd (RCC_APB2Periph_GPIOx,ENABLE);
  40.         //列
  41.          GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP;        //推挽輸出
  42.          GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
  43.    GPIO_InitStructure.GPIO_Pin=KEY_L0_GPIO_PIN;
  44.    GPIO_Init(KEY_L0_PORN,&GPIO_InitStructure);
  45.          GPIO_InitStructure.GPIO_Pin=KEY_L1_GPIO_PIN;
  46.    GPIO_Init(KEY_L1_PORN,&GPIO_InitStructure);
  47.          GPIO_InitStructure.GPIO_Pin=KEY_L2_GPIO_PIN;
  48.    GPIO_Init(KEY_L2_PORN,&GPIO_InitStructure);
  49.          GPIO_InitStructure.GPIO_Pin=KEY_L3_GPIO_PIN;
  50.    GPIO_Init(KEY_L3_PORN,&GPIO_InitStructure);
  51.
  52.         //行
  53.          GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IN_FLOATING;   //浮空輸入
  54.          GPIO_InitStructure.GPIO_Pin=KEY_R0_PIN;
  55.    GPIO_Init(KEY_R0_PORN,&GPIO_InitStructure);
  56.          GPIO_InitStructure.GPIO_Pin=KEY_R1_PIN;
  57.    GPIO_Init(KEY_R1_PORN,&GPIO_InitStructure);
  58.          GPIO_InitStructure.GPIO_Pin=KEY_R2_PIN;
  59.    GPIO_Init(KEY_R2_PORN,&GPIO_InitStructure);
  60.          GPIO_InitStructure.GPIO_Pin=KEY_R3_PIN;
  61.    GPIO_Init(KEY_R3_PORN,&GPIO_InitStructure);
  62. }
  63. void Keyboard_Scanning (void)
  64. {
  65.   KEY_L_Init();    //行做輸出低電平,列讀取電平
  66.         L_KEY_R0;        //各行輸出低電平
  67.         L_KEY_R1;
  68.         L_KEY_R2;
  69.         L_KEY_R3;
  70.
  71.         if(KEY_L0==0)column=1;        //如果第一列讀到低電平
  72.         if(KEY_L1==0)column=2;        //如果第二列讀到低電平
  73.         if(KEY_L2==0)column=3;        //如果第三列讀到低電平
  74.         if(KEY_L3==0)column=4;        //如果第四列讀到低電平
  75.
  76. if(column==1)                  //如果第一列讀到低電平
  77.   {
  78.     KEY_R_Init();                //列做輸出高電平,行讀取電平
  79.           H_KEY_L0;                    //第一列輸出高電平
  80.                 SysTick_Delay_us(5);
  81.     if(KEY_R0==1)Key_Number=1;   //第一行
  82.           if(KEY_R1==1)Key_Number=2;   //第二行
  83.     if(KEY_R2==1)Key_Number=3;   //第三行
  84.     if(KEY_R3==1)Key_Number=4;   //第四行
  85.   }
  86. if(column==2)                  //如果第二列讀到低電平
  87. {
  88.    KEY_R_Init();
  89.          H_KEY_L1;                    //第二列輸出高電平
  90.          SysTick_Delay_us(5);
  91.    if(KEY_R0==1)Key_Number=5;
  92.          if(KEY_R1==1)Key_Number=6;
  93.    if(KEY_R2==1)Key_Number=7;
  94.    if(KEY_R3==1)Key_Number=8;
  95. }
  96. if(column==3)                   //如果第三列讀到低電平
  97. {
  98.    KEY_R_Init();
  99.          H_KEY_L2;                    //第三列輸出高電平
  100.          SysTick_Delay_us(5);
  101.    if(KEY_R0==1)Key_Number=9;
  102.          if(KEY_R1==1)Key_Number=10;
  103.    if(KEY_R2==1)Key_Number=11;
  104.    if(KEY_R3==1)Key_Number=12;
  105. }
  106. if(column==4)                  //如果第四列讀到低電平
  107.   {
  108.    KEY_R_Init();
  109.          H_KEY_L3;                     //第四列輸出高電平
  110.          SysTick_Delay_us(5);
  111.    if(KEY_R0==1)Key_Number=13;
  112.          if(KEY_R1==1)Key_Number=14;
  113.    if(KEY_R2==1)Key_Number=15;
  114.    if(KEY_R3==1)Key_Number=16;
  115. }
  116.          column=0;                     //列標(biāo)記清零
  117. }
4x4矩形鍵盤.7z (182.31 KB, 下載次數(shù): 22)
ID:1 發(fā)表于 2019-7-25 16:35 | 只看該作者
本帖需要重新編輯補全電路原理圖,源碼,詳細(xì)說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
