查看: 2328|回復(fù): 4
藍(lán)牙控制繼電器程序
ID:151689 發(fā)表于 2019-7-28 15:06 | 顯示全部樓層 |閱讀模式
#include "STC15.H"
sbit LED1 = P2^0;
sbit LED2 = P2^1;
sbit LED3 = P2^2;
sbit LED4 = P2^3;
sbit LED5 = P2^4;
sbit LED6 = P2^5;
/*void UART_Init()
        TMOD = 0X20;
        TH1 = 0XFD;
        TL1 = 0XFD;
        TR1 =1;
        REN = 1;
        SCON = 0X50;
        EA = 1;
        ES = 1;
                LED1 = 0;
                LED1 = 1;
                //UART_Init();
                //while(1);
/*void UART_SEA() interrupt 4
        if(RI)
                RI = 0;
                switch(SBUF)
                        case 1: LED1=0; LED1 = 1; break;
                        case 2: LED2=0; LED2 = 1; break;
                        //case LED3=0: LED3 = 1; break;
                        //case 0x03: LED2 = 1; break;
                        //case 0x04: LED2 = 0; break;
                        //case 0x05: LED3 = 1; break;
                        //case 0x06: LED3 = 0; break;
                        //case 0x07: LED4 = 1; break;
                        //case 0x08: LED4 = 0; break;
                        //case 0x09: LED5 = 1; break;
                        //case 0x010: LED5 = 0; break;
                        //case 0x011: LED6 = 1; break;
                        //case 0x012: LED6 = 0; break;
ID:151689 發(fā)表于 2019-7-28 15:09 | 顯示全部樓層
這程序只能在主函數(shù)里while大循LED1 = 0; LED1 = 1;繼電器才閉合
ID:651114 發(fā)表于 2019-11-28 18:54 | 顯示全部樓層
這是15單片機嗎?
ID:385830 發(fā)表于 2019-11-29 16:27 | 顯示全部樓層
第一:屏蔽兩段子程序,還有意義么?第二:在主程序里緊接著執(zhí)行下面兩行語句
        LED1 = 0;
        LED1 = 1;
連個延時都沒有,繼電器能反映的過來么?
ID:149799 發(fā)表于 2019-12-3 11:44 | 顯示全部樓層
繼電器反應(yīng)時間要10ms
