不知道protues的原理圖和程序是否配套
2019-7-25 21:48 上傳
- #include"reg51.h"
- #include <intrins.h>
- #include<stdio.h>
- typedef unsigned int u16; //對(duì)數(shù)據(jù)類型進(jìn)行聲明定義
- typedef unsigned char u8;
- #define uint unsigned int
- #define uchar unsigned char
- uchar code LEDData[]=
- {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
- sbit LSA=P2^2;
- sbit LSB=P2^3;
- sbit LSC=P2^4;
- sbit OE = P1^0;
- sbit EOC = P1^1;
- sbit ST = P1^2;
- sbit CLK = P1^3;
- sbit ADDA = P1^4;
- sbit ADDB = P1^5;
- sbit ADDC = P1^6;
- sbit LED=P1^7;
- u8 weixuan[4];
- uint temp;
- uchar getdata;
- uchar b;
- uchar s;
- uchar g;
- void delayus(uchar us)
- uchar i;
- while(us--)
- for(i=0;i<120;i++);
- void init()
- TMOD=0x21;
- TH0=(65536-200)/256;
- TL0=(65536-200)%256;
- TH1=0XF3;
- TL1=0XF3;
- PCON=0X80;
- SCON=0X50;
- ES=1;
- ET0=1;
- EA=1;
- TR1=1;
- TR0=1;
- void TImer0()interrupt 1
- { TH0=(65535-200)/256;
- TL0=(65535-200)%256;
- CLK=~CLK;
- void DigDisplay()
- u8 i;
- for(i=0;i<4;i++)
- switch(i) //位選,選擇點(diǎn)亮的數(shù)碼管,
- case(0):
- LSA=0;LSB=0;LSC=0; break;//顯示第0位
- case(1):
- LSA=1;LSB=0;LSC=0; break;//顯示第1位
- case(2):
- LSA=0;LSB=1;LSC=0; break;//顯示第2位
- case(3):
- LSA=1;LSB=1;LSC=0; break;//顯示第3位
- P0=weixuan[i];//發(fā)送段碼
- delayus(10); //間隔一段時(shí)間掃描
- P0=0x00;//消隱
- void Display_Result()
- weixuan[1] = LEDData[b];
- weixuan[2] = LEDData[s];
- weixuan[3] = LEDData[g];
- DigDisplay();
- void ADDX(uchar x,uchar y,uchar z)
- ADDC=x;
- ADDB=y;
- ADDA=z;
- void send(uchar x)
- EA=0;
- SBUF=x;
- while(TI==0);
- TI=0;
- EA=1;
- void ADC0808()
- ST=0;
- OE=0;
- ST=1;
- ST=0;
- while(EOC==0);
- OE=1;
- getdata=P3;
- send(getdata);
- OE=0;
- void main()
- init();
- LED=0;
- ADDX(0,0,0);
- while(1)
- ADC0808();
- temp=getdata*1.0/255*500;
- b=temp/100;
- s=temp/10%10;
- g=temp%10;
- if(RI==1)
- RI=0;
- if(SBUF=='A')
- LED=~LED;
- Display_Result();
